Geodesic Cat Ears Jewelry Accessory
3,329
105
19
This beautiful piece of hair jewelry accessory, inspired by Himmeli sculpture and geodesic structure, is both fun and unique. Made from simple copper tubing and bead wiring, these deconstructed cat ears are super fresh and eye-catching. For lovers of geometric design and unique, modern jewelry, this mind-bending DIY piece is sure to win hearts and turn heads where you go!
Rock them at the next get together to really bring the party. Or making a match pair to give to your special someone. Better yet, make them with your best friends so that everyone in your squad can rock some amazing geodesic cat ears!
Step 1: Get Your Materials and Tools Ready!
Note: I purchased all my materials and tools at Hobby Lobby and Amazon. You can certainly find most of them at any crafts retailer online or in-store.
At Hobby Lobby, I was able to find copper and aluminum tubing to make the gold and silver color pairs. If you look online, you can also order brass, gold, platinum, or you can invest in an airbrush gun and paint them all kinds of different colors. The possibilities are endless! Use your imagination.
List of Materials
1. 5/32 or .014 copper tubing 12 inches in a 3-pack x2
2. Bead wiring (about 30 ft. will be more than enough!)
You will find them in many weights. Medium or fine weight is recommended in order to fit through the tube in multiple loops.
3. A pair of hair comb (ideally < 1.5 inches in width each)
4. Transparent glue stick for glue gun
5. Fine-tipped Shapie
List of Tools
1. Ridgid 32975 1/8-Inch to 5/8-Inch Close Quarters Tubing Cutter
2. Jeweler wire cutter or scissors
3. Hot Glue Gun
4. Ruler
Step 2: Cut Your Tubes to Size
Using a fine-tipped Sharpie and a ruler, mark your 12" tubing into 1.5" sections. You should be able to get 8 pieces of 1.5" tubes from each 12" tubing.
36 pieces of 1.5" tubing
2 pieces of 1.75" tubing
Next, use the tube cutter to cut the tubes. Here's an instructional video on how to use a small tube cutter.
Note: It will take some patience at first to get a hang of tube cutting. It may also get tedious at times so take frequent breaks! If you have delicate skin, please wear work gloves for protection because I did get some redness on my finger from turning the copper tubes repeatedly.
Step 3: Make a Base for the Cat Ears
Start by taking a long piece of beading wire (about 6 ft.) and start stringing three pieces of tubing to form a triangle. To secure the triangle shape, pull the wire through one of the sides and tighten. Next, take another three pieces of tubing and repeat the process.
You will keep adding more triangles until you have a structure that looks like the base above.
Note: You will only need to add two or only one piece of tubing at times because you are building upon triangular structures already in place. If you make a mistake, it's not a big deal at all! Simply remove the extra or misplaced pieces and start from there.
Patience is key and don't give up!
Step 4: Make the Cat Ear Tip
Once you have the base structure, take two pieces of 1.5" tube and one piece of the 1.75" tube to finish constructing the cat ear tip. You are going to connect the shorter tubes to the top of the base and use the longer tube to extend along the back of the ear as support.
Join the pieces together by pulling the wiring through the tubing and tracing the triangle shape through the tubes twice for added security.
Viola! You are half way there. You now have ONE cat ear! That's half the battle!
Take a break. Get up, stretch, drink some water, and come back when you are ready to do it all over again.
Note: If you run out of wiring, don't fret! At this point, the wiring is already completely secured on most of the structure. Simple trim the wiring at a convenient point, as close to the joints as possible to minimize the wires sticking out. Alternatively you can tuck the wiring into the tubes to hide them.
Step 5: Make the Second Base
It should be much easier the second time around! You will make more triangles, just like in Step Three, with the exception that the left-side of the second base will connect to the right-side of the base that you already made. The rest is exactly the same!
Step 6: Complete the Second Cat Ear
After you have completed the base, attach on the cat ear tip just as you did in Step Four. Now, carefully clip away all excess beading wires that are still attached. If you have any areas that are loose, no worries! Simply get another piece of beading wire and secure that section by making several loops through the tubings around the triangular shape.
