Garage Floor Before/After
38,565
410
25
About: We're Mother Daughter Projects, sharing our DIY adventures as we learn to maintain, improve, decorate, and use tech in our homes.
When Steph moved into her house, we knew we needed to redo the garage floor one day. It was half painted with carpet down the middle. We did some research on different products to use and found Rust-Oleum Rock Solid Metallic Silver Floor Coating Kit. Steph thought her mini cooper would look really cute parked on the floor so we decided to take on the project!
Supplies:
Step 1: Watch the Overview Video
Step 2: Watch the Prep Video
Step 3: Prep the Floor
Steph's garage floor was a mess! We did a lot of prep work, which you can check out in our prep video.
Step 4: Use Concrete Etch Solution to Clean Floor
The kit comes with this product and it helps prep the floor for the coating.
Step 5: Mix the Coating
The kit comes with a pouch with two components that need to be mixed together. Then you mix that with the metallic tint in a bucket.
Step 6: Apply the Product
We used a brush to finish the edges and then poured the coating on the floor and used a roller to apply.
Step 7: The Finished Look
The whole project took a few days and we learned a whole lot through the process. For complete details about what we learned check out our website.
    • Classroom Science Contest
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    25 Discussions
    swiddall
    2 years ago
    The floor looks great! I already have paint on my floor - I suppose that all would have to come up?
    DIY for Homeownersswiddall
    Reply 2 years ago
    If the paint is peeling yes- but you can do a test to see if you would have to remove it. The test info can be found in the pdf manual for Rock Solid floor coating- just google it and you should find it easily.
    Dawsie
    3 years ago
    thanks for sharing :-) I have been looking at this for Dads workshop :-) at least my prep will be simpler as its fresh concret floor that's been down now for 18 plus months so will only need the etching and washing prep :-)
    I love the look of the metallic floor so might surprise him with that look :-)
    Thanks again for the videos and the extra tips and tricks :-)
    DIY for HomeownersDawsie
    Reply 3 years ago
    Glad you enjoyed it! Fresh concrete will be so much easier. Good luck with the surprise!
    Redhawk06
    3 years ago
    Thanks for taking the time to step through your project in a positive fun way.
    cepterbi
    3 years ago
    Nice and informative video. The lessons-learned is great and so is the result. Tnx for sharing.
    londobali
    3 years ago
    Very nice.. and cool video..
    Thanks for sharing! I'll be waiting for more.. :)
    dlebryk
    3 years ago
    Wear golf cleats when you do this. You can walk on the epoxy and it will never leave marks, the tiny spots will heal over. Just clean the bottom of the shoes before you walk on the garage floor.
    Adding sand to the finish is a good idea - glossy finishes get super slippery. To add the sad, you kind of need to walk on the floor after the epoxy is applied.
    jeanniel1
    3 years ago
    How well does it wear? I mean, not just after a few days? What would scratch the surface - so to speak? It looks great, and you guys did a super job!
    DIY for Homeownersjeanniel1
    Reply 3 years ago
    It's been two months now and the floor looks the same as day one. I'm not sure what would scratch the surface. The coating is really strong and has held up great so far! Thanks!
