Google Play Music Internet Radio (Raspberry Pi and Arduino)
134,862
689
29
I was looking for a project to do with my Raspberry Pi and found this Instructable and thought I would have a go at something similar which worked with Google Play Music. I had a rough idea of what I wanted the final item to end up like and was able to get my dad interested in helping me with the design and construction of the enclosure.
All code and CAD drawings can be found in the GitHub repo.
Before we begin I should probably point out that a reasonably good understanding of electronics and Linux makes this project a lot easier, especially since my Instructables are probably not the easiest to follow (I do try my best), however feel free to ask if something isn't clear enough.
A full parts list is a little difficult for a project this size so I'll highlight the important parts only:
  • Arduino IC (i.e. ATmega 328 with Arduino bootloader, you can but them blank and flash then yourself or pre flashed with a bootloader)
  • Raspberry Pi (512MB version if possible, because you know, more memory is better... but seriously I haven't tested with a 256MB version, but it should still work)
  • Digital potentiometers (logarithmic taper (we'll be using it to attenuate audio) & i2c (from the Pi), a DS1807 will do)
  • Amplifiers (I used pre-built modules but feel free to build your own if you feel up to it)
  • DC-DC converters (12v to 5v, 600mA output, isolated)
  • Rotary encoders (from font panel, cursor movement and volume)
  • An LCD (4 rows, 20 columns works for me, if you have songs with really long names maybe get a 40 column one)
As for tools, you just need all the standard electronics and woodworking tools, a few others which may be useful:
  • Bus Pirate (I don't actually have one, but they are very useful, alternatively you can do what I do and write Arduino scripts to make an Arduino act like a Pus Pirate to some degree)
  • Laser cutter/engraver (not essential, but makes production of mounting hardware and front panels SO much easier)
  • Router (for construction of enclosure)
  • Accurate callipers (essential for measuring sizes for panels and mounting hardware)
I think that is about it for specialist parts and tools, but of course I would highly recommend you read through the entire Instructable before starting work on this project.
Video demoing the finished radio:
I'm having problems embedding videos in my Instructables, here is a link to YouTube: http://www.youtube.com/watch?v=tgPbvo-8iRc
Step 1: User Interface Electronics
The order in which I went about this project seemed fairly logical and seemed to work for me, so I'll go with that.
In that case first up is the electronics which control communication between the radio and the user, in my radio the included 6 buttons, two rotary encoders which also have a switch for when they are pressed and a 4 row, 20 column backlit LCD, the majority of this is controlled using a ATmega 328p which interfaces with the Raspberry Pi using RS232 (over a level converter, since the Pi has a logic level of 3.3v and the Arduino is 5v), the one exception is the LCD backlight which is switched on and off using a GPIO pin from the Pi.
So here is an overview of what IO devices were actually connected to the Arduino, how they were connected and why:
  • Pins 0 and 1 connected to the Raspberry Pi GPO header through a MOSFET level converter, this was for the serial communication between the Pi and the Arduino.
  • The front panel button were connected to ADC pins 0 to 5 with either an external pull up or pull down resistor (whichever is easiest, in hindsight pull up would have been easier then I would only need ground on my front panel board).
  • The LCD is connected on digital pins 8 to 13, the actual pin assignment is not important at this stage as it can be configured in the Arduino script.
  • The encoder buttons are on pins 6 and 7, using the internal pull up resistor.
  • The encoders are on pins 3 and 5 and 2 and 4, it is important to have at least one interrupt pin per encoder, this will greatly improve the performance.
Most of this can be seen easily on the schematic which has all of these relevant sections annotated, note that this is the schematic for the main board only, so the actual devices are shown as pin headers, I will go over wiring the actual devices in the next step.
Step 2: Front Panel and LCD
Before starting this step it is a good idea to know roughly what size you want your radio to be, as this will limit the maximum size of your front button/encoder panel.
Once you know roughly what size you need to make your front panel you can design it however you like to match the style of enclosure you are planning, the only constraints are that the use the same Arduino code as me (at least without vast changes) it will need to use the same type and function of inputs.
My front panel was simply built on stripboard and bolted to an Acrylic panel which would later be mounted in the enclosure.
On the LCD module I soldered on a small breakout board which tool the 6 and 4 pin ribbon cables which came from the main board and connected them to the appropriate pins on the LCDs 16 pin header.
a 5v and ground wire was needed between the LCD breakout board and button/encoder board as the encoders needed a ground reference and the buttons needed a 5v reference in order to work properly.
