Goodmorning Underwear
449,546
873
164
The Goodmorning Underwear are a pair of panties that vibrate to wake you up in the morning. This project is a continuation of my ongoing efforts to further the field of electronic underwear. Unlike all of my previous projects that use complex circuitry and fabrication techniques, this one is based around the littleBits prototyping platform and is easy enough anyone can make at home.
This particular project came about because I finally wanted to make a garment that my girlfriend would actually want to wear. While it may be hard to believe, when I made the Clap Off Bra it was not really for her. Sure, I may have gifted it to her to use, but it was really something that I made for myself. This time around it was important to me that I should repay her for all of her patience and make something that she would truly appreciate.
Truthfully, this is a little bit tricky because I have noticed that she does not wear underwear all that often. Largely she wears underwear only when she goes to bed. While this may seem like a backwards approach to underwear usage, it ultimately proved to be my design constraint. Thus, I began to consider how her underwear could be enhanced to improve her resting hours.
Through nearly a decade of intensive study and observation, I have come to learn that she is not really much for being woken up in the morning and does not particularly care for alarm clocks. However, over the last ten years I have also observed that she is awfully fond of devices containing vibrating motors. It then goes to follow that she would enjoy her alarm clock much more if it vibrated her awake instead of bombarding her with horrible, wretched, noise. To test this hypothesis, I have created the Goodmorning Underwear. It is my sincere hope that this garment will promote a happy, healthy, and holistic lifestyle.
Or maybe these are all half-truths and I just "borrowed" this idea from Carleyy (who in turn got it from a friend).
Nonetheless, I still developed and shared directions for making vibrating alarm clock underwear. You're welcome.
Step 1: Materials
You will need:
(x2) Underwear (briefs)
(x1) littleBits Cloudbit
(x1) littleBits power (p1)
(x1) littleBits USB power (p3)
(x1) littleBits pulse
(x1) littleBits wire
(x2) littleBits vibration motors
(x1) 9V battery and cable
(x1) 12" x 12" mat board
(x1) 1 yard soft felt
(x1) Zip tie assortment
(x1) 6" adhesive hook and loop
(x1) Assorted thread
(x1) Sewing needle
Step 2: Setup the Cloudbit
Power up the Cloudbit by connecting it the USB power bit.
Configure the Cloudbit using the easy-to-follow initialization walkthrough on their website.
Step 3: Build the Circuit
Connect the following bits in series:
Power Bit (p1) --> Cloudbit --> Pulse Bit --> Wire Bit --> Vibration Motors Bit --> Vibration Motors Bit
Once the circuit is built and running, adjust the dial on the pulse bit until it is pulsing to your liking.
Step 4: Make a Google Calendar Alert
Create a new Google Calendar which will be used for setting events to trigger your alarm.
Each new event will be used to trigger the alarm. You can make single events or recurring events as per your preference.
Step 5: Configure 'If This Then That'
Go to If This Then That and create a new recipe that activates the Cloudbit output high for 30 seconds when any event starts on Google Calendar.
Step 6: Cut Brackets
Use the attached template to make mat board mounting brackets for the larger chain of littleBits.
Step 7: Fasten the LittleBits Together
Insert the littleBits into the mounting bracket with the holes and place the long thinner bracket on top. Note that there is not cardboard mounts for the two vibration motor bits, as this was deemed unnecessary.
Use zip ties to securely fasten all of the littleBits in the circuit together.
Step 8: Prepare the Fabric
Cut two rectangeles that 3.5" x 6" and 3" x 3.5" out of the second pair of undies. These will be used to add a sense of style to the circuitry and cover up the felt padding that will be wrapped around it.
Next, cut a small piece of the elastic band for use as a battery holder strap.
Cut two rectangular pieces of felt that are 3.5" x 5.5" and 2.5: x 3.5".
Glue and fold over the edges of the underwear fabric squares to keep it from fraying after it is sewn.
Step 9: Pad the Electronics
Wrap the felt around the circuitry and sew the the seam together with whatever stitch works best.
Next, wrap the decorative fabric around the felt and sew this seam together as well.
For an added touch, cut two small circles of fabric from the extra underpants and adhere them to the vibration motors using the motor's adhesive backing.
Step 10: Finishing Touches
Cut a 5" and a 2 " section of adhesive-backed hook and loop fastener.
Adhere the soft side of the fastener to the backside of the padded electronics.
Next take the fastener's plastic "hook" side and adhere the longer of these pieces centered below the front waist line. Position the shorter second piece vertically between the two leg holes.
Sew the plastic motor snaps wherever you see fit to place them (in relation to the position of the circuitry).
Finally, take the small piece of cut elastic strip and sew it to the underwears to form a small loop to hold the 9V battery.
Step 11: Have a Good Morning
Put them on, set your alarm and wake up to a wonderful day.
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    164 Discussions
    FredR50
    4 months ago on Step 10
    Seriously how is this appropriate???
    osbock
    2 years ago
    I made a parametric mouting plate for littlebits that you could modify for mounting. It requires 3d printing, but with a little openSCAD magic, you can make them into any shapes you want. The code is here:
    https://github.com/osbock/Baldwisdom/tree/master/LittleBitsMounts
    The Golden Arrow
    3 years ago
    what if the battery exploded? just in. case
    zlorph
    4 years ago
    I really like to try that but I'm little scared im getting really wet from that kind of stuff I can get electric shok?
    wyattwiczlorph
    Reply 3 years ago on Introduction
    Six months late here, but probably not. Although I know some people are into that kinda thing, imagine the issues some would have.
    Code Cardinal
    3 years ago
    You can nake the design A LOT SMALLER.
    You should make the energy transmission wireless.
    Make a coil, put it under the best sheets. Add square pulse generator to that that activates at wake up interval.
    Next make second coil and attach to underwear and directly to vibration module. When the first coil is activated the magnetic field will create a current in the secondary coil turning on the vibration.
    This allows you to take off the battery and all those silly shields which are too big to sleep on!
    Code CardinalCode Cardinal
    Reply 3 years ago
    And if you waterproof the vibration part (coil is not needed) then this underwear can go straight into the washer!
    Reply 3 years ago
    PS make two coils, one on the front and one on the back, this allows you to sleep in any position. Hook that up in parallel.
    mtattoohead
    3 years ago
    Humorous in that pubescent humor kind of way.
    jwingoKarloman
    Reply 4 years ago
    Yeah, did she adopt the GoodMorning Undies? Really curious! Love underwear!
    WildOne1985
    4 years ago on Introduction
    The introduction is very well written and it really made my day a lot brighter! :)
    GorillazMiko
    4 years ago
    This one takes the cake.
    Baccacuda
    I am new to instructables, however I like it enough that I look up activities to do with my children and sometimes we look together at the site. I think this should be in a adults only section , if one is not already available.
    icengBaccacuda
    Reply 4 years ago on Introduction
    This author is an incredibly artistic multidimensional literate HQ individual !
    I am not HQ... And have had an ible censored for enhanced and exposed breast skin with large tasteful pasties covering the normal Burning-man attire by what I believe was an arbitrary and unknowingly envious reaction by a puritanical female editor...
    Please ... Don't go immediately changing Laws where you move in,...... to the way they where you come from..... All that happens is you make it the same as where you came from..... Then when you will move again, .... But not until your actions defiled an old community that got happily along before your superior ways !
