Glowbugs - Homebrew Tube Amateur Radio Transmitters and Receivers
24,152
43
17
About: Partido Geozentrista de los Martianos Intruderz
Glowbugs - homebrew (DIY) tube gadgets, receivers and transmitters, dedicated to the Golden Era of Amateur Radio. Generally, any small, home-built tube-type transmitter or receiver may be referred to as a glowbug. The majority of glowbug transmitters are designed to be used in the CW radiotelegraphy mode. www.squidoo.com/glowbugs
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    17 Discussions
    wd4nka
    5 years ago on Introduction
    Andy, your stuff is always so awesome. One day, I need to print up some vintage Letterpress QSL cards for you, to go with your vintage station. Hey! I just came across the carcass of an old Grundig Majestic. Perhaps I can salvage the transformer and filter choke, toss a few filter caps, a 5U4, and rig up a 6AG7 / 6L6 MOPA to couple with my HRO-5 that I hope to re-cap.
    Johenix
    6 years ago on Introduction
    Andy, UU1CC, I assume that is your call sign?
    I have a small interest in Glowbugs.
    I found an old "QST" article about a home brew, two band Reciever (80 & 40 M) from April 1941. Principle seems sound even though it uses a "C Battery" for bias- 6V AC for filaments.
    I would like to rebuild it or something similar using a 1U5 and a 1R5 so I could be completely battery powered. I probably would use a "B Battery" of AA pen light cells.
    Worst kit I have found from the 1950's was a ONE TUBE ham station offered (for about $15) by a one man company in Kearney, Nebraska. It was 1/2 triode oscilator transmitter, 1/2 triode Regenerative reciever. You were lucky to be heard across town. A PI network to match it to the antenna might have helped it to get out better.
    I was thinking of using a tube like that double triode as a push/pull crystal oscilator transmitter.
    I also have plans for an early 1950's camper's 2 tube superhet reciever ( 1U5, 1R5) from "Popular Mechanics" magazine.
    Oh, yes, my call is KC0KBG.
    welder guy
    7 years ago on Introduction
    I like it! This is the true spirit of HAM radio! I have to make one of these soon!
    -KC2VDM
    wa2qcjshobanaelango
    The biggest issue for a FM receiver is the detector stage, and a limiter. The limiter stage is simply an amplifier that is followed by a diode clipper stage. Insertion of these 2 stages into an AM radio will net you a FM receiver. Schematics for FM detectors, and limiters abound on the Internet, so a google search should net you what you need. If you can follow a schematic, then you should do quite well with this project.
    IC versions of these radios are also very common, and readily available.
    Andy UU1CCelectricfan
    You're right - it is early Russian 6L6-GB's clone - 6P3 http://timelesson.blogspot.com/2010/02/6p3-beam-power-tetrode.html
    me
    9 years ago on Introduction
    nice, it has a steampunk look to it, I like it, you should really post a how to...