Step 3: Arduino Script
If you kept most of the general circuit design similar to mine then there will be very few changes that have to be made to the script before uploading to the Arduino, although it is a good idea to have a look through this list to see if any apply to you:
  • You are using pull down resistors on the ADC
    Starting on line 174 you will see a lot of tests that look like this: analogRead(PLAY_ADC) <= ADC_TH
    Change this to >= and you should be fine.
  • Pin configuration
    You will almost certainly have to change some pin assignments, this is done from lines 26 to 60, all the pins are well labelled in the script.
You will also need some additional Arduino libraries before the script will compile, namely Streaming, CmdMessenger and Encoder. Once theese are in your libraries folder you should be good to go.
Once you have made all your changes, upload the script to the Arduino either by using an Arduino board to upload it or connecting a serial connection to the IC in circuit (I just used a Uno board, it is easier).
Here may be a good time to build the circuit so far on breadboard and test to ensure that everything is working as expected and you get the correct serial data when input devices are actuated and that the LCD responds correctly to serial commands. It is not essential that you do this here, if you prefer you can test the entire circuit before it is moved to the PCB.
Step 4: Audio Electronics
The next part of the electronics control the path of the audio signal between the output of the Raspberry Pi and the speakers, although I have not used them in my radio I also included headers on the PCB for a line out (for connection to an external amplifier) and headphone out (for headphones ;).
A summary of the audio signal path is as follows:
  1. Raspberry Pi output, close to an unattenuated signal, I used alsamixer to set the output to 0dB.
  2. Line out header, if used this would be a 5 pin 3.5mm jack which breaks the signal path if a plug is present in the socket.
  3. Digital potentiometers, these are used to attenuate the audio signal prior to amplification, controlled and powered by the Raspberry Pi over i2c.
  4. Headphone output, outputs attenuated audio output for use with headphones.
  5. Attenuation potentiometers, I added a footprint on the board for this but just bypassed it as it was not really needed.
  6. Amplifiers, 2 12W amplifier modules.
  7. Speakers, make noise :)
If you do not intend to use the line and headphone out then it is probably best to omit them from your design altogether.
My audio electronics are probably not the best designed, and I certainly did not use the best quality speakers (mainly due to size restrictions to fit them in the enclose I had designed) so feel free to improve this in any way you can.
Step 5: Other Electronics
Other electronics needed to make this work:
  • Amplifier and LCD Backlight power switching
    This was done from two GPIO pins on the Raspberry Pi (since I had maxed out the Arduino), all this involved was a MOSFET level converter switching an PNP transistor.
    In the case of the LCD backlight, this directly powered the LCD backlight LEDs through a potentiometer which could be used to set the brightness.
    To control the amplifier power a relay was used which was switched by the PNP transistor (with a protection diode).
  • Power conversion
    I was powering the radio with a single supply 12V PSU which could deliver 1.5A constant, this supplied enough power however I had to convert it to 5V for both the ATmega IC and Raspberry Pi, to do this I used two switchmode DC-DC isolated converters, one for the 5V power plane on the main board and one to power the Raspberry Pi.
    I used isolated converters as this removed a ground loop which caused problem with the audio circuit.
  • Power supply
    I added an additional board (not depicted on schematic) which included a 1000uF capacitor which helps to compensate for the rapid change in power demand when the amplifiers are powered up.
    This board also has a 20mm cartridge fuse holder fitted with a 1A fuse for the sake of protection.
Step 6: Main PCB
I had several problem when I was getting my PCBs produced (I did intend to have one for the front panel as well), as a result the current schematic in KiCAD has been altered to reflect some basic mistakes I made when designing the original circuit, therefore my original PCB design is no longer included in the KiCAD folder, however you should be able to export a new netlist and layout your own PCB if you wanted to have one made.
I did manage to use the PCB that was produced but it needed a bit of work to correct some errors that were made, some by me and some by KiCAD, but I should have noticed all of them regardless (moral of the story: always check gerber files before submitting them).
Therefore I will not go into too much detail about this, since my board will certainly be different to yours.
Step 7: Pi Setup and Python Script
To get everything working on the Pi takes a little work, but is not too difficult:
  1. First set up the Pi to suit your network, etc., setup SSH if you want (it is quite useful but not essential) and ensure the Pi boots to a desktop environment.
  2. Install required libraries for GStreamer.
    This can be done by running the following commands:
    "sudo apt-get update"
    "sudo apt-get upgrade"
    "sudo apt-get install libglib2.0-dev gstreamer0.10-alsa gstreamer0.10-tools libgstreamer0.10-dev libupnp-dev libxml2-dev gstreamer0.10-ffmpeg gstreamer0.10-plugins-base gstreamer0.10-plugins-good gstreamer0.10-fluendo-mp3 gstreamer0.10-pulseaudio pulseaudio"
  3. Install other libraries
    Following the setup instructions available on the project pages is probably best (if nothing else they will certainly be clearer than my instructions ;).
