Guitar Hero World Tour Cymbal Fix
88,466
6
35
I had heard many reports of the drum sets that came with world tour being defective. One guy I know can't get long streaks because the drum set just wasn't of high enough quality. When I set up my drum set it worked great! I was relieved. It seemed the build quality had improved. Not so fast.... Within a few days of some serious rocking out the yellow cymbal failed altogether. I was livid. I knew the stores wouldn't take it back, and it would be weeks to get it shipped and fixed, at a cost. So I did what I do best... I voided the warranty.
I figured the cymbal was a pretty simple piezoelectric device, and anything wrong with it was an easy fix for a geek and his soldering iron. So I set to work. My cymbal was totally non-functional, and broken is a certain way, your mileage may vary.
Step 1: Acquire Testing Ability.
Credit goes to this other instructable on drum set repair for the idea of using the mii freestyle as a test bed. You should start this up and leave it running. Whenever you need to test the cymbal, just plug it in, and see if it works. Very productive!
Step 2: Open Up the Cymbal and Inspect.
There are likely several ways the cymbal can be "broken". This is why the inspection step is necessary. Mine was broken is a specific way. Likely a common way though.
Remove the four screws holding the back of the cymbal on. It's just four small Philips screw, nothing special. Go slow, the screws are going into plastic, and you'll need good threads later to put it back together.
I opened up both my cymbals and compared them. The yellow cymbal clearly had very poor workmanship when compared to the orange cymbal. However, there were no obvious flaws. The solder joints to the piezoelectric looked sound, the circuit board is dead simple, no components at all. Just connects the piezoelectric element to a mini-audio ( mono ) plug.
If you find anything blatantly broken, wire pulled out, plug on board loose... fix that and give the cymbal a test run. If not, move onto the next step.
Step 3: Ensure Functional Piezoelectric Element.
The most complex, but thankfully the toughest part of the cymbal is the piezoelectric. Lets make sure this most important part is functional.
You will find white silicon covering the connections to the piezoelectric element. This must be removed. My finger nail worked fine. I'm sure a small tool would work fine too, just take care not to damage anything.
Get two lengths of wire, thin stranded wire will be fine. I have bags of the stuff. Strip a half inch on both ends of both wires. Solder an end of each wire to the solder pads where the other wires are connected to on the piezoelectric. ( You likely won't be able to solder else where on the piezoelectric, it won't stick. ) I needed pretty high temps on my iron to do this. I will refer to "your" red wire as the wire you soldered to the pad that has the original red wire, and "your" black wire as the other wire.
Now you should have two wires connected to each terminal of the piezoelectric. Using some tape, connect your black wire to the base of the cymbal plug on the drum kit. Then connect your red wire to the tip. Again, just use tape, and put some pressure on it.
Make sure mii freestyle is running as in step 1. Now while everything is connected tap on the piezoelectric with your finger. If you register hits. If not, play around with the taped connection a bit ( It can be finicky. ) This should work... The piezoelectric elements are pretty much indestructible. If you can't get it to work, test for shorts with a multi-meter... Once you have this working, proceed to the next step.
Step 4: Attach Wires to Internal Mini Plug.
Now we know the wires we connected talk correctly from the piezoelectric to the drum set. Now we'll connect those wires to the internal mini-plug at the closest solder pads possible. This eliminates several possible points of failure along the transmission of the signal. In my case, this fixed the cymbal. I'm guessing it will fix many other cymbals that are non-functional as well.
Attached the wires as shown in the image to the solder points on the circuit board. ( For the orange cymbal it will be a mirror image. ) One of the points of failure may be the solder joint from the circuit board to the mini-plug. Because of this, make sure to melt the solder point completely as you attach the wires. This will re-flow the solder and make a good connection.
Now test out your handy work by plugging the cymbal in and tapping on things. If it registers.. Congratulations! you have fixed your cymbal.
Step 5: Reassemble
Now you should be able to put the cover back on. Be careful not to bend your new wires around too much or you might break something. Feel free to use tape to keep things in place. Carefully and slowly screw the four screws back into the symbol back. Remember, these screws are just going into plastic. So as soon as you feel a bit of resistance, the screw is all the way in. You aren't working on a car here.
If you have any questions. Feel free to message me.
    • Woodworking Contest
      Woodworking Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Leather Challenge
      Leather Challenge
    35 Discussions
    Amoffa
    8 years ago on Introduction
    It Works it works it works. My yellow cymbal did not register any hits, was dead, did not work at all. I tried this fix and it works like a dream. I was shocked how well it responded. Thanks so much!
    moschme
    8 years ago on Step 4
     Hej SpinozaQ,
    Thanks a lot for this guide - It worked perfect for me!
    Cheers
    Moschme
    websherpa
    9 years ago on Step 3
    Same issue here and this instructable was very helpful in pointing me in the right direction (gotta love the Internet), though my fix was rather more simple since I used a continuity meter to test for continuity between the piezo and the female socket.
