GoPro Dog Collar
34,528
241
23
About: I have a burning passion for building and creating things, and that's why I admire Instructables so much - everybody welcomes and helps inspire creativity.
Dogs are amazing. Anyone that has had one knows exactly what I'm talking about. So have you ever been interested in seeing life how your four-legged friend sees it? Well after a little experimenting, there's finally an easy way to do just that.
Here's some video using the GoPro Dog Collar.
http://www.youtube.com/watch?v=56-OaEwo3KE
Supplies:
Step 1: Tools & Materials
To build this GoPro Dog Collar you'll need some basic items and some basic tools.
Materials:
• A GoPro and it's original packaging
• 4 small bolts
• 4 small nuts
• A thick, wide dog collar made of nylon/leather that is capable of carrying a GoPro camera.
Tools:
• A Dremel
• Drill bit and Cut-Off Wheel bit for Dremel
• A screwdriver
• A wrench/pliers
• Sandpaper (optional)
Oh, I almost forgot, you're going to need a dog too!
Step 2: Gopro Display Plate
When you purchase a GoPro it will be screwed into a plastic plate inside the packaging. It attaches to the plate using what is called a quick release mount, a commonly used tool with the cameras. You'll need to separate this plate from the packaging, as you're going to make some cuts to this thing with your Dremel.
Place and line up the display plate on your collar as shown in the photo. Make marks on plate for where to cut. The goal is to cut the plate to the width of the collar, but no more and no less. You're essentially making a belt-buckle. After you've cut the plate, you'll probably have some rough edges. Take some sandpaper to it if you feel like it, it will be more comfortable for the wearer.
Proceed to drill 4 holes through the plate and through the collar in the exact places. The holes must be lined up correctly for the next steps to be successful. (Ignore the extra holes, some were used in packaging.)
Step 3: Attaching the Mount
Insert the bolts into the holes you've drilled in the collar. If you're using nylon, this will be tricky. A screwdriver or possibly even drill will be necessary to screw them into the collar.
Once the screws are in place, place the plate you've just cut to size on top of the collar where you've chosen to mount it. The bolts and the holes in the plate should patch up perfectly, and there should be enough bolt sticking out of the plate to fasten a nut to. Use your wrench or pliers to attach the nut tightly. By now there should be little to no bolt protruding past the nut.
Step 4: Finished GoProduct
Now you're all set to film some footage! I've used this mount countless times with my German Shepherd, she seems to enjoy running around with it on. This is one of the most unique GoPro mount I've ever seen, so enjoy the neat footage you get while using it!
Thanks to all of my supporters, subscribers, and feedback givers!
Pet Contest
Second Prize in the
Pet Contest
    • Classroom Science Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    23 Discussions
    Yes! GoPro includes wifi hotspots built into the camera, therefore you can pair the camera to your smartphone, and watch a live feed! It's very cool.
    kiley_belltrans4mation
    Reply 3 years ago
    I'm interested in buying a GoPro (and attaching it to the collar like you've shown above...great idea!) but I'm a bit confused about the wifi hotspots/live stream thing. My dog roams the forest behind my house a lot and I would love to see what he is getting up to in real time by checking my smartphone to see the live feed. Do you know if this is possible or does he have to be within WiFi range to my house? (which would only be a few feet at best)
    JoeG122kiley_bell
    Reply 2 years ago
    The app for smartphones actually results in your phone pairing to an ad-hoc wifi created by the GoPro, or at least the newest versions do. So you're limited to a fairly short range created by the camera itself.
    Lokisgodhi
    4 years ago on Introduction
    Uh oh. Now there'll be evidence of all the things your dog does that he doesn't want you to know about.
    Expect to be served with a lawsuit from the ACCLU* for invasion of privacy forthwith.
    *= American Canine Civil Liberties Union.
    Javin007
    5 years ago on Introduction
    I'd do this, but I'd end up with 20 hours of the bed comforter. The other 4 hours would be the window sill. :/ And they're not even old. Just lazy.
    trans4mationJavin007
    Reply 5 years ago on Introduction
    I know the feeling, I have a golden retriever (also not old) that is not much of a retriever. Go figure? :P
