Garden Bench
31,087
405
8
Garden bench
Size 2m x 0,5m x 0,5m
Time: 3 days
Net cost: $15
Step 1: Step 1: Project
We want to make four identical benches and place them around a campfire.
We make the project: the radius to the bench must be so that we can put four benches close to each other and it will be a semi-circle around the fire.
Our sizes:
1. distance to the fire - 2 meters
2. the far edge of the bench - 2 meters
3. proximal edge of the bench - 1,5 meters
4. the width of the bench - 0,5 meters
5. the height of the bench - 0,5 meters
Step 2: Step 2: Measure Out, Saw Off, Process the Edges With a File
Sizes:
34 seat boards: 2cm x 5 cm x 50 cm
6 legs: 5 cm x 7 cm x 50 cm
2 connecting boards for seat (far edge): 4 cm x 4 cm x 100 cm
2 connecting boards for seat (a proximal edge): 4 cm x 4 cm x 80 cm
3 connecting boards from far edge to a proximal edge: 4 cm x 4 cm x 40 cm
Step 3: Step 3: Painting
Next day we paint our boards.
Step 4: Step 4: Frame for the Bench
Next day after painting we start the frame for the bench.
Legs connects with metal corners.
Step 5: Step 5: the Seat
The rays of our seat should be lined semicircle.
We lay out it easily with the rope tied to a stick.
Our rays we connect from the inside of the frame.
To turn over the bench and do not break the rays, we use paper scotch
Step 6: Step 6: Final Stage
To finalise our bench we connect side boards.
Step 7: Step 7: Invite Friends
When we finished our garden bench many friends came to see it.
Next parts of bench and fireplace are coming soon!
    • Pie Contest
      Pie Contest
    • Build a Tool Contest
    • Pocket Sized Contest
    8 Discussions
    Hoss58
    1 year ago
    I really like the looks of this bench. I have a few questions though. Could someone breakdown the measurements in inches? If not I guess I could do a little work and look online to convert. I saw where it said to use metal brackets to make the sets of legs. I didn't see how you connect the three sets of legs together. Someone else asked but I didn't see a reply what did you use to put seat boards on?
    NathanU9
    2 years ago
    What did you use to connect the seat boards and make them stay onto the frame?
    Crazy1234
    3 years ago
    love this bench!!!
    drakeschaefer
    3 years ago
    Nicely done sir! Quick question. What stain did you use for the bottom pieces? I really love the faux metal look it gives from a distance!