  4. Move your Python script to the default users home directory (most likely /home/pi/)
  5. Configure autostart
    I did this using a basic autostart entry in /home/pi/.config/autostart/, my entry was as follows:
    gpr.desktop
    [Desktop Entry]
    Encoding=UTF-8
    Type=Application
    Name=GooglePlayMuscClient
    Exec=lxterminal -e "python /home/pi/GooglePlayMusicClient.py"
The reason I used have the Pi boot to desktop and start it using LXterminal is to do with audio quality, I'm not sure if I was just missing something but unless the script ran in the foreground of the desktop environment there was a noticeable loss of audio quality during playback. If anyone has any ideas please let me know, as this left me confused for quite a while...
Step 8: Initial Test
Once you have your main PCB, front panel and Raspberry Pi setup connect an Ethernet cable and power it up, optionally buy preferably keeping a video cable in the Pi for debugging, you should get a message on the LCD saying that the Arduino has started and is waiting for the Pi (which will take considerably longer), after around a minute or so (this time mostly depends on the speed of your SD card, I have tried booting with a class 2 card and class 10 card, the class 10 card is around 30 seconds faster) the Pi should be in the desktop environment with an LXTerminal window open and the LCD should not say either "Logging in to Google Play..." or "Updating local lib. from Google Play...", updating the local copy of the library can take as much as 2 minutes for a large (~10,000 songs) library (at 1Mbps).
If you have any big problems then you will know my now, most of the problem I had were with a bad software setup in which case the Python script will never get this far, so any problems from now on (in my case at least) are more likely to be electronics problems.
If all is well so far you will soon see the home screen of the radio on the LCD, you can now use the cursor rotary encoder to scroll through your library and playlists, the next thing to do is try playing a song, there will be a small delay between pressing the encoder and the song start to play (this is to allow time for the amplifiers to power up) but the LCD should now say the name of the song, artist and album.
This is the other point at which I had most of my problems, after a lot of head scratching I found that the Ethernet controller IC on the Pi was losing power for a short time when the amplifiers powered up, this was because of a small error in my circuit design which has been fixed in the current schematic, however if you have a similar problem it is most likely a power supply issue, to be sure watch the status lights on the Pi, the 100M light going out for a second was what gave the problem away for me.
If all is good here then you can go on to test other functionality (such as Last.fm, amplifier power, further menu browsing) until you are satisfied that everything works, once you are it's time to start thinking about making a nice case to hide all of that ugly electronics (in my case anyway).
Here is a video of a really early test (back when this project was a mess of components on my desk at Uni):
Step 9: Enclosure Design and Construction
Again as with the electronics I won't be going in to a huge detail about how I made my enclosure, however if any part is unclear then let me know and I'll do my best to improve it.
From the start I had decided that I would have a 1930s/1940s style enclosure for this project, no other reason other than I like the design of them, and I suppose there is a certain appeal to mixing new and old styles.
I have to admit that I got quite a lot of help with the construction of the enclosure from my dad so I don't have a great deal of photos of it's construction, however I shall do my best to describe the process used to make it.
The arched section was made in two halves that join at the top, each half is 3 layers of 6mm flexible plywood laminated using a layer of PVA wood glue between each layer. Each of the halves was clamped in a jig to get the correct shape while the glue set.
The front and rear panels were cut from 6mm birch plywood and had the various holes cut (for the speakers, LCD, panels, etc.) using a CNC router, the holes for the mounting hardware were drilled as required.
The base is a two layers of 18mm plywood, one of which is the molded bottom layer and the second forms the step on whih the top section of the enclosure sites and is screwed into. The edge of the bottom later was molded using a hand router.
The front and back plywood as well as the bottom section of the enclosure were all sprayed with a clear lacquer which both protected the surface of the plywood and improved the colour of the birch. The arched section of the radio was sprayed matt black which gives a unique style to the radio and makes a nice effect using the grain of the plywood. (look familiar?)
Finally an aluminium mesh was applied to the rear of the speaker holes to hide the speakers and internal components, this was simple cut to match the contour of the arch and held in place using Araldite. In retrospect this was only partially successful, you could still see the speaker mounting bracket through the mesh.
Step 10: Mounting Hardware
Designing how each section of the electronics would be mounted in the enclosure was a little difficult with limited space and places where things could be mounted, partially due to limited space and limited cable length between components, but the end result did not turn out too badly (I just hope I never have to replace the fuse...).
