Getting Stock Prices on Raspberry Pi (using Python)
64,700
315
15
About: Scott Kildall is an new media artist and researcher. He works at Autodesk, Pier 9 and is an artist-in-residence with the SETI Institute
I'm working on some new projects involving getting stock price data from the web, which will be tracked and displayed via my Raspberry Pi. I wanted to share the setup on how to do this using Python.
This short Instructable will show you how install a stock querying library to get (mostly) realtime stock prices using Yahoo Finance API. There's no GitHub involved!
You can also use this stock price-gathering engine on any Linux server.
Step 1: Setup Your Raspberry Pi
If you haven't done so already, you'll want to do a basic configuration of your Raspberry Pi. You'll need internet access for this software installation.
If you are just getting started, my Ultimate Raspberry Pi Configuration Guide will get up and running.
I prefer using ssh and am using Terminal on a Mac, but as long as you have internet connection, you'll be fine.
We will be using the command line for this tutorial on a Raspberry Pi.
Step 2: Run Updates and Upgrades
Whenever you add new libraries to your Raspberry Pi, you want to update and upgrade your software packages. We'll start with this step.
Type in
sudo apt-get update
then
sudo apt-get upgrade
choose Y to continue when asked
You'll see the usual scroll of Linux and will have to wait several minutes. Get up and do some stretching after each of these commands.
Step 3: Install Pip
pip is a package manager and installer for Python. We want to have this installed to get the appropriate Yahoo python stock libraries loaded onto the Pi.
Type in:
sudo apt-get install python-pip
This will take a few minutes.
Step 4: Install Ystockquote
ystockquote is a Python module that will let you easily gather stock quotes from Yahoo. It does this reasonably quickly, a lot more so than BeautifulSoup, which would be another way to get stock data.
Type in:
sudo pip install ystockquote
Step 5: Write the Python Script
We will create a new directory and a Python script to get the stock data. Type in:
mkdir stockquote
cd stockquote
nano stockquote.py
This will bring up the nano editor.
Type in this following 4-line Python script
import ystockquote
tickerSymbol = 'ADSK'
allInfo = ystockquote.get_all(tickerSymbol)
print tickerSymbol + " Price = " + allInfo["price"]
cntrl-X, Y will save the .py file.
Step 6: Run It, Done!
Now run it.
python stockquote.py
You'll see the latest stock quote from Autodesk.
Buy! Buy! Buy!
I hope this was helpful!
Scott Kildall
For more on the my projects, you can find me here:
@kildall or www.kildall.com/blog
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
15 Discussions
tonyD5
1 year ago
it worked
BenH274Overmind121
Reply 1 year ago
I'm getting the same error, was a solution found?
Archer19
2 years ago
how does one import the ystockquote module for python 3?
mmanuel2
4 years ago on Introduction
Script for multiple symbols:
import ystockquote
tickersymbols = ['ADSK','AAPL','ZNGA','GPRO','GOOG','EA']
for tickerSymbol in tickersymbols:
price = float(allInfo["price"])
change = float(allInfo["change"])
percent = change/(change + price)*100
peratio = allInfo["price_earnings_ratio"]
print tickerSymbol + "\t= %+3.2f (%+0.2f, %+0.2f%%) P/E %s" % (price, change, percent, peratio)
KingN7mmanuel2
Reply 2 years ago
Type error: can only concatenate list (not "str") to list
eplambec
3 years ago
Everything works great. Can you suggest how to multiply the stock price by a set number (for example #of shares) to display a new number?
PiAlex
3 years ago
Is there a way to get it to also trade off the prices ?
PiAlex
3 years ago
DwayneWei
3 years ago on Introduction
I would like to see the expansion of this to stock trading
NoobT
Awesome little project! I am working on expanding on it. Thanks!!!
Hi.
How do i make a code box when making an instructable, because i am making an instructable and without it it looks really bad?
wilgubeast
This project is clean, simple, and useful. I appreciate the integration with your RaspPi configuration 'ible, too.
Klappstuhl
Now to write a program to make the Raspberry Pi trade stock on the market on its own, haha!
Nice instructable!
