Guard Dog Burglar Alarm!
38,632
86
44
About: Tinkerer, hackster and prankster. Hit me up on Facebook: https://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
Turn your doorbell into a vicious guard dog alarm! Watch the video then buiild your own and protect your home and family.
Step 1: What You Need
Step 2: Build the Circuit
Following the schematic, make the connections between the rectifier, diode and relay. You will need to bench test your relay to determine the input and output connections as well as the )+) and (-) connections on the rectifier.
You will end up with 4 open wires. Two coming from the relay and 2 coming from the rectifier.
NOTE: My doorbell circuit generated 18V from the transformer with 13.5 volts AC at the doorbell ringer. Your doorbell voltages may be different and the circuit may have to be designed specifically for your voltages.
Step 3: Finish the Connections
Remove the playback button on the recording module by bending back the two tabs on the back.
Solder the two connections coming from the rectifier to the playback contacts.
Pick the audio cable of your choosing (I used a mini female connector on a length of wire with bare leads) and solder the two connections to the speaker terminals on the recording module. This will allow you to directly input audio to the recording module.
Step 4: Load Your Sound Effect
Run the sound effect of your choice and press the recording module button to record the sound to the module. I used this one and edited it a bit.
Step 5: Make the Final Connections
Plug an audio cable into the cable your soldered to the recording module. This is also the output as well as the input. Connect it to the Wireless Transmitter. Connect the two wires from the relay to your two contacts on your doorbell. Connect the output of the Wireless Receiver to your stereo system. Connect a 9 V battery to the recording module and your Guard Dog Burglar Alarm is finished!
When the doorbell is pressed, the recording module will playback the sound effect and send it to your stereo system. You can adjust the audio by walking outside to see what sounds best.
I hope you enjoyed this Instructable!
Step 6: What You Need
    • Remix Contest
      Remix Contest
    • Sweet Treats Challenge
    • Organization Contest
    44 Discussions
    SteveA4
    4 years ago on Introduction
    This is a great project. Two issues that I picked up, maybe you can help to correct this. The first issue is that the two leads from the rectifier first showed being connected to the doorbell, and then shown somewhere else as being connected to the recording device. So, which one is right? I vote the doorbell leads go to the 12V relay and not to the playback device.
    Also, where does the 2.4 GHz Audio/Video transmitter connects? I would have thought at the playback connector , but does that mean these leads at T'd into the two rectifier leads?
    With these two clarifications, this is a simple yet effective device.
    Thanks
    Steve
    great idea; indeed no need even a microcontroller. However it works only if bell is pressed. one can try adding a PIR sensor which triggers the recorder if anyone comes close to door..of course home owners won't be worried about it and they can turn it off after they enter the place. great work Mr.Kipkay..please keep posting
    cjs1298
    5 years ago on Introduction
    My friend doesn't even own a gun, but he just puts an NRA sticker on his door.
    jrigvd
    6 years ago on Step 2
    Key Kip, The schematic is ok in the instructable but wrong in your video on youtube! Cheers!
    sk8r4life
    9 years ago on Introduction
    few things 1. where did you get the audio receiver and transmitter and how much? 2. would a burglar really ring a door bell?
    georionsk8r4life
    Reply 6 years ago on Introduction
    yes and no--its a check to see IF someone might be home--we dont like surprises,niether do burglurs
    Kipkaysk8r4life
    Links on the Instructable for all of the parts. This is a common practice to impersonate a survey taker, sales person, etc...ring the doorbel. If no one answers maybe check the house out.
    Default117Kipkay
    I'm sure you would know, after all, you did open that window in no time flat ;P
    ElvenChild
    8 years ago on Introduction
    but a smart burglar would hear the audio repeating in a loop and think that is one weird dog!
    ARJOON
    however you need to let your pc on. it will eat up too much electricity.hell yeah i know kipkay. he is just an animator, not smart at all
    Kasm279ARJOON
    The only thing you would use the PC for is to record to the recording module. Other than that it has nothing to do with the operation.
    cupnoodles2
    hello! , would that circuit work like to power a relay so that i can turn a motor while the doorbell button is pressed? im trying to make a sistem to open my door as i press the doorbell button for my room thanks.
    DJ Radio
    Hey kipkay, You might want to reject all of your patches, they make your orangeboard not work.
    Squid Tamer
    Neighbors who visit often will start to wonder why they've never actually seen the dog! (Could end in people looking around and under furniture when they think you're not looking, or in a call from PETA about confining animals! ;) )
