Giant Clicker Pen!
39,456
52
15
We built this enormous retractable pen as part of our Kinematics class at BYU.
The goal was to build a mechanism big enough to teach and be handled by fourth-graders.
Collaborators: Ryan Anderson, Scott Taysom, Steve White, Brettany Rupert, Clifton Dudley, Wyatt Felt
Here's a look at the materials we used:
Giant Spring (taken from a broken fan base)
clear tube: 30"
plexiglass: .25" or .375" thick, 5" long .5" (2 of them) wide
plexiglass: whatever thick and abt 2.75" dia
1" PVC pipe  abt 3'
upper pusher - 2.25" diameter plastic 8" long
lower pusher - 2.25" diameter plastic: 7.5" long
tip   -  2.75"+dia  4.5"long
spacer  - 2 1/4" by   1.5" long
set screws - various sizes
Big ol' Marker
Small spring and guide rod for cams
~$60, weighs in at 4 lbs
Step 1: How It Works
The mechanism for a clicking pen is a bi-stable cam system. It is actuated by a guide pin and a compression spring  In the retracted position the spring is pre-loaded in order to keep the upper and lower cam pressed together.
When the pen is pressed to the change point, the lower cam clears the guide pin (Fig. 1b). The force of the compressed spring is larger than the friction on the inclined surfaces of the cams, and the lower cam rotates as it retracts into the extended position (Fig. 1c).
By compressing the spring past the change point again, the lower cam rotates and the upper cam is guided back into the retracted position (Fig. 1d). The stroke length from the retracted to extended position is 1”.
Step 2: Obtain Spring and Scale CAD Files
We scaled our entire project around a spring we'd recovered from a fan base.
Our CAD files are designed to work with a spring that is slightly larger than 1" and about 14" long uncompressed.
We've attached the files we used below. They will probably need to scaled to work with whatever spring you have available.
Step 3: Build It!
The central rod is a 1" PVC pipe.
The CAM mechanisms were cut using a 3-axis CNC Mill.
The Axially-symmetric parts were turned on a lathe.
The guiding sliders (trapezoidal) were cut on a laser-cutter.
We used set screws to hold the nested parts in place
We used a Dry-erase marker as our pen tip.
Challenges/Refinements
As most engineering projects, when we began to build our physical model we encountered challenges that the CAD model had not predicted. One of the biggest challenges that we encountered was friction between the two cams. We anticipated this friction and to prevent it from binding the mechanism, we inclined the sliding surfaces of the cam to 45° in the CAD model (Fig.  4).
When we built the model we found an unanticipated problem during the retraction of the mechanism where the upper cam became wedged between the flat face of the lower cam and the slider. Instead of the pen automatically popping back up and letting the lower cam fall into its extended stable position, the user needs to fiddle with it to overcome the friction.
The pen tip  prevented the mechanism from running smoothly. Due to manufacturing errors the two guiding circles on the pen tip were not concentric. In order to solve this problem we decided to widen the radius of the cylindrical hole in the pen tip. This gave the pen looser tolerances and allowed the pen to extend and retract easier.
Another problem that we encountered was the effect the planned gaps between the pen wall and the cams had on the hardware. The outer diameters of the cams were turned down so that there would not be friction between the cams and the wall as they slid up and down.  However, this spacing made it difficult for the cams to remain concentric during mechanism motion. In order to solve this problem we added a guiding rod (see picture) between the two cams to maintain their concentricity.
We also had some issues with material fracture.  We originally designed the pen end-cover using .25” acrylic, which we cut with the laser cutter. However, the recoil of the cam returning from the change point back to the retracted stable position caused the acrylic to crack. In order to solve this problem we replaced the acrylic cover with a thicker piece of less-brittle plastic.
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    15 Discussions
    smallmachine
    4 years ago on Introduction
    Sweet project, very cool way to demo the concept. I found this project while looking to understand the mechanism in a conventional retractable pen and it is worth pointing out that this is not that mechanism.
    In Fig.1, the system is locked in step C by pressure from the spring and the upper cam must be retracted by a different force. Pulling on the clicker (as in the video) or adding a second spring to the upper cam would accomplish this, but that is not how click pens work.
    I am not detracting from the project or its aim of introducing mechanical thinking to young students, but maybe I can save the next person some time modeling and 3D printing this design, as I did, only to find that it does not work like a click pen.
    Still a cool giant pen.
    Jewson
    6 years ago on Introduction
    That is a boss pen but I don't think it's going to fit in my pencil case.
    poofrabbit
    This is amazing! I'd love to have this in my room with a huge piece of paper and have kids draw with it! Well done!
    Cephuspoofrabbit
    Reply 6 years ago on Introduction
    Are you old enough to remember the teaching slide rules hanging above the blackboards in math class? This pen would go perfectly with one of those!
    poofrabbitCephus
    Oh dear now I am going to date myself! yes I am old enough to remember that!! Also all the giant compass, protractors and other gizmos on the chalk board, now we don't even use chalk boards because of asthma (and smartboards are way cooler anyway lol)
    Bugsley
    Pocket protector, instructable, next?
    Great work.
    Mr. Boo
    As a former industrial modelmaker and prototyper I have to say "Great job".
    lucylollipop
    This is fab! And the information on the mechanisms is really useful too - brilliant :)
    bobzjr
    Very Cool! I really like this one. Well documented and also great to have the challenges/refinements section. That section helps us to learn from your experiences. It's good to see what bumps in the road you came upon - and how you handled them.
    To me this project is a piece of functional art.
    Keep up the good work.
    Boost
    Oooo. I wish it would click louder so I can build one of these and annoy the hell out of the clicker-nuts at the office. :-)
    Very cool pen.
