Garden Box Construction (4'x6')
11,011
157
7
Have you ever wanted to build or buy a garden box?  The cost of pre-built boxes and lumber itself is extremely expensive.  Fortunately you can build one for just a few dollars in nails and tools if you use wood pallets.
Let's get started.
Step 1: Materials and Tools
Lumber -
1) 4 - 6ft pieces of 2'x4'
2) 4 - 4ft pieces of 2'x4'
3) 4 - 7in pieces of 2'x3' (can be easily substituted for 4"x4" or 2"x2", etc..)
PVC -
1) 6 - 7in pieces of 3/4" PVC piping
2) 3 - 10ft pieces of 1/2" PVC piping
Hardware -
1) 6 - 3/4" pipe fasteners
Tools -
Power Miter Box or Table Saw
Depending on construction either:
-Box of 2" 18Ga. galvanized nails
-Nail Gun
-Air Compressor
-Box of 2"-3" Screws
-Drill
-Drill Bit
Step 2: Assembly
Create first frame by butting up the joints and fastening. Repeat this process to construct a second layer or story for the box. Place on top and fasten together with pre-cut 1"x3"s (can add additional hardware if desired i.e. L-Brackets and other fasteners)
Attach the 3/4" PVC to the wood frame with the 3/4" pipe fasteners.
Place 10ft 1/2" PVC inside of 3/4" PVC housing.
Step 3: End Product
Completed Project
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    7 Discussions
    twighahn
    2 years ago
    Skip pvc for branches
    Gaige Kerns
    3 years ago on Introduction
    What if you Connected the pipes and put misters on the PVC to have a watering method
    phhbrown
    6 years ago on Step 3
    I like the functional fitness equipment in the background!
    Schmidty16
    6 years ago on Introduction
    for the pvc u could tap into it and and put hole in the pvc and make it a watering swstem in it that would be cool and put a green house canvise over to make it work extremely well
    pfred2
    To answer your question yes I have. When I made mine I made them out of 2x6s though and made them longer, and narrower than yours. I just went with the 8 foot length the wood came in, I made mine 32 inches wide inside too. I get two rows in each box, and stuff is easy to reach.
    For tools I used my radial arm saw, but I could have just as easily used a circular saw and a speed square. One tool I found indispensable constructing my garden boxes was 90 degree corner clamps. Those made putting the boxes together easy.
    Here is a picture of my garden boxes:
    http://i.imgur.com/hdMjt.jpg
    jessyratfink
    Very nice box - assembling lots of these would be really easy and cost effective. :D
