Gift Card Wrapping Ideas (with Free Printables)
1,917
27
Gift card is a common choice of gift but that does not mean the presentation has to be common too. Presenting to you five creative gift card wrapping ideas to add a ‘wow’ factor that your friend will love. Easy to print and make in under 10 minutes!
Get the free printables here: http://akioneam.com/gift-card-wrapping-ideas/
Supplies:
Step 1: STYLE 1:
The yellow and sand color square box is the same size as the printable heart pattern gift boxes shared before. There are no additional instruction for this gift card wrapping idea. Simple, clean and fun.
Step 2: ​INSTRUCTIONS:
Print your choice of gift box, card or wrapping sheet- from the five gift card wrapping ideas- on an A4 sheet.
Cut along the solid lines. (Use the final gift card wrap pictures in this post for reference.)
Fold along the dashed lines.
Glue the tabs with white craft glue or double sided paper tape. (Use the final gift card wrap pictures in this post for reference.)
Place card inside and if needed use fillers like tissue paper.
Seal with a sticker.
Write your name in the ‘from’ box.
Step 3: STYLE 2:
This three fold wrap is the most complicated and unique of the gift card wrapping ideas shared today. It consists of three parts- the blue patterned gift card holder, the yellow multi patterned outer shell and the blue with floral tags. For the gift card holder, cut around the outline – fold the left and bottom tabs – and glue the tabs. Next punch the holes using the grey circle guides and place your card in.
Step 4:
The outer yellow patterned shell is easy to make. Just cut around and fold at the various pattern joint lines. Punch holes at the grey circle guides. Next using a piece of string or ribbon attach the card holder to the outer shell. Lastly using double sided tape attach the tags over each other.
Step 5: STYLE 3:
Third is a rectangle box of 3.75 inch x 2.5 inch x 1 inch (lxbxh). It is the perfect dimension to place a gift beautifully wrapped in gift wrapping tissue paper. Follow the instructions stated next. Next, cut around the blue label, polka dotted circle and ‘congratulations’ flag. Using small pieces of double sided foam tape place it over each other.
Step 6: ​INSTRUCTIONS:
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