All of the mounts mentioned here were laser cut, you can find the LibreCAD files in the GitHub repo.
The first (and easiest) item to mount was the two amplifier modules, these used an acrylic mounting plate to screw onto the sides of the enclosure (which are around 18mm thick so can have a small self tapping screw go into them with no problems) and could be mounted almost anywhere as I had relatively long ribbon cables to connect them to the main board.
Next in was the speaker mounting bracket (complete with speakers), this was a little tricky to get in as there was very little space to get in with a pair of pliers to tighten the nuts properly on the screws protruding from the front panel, since this section will be vibrated by the speaker during use it is a good idea to use nylon lock nuts or two locking nuts to prevent them from vibrating loose over time.
Next up was the front panel board mounted on an acrylic panel with the correct cut outs for the buttons and encoders, this acrylic panel would both to the inside of the enclosure, resulting in the controls being recessed into the front of the radio slightly (I explain this terribly, see the photo), the top edge of the acrylic panel also acts as a spacer for the LCD module...
Which is next to be mounted, this is mounted directly into a cut out just the right size for the actual module (the black part, not the PCB) the PCB is then spaced back from the plywood using the button panel acrylic on the bottom and a small acrylic spacer at the top, the PCB is then held in with four retention clips which are bolted to the front plywood (this is maybe a little bad practice, but it works).
Now I need to fit in the main PCB somewhere, to do this I used an acrylic bracket to mount it to the side of the enclosure (originally planed to mount it on the base of the enclosure, but several ribbon cables would not reach it there), I was now able to connect the cables between the main board and the front components, amplifiers and speakers.
The next parts start to get a little tricky as it involves trying to connect cables to the Pi whilst holding to top section of the enclosure, next I mounted the Pi on the base of the enclosure which lined up with the cut out on the rear plywood, having done this I then had to connect the USB power connector, audio output and GPIO cable.
Finally, I mounted the power board to the base of the enclosure under the main board bracket (making fuse replacement a pain, but there was no other good place for it) and connected the rear power panel (which is held into the rear plywood with Araldite), the top and base sections of the enclosure could now be joined, making sure not to damage the questionably positioned USB header on the Pi, and finally connect power in from the power board to the main board.
Step 11: Final Assembly and Test
I finished off the enclosure with some black Japanned screws on the side of the enclosure to hold the two sections together (they went well with the black paint), some nice polished aluminium knobs for the rotary encoders and a back panel to cover the access door (to do this I had to glue a section of MDF on the inside of the enclosure to stop the cover from falling in) which was held in using some acrylic brackets screwed onto the back of the radio.
You may also notice I did not label the front panel controls, I did plan to laser engrave the button caps and knobs (originally planned to be hardwood), then the plan changed to laser engraving the panel, but from past experience it looks so much better now than it would if I had done this. Furthermore a lot of the controls are very intuitive; next track button is right of play, pressing the cursor encoder selects, back is the closest button to cursor encoder, pressing volume encoder mutes, red button is for Last.fm love, etc.
And now if you connect an Ethernet cable and 12V power then turn the power switch on you should still be greeted by the "Waiting for Pi..." message and in a minute or so should see your music library.
Find a good song and enjoy it, that's what I did next.
But back to testing, I played quite a varied selection of music to get an idea of what the sound quality is like and was quite surprised how good it is for most songs, if anything mid frequencies are a bit weak and bass is a bit strong (surprising given the type of speakers I use). I also found that above volume 40 you can hear a little hiss when playing a quiet song, which I can live with, it is not anything as loud as the music is at this volume it's just when there is a song with large changes in volume that you notice it during a quiet part.
As for software performance, every thing works, it could certainly work better though. There are a few optimisations I can think of which would make the radio a lot faster, mainly during boot (keeping on offline cache of the library dictionaries is what I'm thinking), but this will do for now, even on my slow connection now I am listen to my radio, writing this Instructable, downloading photos to add to and hosting a Minecraft server, so the main problem is mainly the long boot time.
Step 12: Review and Future Improvements
Overall I am very happy with this radio, I will certainly be using this a lot (probably daily) since the sound quality is much better than my phone or tablet and it is easier than having to use external speakers or using a PC for music.
Some things that I could work on to make this even better:
  • The local caching I talked about in the last step
  • Improving audio quality
    This would be done with better designed audio electronics and by fixing the PulseAudio bug on my Pi (I did plan on updating the firmware to fix this but never got round to it)
  • Add play mode and repeat options (EDIT: I added this in a new version of the code)
    It would be good to have the linear/random and repetition options that I put into the PlayMusicCL project that spawned form the Python script behind this radio.