    There is a very, very small amount of copper connecting the black ground plate to the female socket's pin. mine had a hairline crack which is probably a stress crack that widened and opened the cuircuit  very shortly after we started playing the cymbal.  I would consider this an engineering defect, the PCB was etched with too narrow a connection here at a high stress point.  In any case I just scratched off some of the green resist from the PCB and used a bit of copper braid wire to create a "stitch" between the pin and the board (on the side opposite the hairline crack).  Even a solder bridge (extra solder bridging the gap) would work for some time.
    sperna
    9 years ago on Step 5
    My yellow cymbal wasn't working. If I switched them the orange one didn't work when plugged in to where the yellow one was. So I took it all apart to look for bad solder joints, broken wires, etc. Instead it ended up being the 90 jack where the yellow cymbal gets plugged in. Strange... it's a molded plug but it was bad. I replaced it with a 1/8" mono plug from Radio Shack and it works great again!
    kussfamily
    9 years ago on Introduction
    both my cymbals don't work. I inspected wires/piezo/jack and everything is fine. Is there somewhere else that could be causing the problem?
    ingba
    i think i have the same problem as aleettzz. my left cymbal does not any connection to the drum kit at all. even if i switch the yellow n orange cymbals, the cymbal on the left does not register any hits while the one on the right works fine. so there isnt a problem with the individual cymbals but possibly the wiring or some processing chip inside. any suggestions how to solve this? im not really good with my hands so the easier the solution will be much appreciated.
    SpinozaQingba
    You are correct. Your problem is most likely inside the drum kit itself. This instructable does not cover the insides of the drum kit. If you are not "good with your hands" you're probably not going to be able to fix it yourself.
    Raven3000
    I found this awhile back and I really didn't think soldering new wires would ever work. However, I got really fed up about two days ago with how my cymbals were not registering hits (brute force needed on one, the other would never be consistent to how I was drumming). After soldering BOTH cymbals, they work absolutely perfect, I had to turn the sensitivity down on both. The cymbal I had to use brute force on and maxed on sensitivity (20), was turned into a cymbal where I could now lightly tap it and have it set on the lowest setting (1).
    I named my cymbals too! Ultra Rigged 3000 A & B
    SpinozaQRaven3000
    Ha. I haven't read these comments in a while. I'm so happy other people found the instructable helpful. I'm not sure why this fix is so good. There are some theories though... ( I should get a decent oscilloscope and verify them. ) One theory is just using better wires and connecting them "closer" to the output, rather then allowing them to go through the circuit board helps a bit. The other is that if both sets of wires work once everything is re-soldered you'd actually get two signals going to the output. I'm not sure how the drum kit is designed, but if the plugs are capacitively coupled like most audio equipment, that could boost the signal it "sees" quite a bit.
    CraimerX
    My cymbal is cracked and it won't regeister well as the cymbal is struck. How do I fix that?
    wantie002
    I'd love to know how I can fix a new connector jack to the wire that emerges from the left hand (yellow cymbol support). The jack became disconnected and them my son stripped the whole thing down so not much to do except find a way of reconnecting a new jack. Would it be possible to buy an already wired jack and then dismantle it at the other end to see how it is connected inside the support?
    mikemaul1
    The appears to be bad cables in the drum kits for the yellow cymbals. The audio jack fails and then the cymbal will never work. I fixed this by purchasing a mono audio cable from Radioshack, part number 42-24220A, cut off one head, cut off the old head on the drums and solder the ner head to the cable. This cost $4 and some time but it worked.I purchased one with a head on both ends so I could replace both cymbals if the other fails in the future
    xxjosh
    10 years ago on Step 5
    I tryed what you said to do and it has not worked for me. Have you got any more tips on what to do. Also i have uploaded this images could you tell me iff ihave done this right ?
    Raven3000xxjosh
    The black cord is in the wrong position. Put it next to the white one.. Here is a picture of mine so you get an idea.
    cowboyebfd
    10 years ago on Introduction
    the wires from my cymbals are rip out from the device that plugs in the back of the cymbals where you can unplugs and plug back in. Is there any way i can fix that or what can i do?
    easyeee
    10 years ago on Step 3
    Easiest way around the whole, "broken/snapped wires at jack input" =
    Situation
    U don't have a spare Male 1/8th jack.
    U know how to solder, got the gear.
    Butchered the old Male jack or other.
    Can't be bothered stuffing about.
    Want a somewhat permanent fix.
    Simply use some wire (e.g vehicle speaker wire) to lengthen existing snapped wires. maybe another 50-100mm or more. measure twice, cut once.
    Remove underside rubber protector from offending cymbal.
    Neatly cut speaker wire to length. Both ends.
    Cut Cymbal side as close as possible to jack.
    Strip back maybe 10mm or more.
    Speaker wire same as above.
    Use Earth, black line along speaker cable, for Earth connection.
    Positive for Positive.
    Solder speaker wire ends directly onto Chip.
    There are 3 solder points for this operation.
    Very bottom is earth.
    Top left is power
    third is connection unused in situation I bypassed(buggered jack point)
    eg; of solder point orientation.
    Power Connection
    1 1
    Earth
    2 Internal wire from Drum-kit end is Power
    3 External wire is Earth.
    Before soldering test correct orientation of wires using MII play.
    If incorrect fix it....
    Solder the correct ends together. Problem solved.
    Put it all back together.
    There are some basic steps not included like splicing wires together etc, if u can't do the basic I think u maybe in the wrong place
    either that or I am.
    Cheers
    maryberno58
    Did you find a solution to your problem? I think I have the same one. The wires cam out of the plug that plugs into the back of the cymbal. Just the wires are hanging out of the cord. What can I do?
    Bozie
    the spot where i plug the cord is broken. in the little small hole for the plug under the wires came off accidently while i pulled on the cord. Do you have instructions on how to put back the small tube thingy under the wires?
    aleettzz
    i need helppp!!!!!! with thisss guys i got these problem .My drums doesnt have the sensivility problem the right cymbal doesent work but i isnt the cymbal it is inside the drums kit or it can bee to the plug, because i change the cymbals and stils that side of the base of the cymbal that doesnt work