HOORAY! You now have the geodesic cat ears completed. Take a moment to enjoy this victory and pat yourself on the back before we make it ready to wear.
Step 7: Glue the Hair Comb to the Cat Ears
This is the last step. Congratulations on making it this far!
It's time to take out your hot glue gun and hair combs. Load the hot glue gun with a clear glue stick and wait for it to warm up. Squeeze a bit of the glue onto the top of the hair comb (with the teeth curving downward) and while the glue is still hot and soft, press it onto the right-most tubing on the cat ears. Repeat for the left-side.
Note: If you were not able to hair comb that's less than 1.5 inches wide, you can always use heavy duty shears to cut the comb into 2 pieces. When I went to Hobby Lobby, they were out of the hair combs that I needed so I had to buy 2" hair combs. I just split them into two 1" pieces for this project.
Note: I choose black because I have dark hair and the hair combs better hidden. However, if you have a lighter hair color, try using clear combs or combs that match your hair color for best results!
Step 8: Share and Rock These Geodesic Cat Ears!
YAY! You are now finished making your fancy DIY geodesic cat ear hair jewelry. Rock them at the next get together to really bring the party. Or making a match pair to give to your special someone.
Better yet, now that you know how to make them, teach your friends so that everyone in your squad can rock some amazing geodesic cat ears!
Jewelry Contest
Runner Up in the
Jewelry Contest
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    19 Discussions
    SilentSkeleton
    2 years ago
    So cute! I'm definitely going to try this. I don't have the tubing things, but i'm gonna try and use coffee stirrers and spraypaint it gold :o)
    warriorethos2
    3 years ago
    cathychen, your geodesic cat ears jewelry accessory is nice. In step 1, do you start by finding the middle of the wire or do you start at the end and leave some wire on the free end of one side of the first triangle? This part was not clear for me. Since this is wire your running through the copper pipes how do you tie it off at the end so you don't see a big knot? Good luck in the jewelry contest.
    cathychenwarriorethos2
    Reply 3 years ago
    I start by leaving some wire free on one end, about 6 inches or so, and then I detach the rest of the wire from the spool. Just try to keep the wire from tangling too much in the process of making. I don't tie off the ends, I simply loop them through the same triangle tube formation a couple of times and then snip off the excess. I hope this answers some of your questions!
    warriorethos2cathychen
    Reply 3 years ago
    Thank you for your clarification. Again good luck in the contest.
    cle0o_143
    3 years ago
    So cute..do you think it can be done separately? so the ear won't be to close by..
    cathychencle0o_143
    Reply 3 years ago
    Absolutely! One of the beauty of geodesic designs is that you can customize it into different configurations. Just add another tubing when you are making the second part of the cat ears instead of connecting it to the first ear. I would also recommend adding another set of combs. Let me know how it turns out!
    charlesd.parker.33
    3 years ago
    This talent will surely take you far. There are too many with little or no imagination out there. Stay with it and one day you will surely be a Star! An artist of merit to be!
    cathychencharlesd.parker.33
    Reply 3 years ago
    Thank you. I hope to post another Buckminister Fuller-inspired baseball cap that I'm prototyping for another competition soon!
    oscardelben
    3 years ago
    I love that you add some geometric designs in this Cat ears. It look so classy since you also use gold color on this. I guess this will cost much if I buy this in some famous fashion stores but you made it easy for mevto make this at home. Your a star!
    cathychenoscardelben
    Reply 3 years ago
    I really dislike it when designers charge 300 dollars for something that costs 30 dollars to make. Sure, you are charging for the design but 100% markup? That's why I love Instructables and Open Source DIY projects!
    charlesd.parker.33
    3 years ago
    cathychenmomoluv
    Reply 3 years ago
    Thanks! Always get compliments when I wear them.
    _Amelia_
    3 years ago
    Totally awesome! I imagine they're somewhat flexible so getting them on with the hair combs is easy, right?
    cathychen_Amelia_
    Reply 3 years ago
    Yes, they do stretch a bit and so you can easily adjust them to fit. :)