  • There is scope to make my main board a lot tidier, but that is somewhat understandable, not many people make a PCB perfect first time.
  • Network/IR control
    I toyed with the idea of controlling the radio with an IR remote before, but the same could be done over a network connection, half of me thinks "What's the point?" and the other half thinks "Why not?".
  • Solving the character problem
    I can't really think of any way around this, essentially if I browse to music with a name not supported by the LCD (not in it's character set/font generator) I get a number of question marks, this was done purposely so that at least something was displayed on the LCD.
    The only easy way (which is not really that easy, as it would need a lot of changes) is to use a graphic LCD rather than a standard text one.
I would also like it if I could import auto playlists but the API does not support this right now (although it did when I started working on this project), All Access does not work with this API either, but I'm in the UK so I'm not too bothered about that.
EDIT: this has also been fixed, turns out the API stopped providing auto playlists and it was the client's job to generate them.
Father's Day Contest
First Prize in the
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    29 Discussions
    mhanders
    4 years ago on Introduction
    I like your work and the quality of the end product, do you think it would be possible to make one similar with a headphone jack, and do you think hooking it to a youtube playlist with only audio being played would be possible?
    DanNixonmhanders
    Reply 4 years ago on Introduction
    Can't see why that wouldn't work, the software would be quite different though.
    navi97
    4 years ago on Step 3
    Please help
    I can not translate in English
    who sent me an Arduino / Raspberry Pi Internet Radio on sd card
    Raspberry Pi
    Arduino UNO
    16X2 LCD display
    reply to navi2@seznam.cz
    What would be the price through pay pal
    thank you
    jlyons13
    Got a Pi a few months ago but not had the time to do anything with it. Great job. I have an old tube radio (Motorola). Still works, but I may just pull out the innards and mount the Pi inside. I was thinking about keeping the tube part, but the heat from the tube may degrade the Pi over time. This is my summer project! Thanks for your cool radio!
    DanNixon
    5 years ago on Introduction
    I know exactly the type you mean.
    If you could deal without the graphic display then I see no reason not to use such an enclosure, in fact I did consider doing this after a saw an old radio in a store window which apparently had faulty electronics.
    dwilkinson3
    5 years ago
    This is very cool... I'm an apprentice cabinet maker and can see that you have excellent skill levels with woodworking. Might have to try this out, I'm just getting into electronics but if and when I do I will make sure to share my version with you! Cheers
    DanNixondwilkinson3
    Reply 5 years ago on Introduction
    Thanks, although I have to give credit to my dad for the enclosure since he did a lot of the work on the construction and finish, I mainly just did the mounting mechanisms for the electronics as far as the case is concerned.
    lectroluke
    Good project, Dan. I hope to find time to make a copy using a more compact and modern cabinet and IR only front panel controls.
    DanNixonlectroluke
    Thanks.
    Yeah I would have liked to have IR controls on mine, half the problem was time, but I also couldn't find a suitable remote (or at least one I would be happy with), I was planning on using my Roku remote which would be perfect (since I could map app the buttons to a function that is depicted well by the button label) if there was volume controls on it.
    I would be interested to see other case ideas, I quite like the design I went with but a smaller compact one would be pretty good. I also thought about having one in a Hi-Fi separate (the systems with the separate tuner, amplifier, tape deck, CD player, etc) case, it would be a nice modern addition to a separate system (if I had one).
    w1ll1am23
    5 years ago on Step 12
    Dude this thing looks awesome. One day if I have all the wood working tools to do this I will. Good job.
    DanNixonw1ll1am23
    Thanks.
    Also you don't really need a lot of tools to do this, mainly just a hand router with a basic set of bits should do, and some way of making templates for it (laser cutting them out of MDF is my preferred method).
    I do try and keep my use of CNC machines down (or at least make it doable by hand) but router templates are something that probably needs the accuracy of a laser cutter to make.
    aecl755
    I think Google stole your idea: google.com/chromecast :p
    Great work, though! Looks real nice too.
    Build_it_Bob
    Very nicely done ! the use of Pi with Arduino is also a good way to introduce Pi to us Arduinians who are unsure if we want to take the leap yet.
    The cabinet is AWESOME ! I love antique radio ...and cathedral radios especially . You both worked to make an amazing project together ...I hope you are both proud of the end result !
    Build_it_Bob
    DanNixonBuild_it_Bob
    Reply 5 years ago on Step 12
    Thanks a lot.
    It's comments like this that make me want to continue making Instructables.
    ssamc
    Great work. Congrats, very professional look.
    It lacks some source code in this instructable
