Grand Daisy Tatted Lace Choker
19,990
210
14
About: I'm a tattooed needle tatter, a stay at home mom and a homeschooler. I sell my work on etsy. I hope to offer a few patterns more here as I get the time. You can also follow me on twitter as TotusMel and read...
One of a collection of tatted choker patterns I designed based on a daisy motif, this is a simple choker necklace made with smaller motifs tatted together and long chains added to complete the look.
Step 1: What You'll Need
You will need:
-Size 10 cotton thread in your choice of colors, I used black.
-Size 5 tatting needle or shuttle if you prefer
-Scissors
-Small steel crochet hook for joins (optional)
-Clasp and split rings
You will also need basic tatting knowledge that can be acquired with my other beginning instructables.
Step 2: Center Daisy Motif - Center
Start the motif with a ring, the pattern is 2 double stitches(ds) 1
picot(p) 2ds 1p 2ds 1p 2ds 1p 2ds 1p 2ds 1p 2ds 1p 2ds 1p 2ds 1p 2ds 1p 2ds close and make a mock picot*. This will leave you with a ring of 10 picots separated by 2ds
*A mock picot is simply a picot made by double tying the ends of the thread to make a loop the same size as the other picots.
The petals of the flower are all chains joined by putting the thread through the picots of the every other picot in the center ring.
Chains(ch) are 5ds 1p 4ds 1 long picot(lp) 1ds join
Repeat around, last chain is 5ds 1p 5ds join to beginning p and make a long mock picot to match the length of the lp's
Step 3: Center Daisy Motif - Second Round
Start Second round at the long mock picot
Ch 5ds 1p 5ds join to picot in chain of last round
Ch 5ds 1p 5ds join to long picot
Continue around and join final chain to the beginning mock picot
Tie, cut and hide ends.
Step 4: Side Daisy Motifs
Side daisies are begun in the same manner as the the center daisy except that the center ring is 12 picots separated by 2ds
Chains are 5ds 1p 5ds joined to every other picot on the center ring.
Join the motif to the center motif as shown by two petals. Each subsequent motif will be joined as shown by the two side petals. Make a total of 6 small motifs on each side of the center motif.
There should be two petals between the side motifs on the top of the center motif and four between at the bottom. See final photo for placement.
Step 5: Chains - 1st Round
R 6ds join to bottom picot of third small motif from center 6ds close(cl) reverse work(rw)
Ch 20ds cl rw
R 6ds join to bottom picot of second small motif from center 6ds cl rw
Ch 20ds cl rw
R 6ds join to bottom picot of first small motif from center 6ds cl rw
Ch 20ds cl rw
R 6ds join to side bottom picot of center motif as shown 6ds cl
Repeat this chain design on other side.
Step 6: Chains - Last Round
Join thread where shown at the base of the ring joined to the first small motif to the side of the center motif.
Ch 40ds cl rw
R 8 ds join to the second bottom picot of the center motif 8ds cl rw
Ch 8ds cl do not reverse work
R 8ds 1p 1ds 1p 1ds 1lp 1ds 1p 1ds 1p 8ds close do not reverse work ( total of 5 picots in center of ring)
Ch 8ds cl rw
R 8ds join to the next bottom picot of the center motif 8ds cl rw
Ch 40 join to ring opposite of the starting point
Step 7: Finishing
With my tension and size 10 thread the total length of the necklace should be around 14 inches, each small motif is approximately 1 inch, so you can adjust the length by adding or subtracting daisies.
Add clasps to the end motifs using jump rings to join to the picots of last motifs. I used an adjustable pewter clasp, but you can use whatever kind of clasp you like.
You can also all beads to any or all the picots for a different look.
You may press the necklace with steam on a towel to get a better shape.
It can also be hand washed, rolled in a towel to remove excess water and laid flat to dry followed by pressing.
This choker necklace is also for sale in my etsy shop.
The laws of Copyright Protection permit this tutorial to be used for personal use only. Reselling finished items for profit is prohibited.
Necklace Challenge
Runner Up in the
Necklace Challenge
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    14 Discussions
    barbkala
    2 years ago
    Sorry for what may be a dumb question, but I am a beginner and need some clarification. Are all the centers of the smaller daisies made separately and than joined on the 2nd round? It looks as if they each have to be tied and ends hidden before a second one can be ended. Also in the past videos I have watched, after a chain in made you usually RW and tie. A join has been on the left. These joins are made on the right and than tied?
    TotusMelbarbkala
    Reply 2 years ago
    You can tie off the centers or you can make the last picot a mock picot by tying the threads together at the same length as the other picots and then continue the next round from there, which is what I do.
    I'm not quite sure what you're referring to as joins on the left or right, but as far as these chains are concerned, you tie without reversing and continue working around the daisy in the same direction.
    barbkala
    2 years ago
    How much thread should I allow as a tail? love, love love this pattern
    TotusMelbarbkala
    Reply 2 years ago
    Thank you! I've never measured the length of my tails, I usually just play it by ear. Since the piece is made from smaller motifs you shouldn't need much for each section, maybe start with a foot for a daisy and then adjust to the right amount for the next one. You'll need a bit longer for the 'chain' portions, just guesstimate about how long they'll need to be and that should get you there.
    Sorry I couldn't give a clearer answer.
    barbkalaTotusMel
    Reply 2 years ago
    Thanks so much for the quick response. I am going to try this choker as my first written instruction needle tatting project. So far have just been making things from youtube. Most of the projects there were for beginners, and although I am a beginner I want to know so much more, especially how to read instructions for more complex projects and also how to make patterns smaller or larger without disrubting the proportions. So much to learn, but so much fun. I love all your projects and will attempt them all. Thanks again
    PeggyM21
    3 years ago
    thank you for all of your amazingly understandable directions and the beautiful designs that you share! I'm a lefty and tried for months to learn needle tatting. I eventually gave up and started crocheting again until I stumbled across your tutorials. I have learned needle tatting right handed and I'm addicted to your tutorials! Girl you rock at this and you share and teach others to make beautiful treasures as well, I can't praise you enough! Oh and because of you, I was able to teach my 5 year old daughter the Josephine chain and she is making bracelets for everyone using all my thread lol. And her 10 year old brother decided he had to learn too so now they argue over who gets my 3 gauge needle first instead of video games! I love to see these types of hand crafts passed down to the next generation, so I'll be getting another set of needles today as an after school surprise for my little ones. Thank you so much!
    ChristinaV7
    3 years ago
    I have a question. On Step 2, on this part:
    I'm wondering if I should be tying off the ends of each chain after the join? I'm used to tying off after ending every chain and ring, but I'm not sure in this case, as it's not explicitly stated... thank you for any clarification! :)
    TotusMelChristinaV7
    Reply 3 years ago
    Yes, I tie every time I join a chain to a picot.
    ChristinaV7TotusMel
    Reply 3 years ago
    Great, thank you for the quick reply! And for posting this beautiful pattern! :)
    msiena1
    4 years ago
    Very talented work thanks for sharing
    xie
    4 years ago on Introduction
    I'm really excited to try making this pattern! :D
    the_anykey
    Very sexy :-) Nice work ! Now I just need to convince the GF to make and wear one :-)
