Geodesic Dome From Laser-Cut Cardboard
12,381
97
16
About: We are a non-profit that solves problems for and with the poor in developing countries using design.
In this brief tutorial, we will show you how to build geodesic domes using cardboard or foamcore board panels. We manufactured our panels using a laser cutter with a 2'x3' area. If you are highly motivated, you could also create these panels by hand, using the same design template.
We assembled our domes using Makedo screws (https://www.make.do), an amazing and re-usable tool for cardboard prototyping. If you're impatient to get building, you could also assemble your dome using zip-ties or binder clips.
NOTE that this Instructable is a draft! Help us make it better by putting your suggestions in the comments!
Supplies:
Step 1: Design the Dome Panels
We have designed panels for what's called a 2v-dome with 40 panels, and a 3v-dome with 75 panels. Cut from 2'x3' cardboard stock, the 2v-dome is 36 inches tall, and the 3v-dome is 54 inches tall. You can create an even larger 3v-dome with an additional bottom strip of 30 panels that will be almost six feet tall, but it isn't as stable as the other two domes.
Attached are the dome panels as a CorelDraw file. This is the format that works best with the printer driver for our Epilog Legend 36EXT laser cutter. Please request other file formats in the comments!
Step 2: Notes on the Dome Design
Our goal was to make the biggest possible geodesic dome using panels cut from 24"x36" cardboard using our 60W Epilog laser cutter.
We first considered a 2V 3/8th dome design, which has just 40 panels. Note that most dome calculators provide parameters in terms of struts and hubs.
See the attached Excel spreadsheet for all of our calculations.
Step 3: Inspirations
Step 4: References
1. Desert Domes reverse dome calcs
2. Geo Dome UK
HOWTO GENERATE PANEL DIMENSIONS:
  • estimate maximum strut length using example triangles in CorelDraw. Goal is to fit two triangles on each 24"x36" cardboard sheet, including 1/2" wide assembly tabs on each triangle face. this looks like 22.5 inches.
  • in 2V dome, using Desert Domes calculator, this max length is the input for the A strut in 3V dome, using Desert Domes calculator, this max length is the input for the C strut
HOWTO CALCULATE THE NUMBER MAKEDO FASTENERS
  • assume three fasteners per intersection/strut
  • subtract three fasteners for every "base" strut
DIY Summer Camp Challenge
Grand Prize in the
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    16 Discussions
    Hungar
    4 days ago
    Very cool project! I'd like to do it with my students but our laser cutter is only 12" x 36". Do you have recommendations for recalibrating the triangle dimensions and configuring them?
    Vherrmann
    Question 6 months ago on Introduction
    Bonjour,
    Je m'appel Valérie, je réside en France et je souhaite savoir si vous avez un kit comme sur la photo de la dame qui lit un livre à l'étape 2 (ci-dessus) : Notes sur la conception du dôme.
    Quelle est le prix du kit (comprenant cartons et vis Makedo).
    Merci par avance.
    angiekconnell
    6 months ago
    Is there a way to get the measurements without the use of a lasercutter? I would like to make a dome of this size but to not have the cutter.
    waynevanwijk
    8 months ago
    Thanks for a great instructable.
    I'll add a few thoughts from my build that may be of interest to other makers.
    I took your plans for the 2V dome and scaled them down to suit some scrap 4mm thick C-flute cardboard that I had available. While scaling down was easy enough I found that the folding tabs were only just big enough to take the make-do screws. I'm thinking that if I scale it down further then I will have to enlarge these. Regardless, it went together well.
    To make things easier, I put holes in the A-A-A triangles to easily differentiate them from the B-B-A triangles, which were left without holes.
    Putting the joining tabs on the inside gives a crisp look, but I think that putting them on the outside would make construction easier.
    As a side note, if you can get access to a CNC plotter then definitely use this over a laser cutter for corrugated card. It saves the burnt edges that go along with laser cutting.
    makedo-ablewaynevanwijk
    Reply 8 months ago
    Looks like you had fun with this one! Thanks for sharing your experience.
    You make several good points here, that should be helpful for other makers...
    We have found that the tabs on the outside make for a stronger, more robust construction. Whether this suits your own creation depends on whether or not you mind revealing the construction elements as a part of the overall visual style.
    For the burnt edges, a lot can come down to the specific settings or fine tuning of the laser cutter for use with cardboard. You can also try cleaning up after cutting with compressed air or gently wiping the edges down.
    waynevanwijkwaynevanwijk
    Reply 8 months ago
    For some reason the photos uploaded upside down - probably because I am in Australia. But that does give me a great idea on how to save on floor space...
    KathrynG27
    2 years ago
    Is it possible to get the plans for the 3V dome as a pdf or an Adobe Illustrator or any other MAC-based file? I am a school teacher and I want to build this with my students. Thank you
    We've just posted Adobe Illustrator (.ai) versions of the 2V and 3V dome files, along with an assembly instruction sheet we designed for a recent event (PDF). Note that the panels are scaled for 24" x 36" cardboard sheets--you may need to scale them to fit your laser cutter, or your printer if you're planning to cut the panels by hand.
    don57
    2 years ago
    I see it as more of a play structure than a shelter so I'm less concerned with keeping occupants dry but if you can waterproof the cardboard you can keep a usable dome rather than a sodden heap of paper
    Design that Mattersdon57
    Reply 2 years ago
    What we're currently working on are panels cut from 3/16" thick sheets of coroplast. Found here at ULine for $5.60/sheet in 100-unit quantities.
    http://www.uline.com/Product/Detail/S-13338W/Corrugated-Pads/24-x-36-Plastic-Corrugated-Pads-White?model=S-13338W&RootChecked=yes
    Compared to our favorite cardboard stock, 200lb corrugated cardboard pads at $0.99/ea in 100-unit quantities:
    http://www.uline.com/Product/Detail/S-2483/Corrugated-Pads/24-x-36-200-lb-Corrugated-Pads
    The trick is to minimizee the amount of hand-work necessary to "finish" each panel after cutting and etching with the laser. This Google group discussion claims that polypropylene is safe to cut with a laser, but they point out that the "flutes" inside the coroplast panels make the material harder to score for bending.
    daviderrDesign that Matters
    Reply 2 years ago
    Hello,
    I'm looking into building a dome for a school project would you happen to have the layout for Mac computer.. PDF or illustrator any Adobe programs
    Best regards,
    David
    newillmeister
    2 years ago
    Could we get the files as EPS or Illustrator files? I don't have anything on my Mac that will open the Corel Draw files. Thanks! :-)
    don57
    2 years ago
    Very cool. If you spray paint the cardboard panels you will gain a modest amount of waterproofing. Should last through a few heavy summer storms especially since the shape itself sheds water.
    Reply 2 years ago
    That'd be a fun experiment! Given all the holes and seams, I bet the dome leaks like a sieve.
    dhaykus0418
    2 years ago
    Very cool idea. I only have access to a 24" x 18" Epilog laser, would it still be doable?
    You laser-cutter can absolutely cut the cardboard and foamcore board. The trick will be scaling the panels to fit in your machine. We've posted the CorelDraw files. Just make sure you proportionally scale the part (ie x and y axis scaled by the same amount) so that the geometry still works.
    For extra credit, you could use the Excel spreadsheet to calculate custom panel dimensions that are a better exact fit for your machine.
