Gradients in Microsoft Paint
194,112
17
48
How to create simple color gradients in MS Paint.
Step 1: Open Paint
Open paint. It is located under "Programs" and then "Accessories". After you have Paint open, press Ctrl+E. This will open the Attributes window (Attributes can be found under 'Image' too). Set width to 100, and height to 500. (Height can be any number, but 500 works well.) Make sure 'Pixels' and 'Colors' is checked and click OK.
Step 2: Draw the Line
Your screen should now look like it does in picture 1. Now, select two colors you want to blend. Using the first color that you chose, use the line tool to draw a diagonal line connecting two corners, as in picture 2.
Step 3: Fill & Shrink
Using the bucket tool, fill the top half of the page with the line color and the bottom half with the other color you chose. Now, press Ctrl+W. This opens the Stretch and Skew window (this can also be found under 'Image'). Enter 1% into the horizontal stretch area. Click OK.
Step 4: Stretch It Out Again
Your screen should now look like picture 1. To stretch it out, again open the Stretch and Skew window. This time, enter 500% into the horizontal stretch area (500 is the max amount allowed). Click OK. Do this two or three more times, until your gradient is wide enough to be admired.
Step 5: Wavy Gradients
This step is a bonus trick I just learned. First, get your gradient to be relatively skinny. Then, use the corner dot to drag your page size so most of your screen is white. Make sure your secondary color white before you do this. Then, select your gradient using the rectangle select tool, and click transparency. Then, while holding the shift key, drag your gradient in any way you want, such as a wavy line. Lastly, use the fill bucket to fill in the white space around the edges. Voila!
8 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Party Challenge
    Party Challenge
48 Discussions
Natgeo564
1 year ago
How do I do gradients in windows 10? This is the image I'm trying to add it to... Sorry if can't see
kennedy_sienko
2 years ago
Ugh! When I tried it this happened!
kmarie16
6 years ago on Step 4
I have windows 7 and and mine does re size and skew not sketch and skew! so it does not work.
AngelFirePonekmarie16
Reply 3 years ago
This'll help you out -->
XD it actually is possible, I did it quite a few times on my own. I also use windows 7 :P
I got that first to, but when I realized that paint automatically checks 'maintain aspect ratio', so uncheck that and change it, done, the gradient is made
artworker
6 years ago on Introduction
Sooooo coool! This trick is so very out of this world. Please tell us how you found this trick. I would love to know the story behind this.
Icalasari
8 years ago on Introduction
Still annoys me that they removed this feature
They actually made their program have FEWER features >.>
Aye Pod
9 years ago on Step 5
dude NICE this is a really good guide
