Guitar String Ring
20,794
426
24
About: Musician, photography hobbyist, calligrapher, and former electrician. I also like to taste exotic and interesting beers on occasion. Life is too short to drink light beer.
Here's a fun use for guitar strings, aside from making music. I made my own wedding ring from a guitar string, but this was not my first attempt. I used several different sizes of guitar strings and tried a few different types of weaves until I finally settled on what I thought looked and felt best. I hope you can enjoy making your own.
Supplies:
Step 1: Items Needed
Materials needed:
  1. Guitar string, nickel wound type, typically used on electric guitar. I found that .024 or .026 sizes worked best for this type of knot.
  2. A rod, pipe, dowel close to the size you want to fit your finger. With my fat fingers being a size 12.5, I found a piece of 1/2 schedule 40 PVC pipe worked well.
  3. Masking tape, electrical tape, wire, rubber bands, or something to secure the starting end of your string to your dowel.
  4. Cyanoacrylate glue (super glue, Krazy glue)
  5. Needle and heavy thread.
Tools needed:
  1. Wire cutter, I prefer small diagonal cutter.
  2. Knife, scissors, or anything you can find to cut thread.
Optional items:
  1. Adult beverage
Items NOT needed:
  1. Lasers
  2. Arduino
  3. 3D printer
  4. CNC machine
Step 2: Getting Started
The first thing I did was to learn to tie a Spanish ring knot, which is the basis for my guitar string ring. There are a few VERY good tutorials on this subject, so I felt it best to show those tutorials rather than to attempt to explain it myself.
A pictorial version can be found here: http://www.paracordguild.com/tie-spanish-ring-knot-2-passes/
I recommend practicing tying this knot with paracord or something larger than guitar string to familiarize yourself with how this knot works.
Step 3: Start Weaving Guitar String
First you will need to secure the starting end of your string to your dowel. You can use tape, rubber bands, or in my case, I used a piece of wire threaded through the little retainer on one end of the string and a hole drilled in my pipe.
Follow the published tutorials until you have reached the first 3 wraps, resulting in a Turk's Head knot. Here is where you need to carefully tighten up your knot. Be very careful not to kink the wire. After the next two times around in the tutorial, your Spanish Ring knot will be complete... sort of. Once you are to this point, You will probably find it much easier to complete the rest by removing the ring from the dowel.
Now simply follow your original path keeping the string side-by-side to make a doubled Spanish Ring Knot.
Step 4: Finishing Your Ring
Clip both ends of your wire inside the ring so they overlap a little. Use a needle and thread to wrap all 3 wires (beginning wire, 2nd wrap, and ending wire) tightly. Use cyanoacrylate glue to secure the thread and let it dry.
Cut your threads close and wear proudly.
I hope you've enjoyed my very first instructable.
2 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Party Challenge
    Party Challenge
24 Discussions
theTobster5001999
1 year ago
hey, what do you use to keep the string from turning green? that's the only problem i had with it, the ring itself is great
MartyK1theTobster5001999
Reply 1 year ago
I used nickel wound electric guitar strings which have given me no green. Many acoustic strings are bronze, and definitely will turn your finger green. I suppose if you like the bronze strings, maybe a coat or two of clear lacquer might help, but not sure how that would hold up against your skin, or how well it would stick to the strings. If you try that, let me know how that works.
I do notice even the nickel strings tend to accumulate dirt over time, so I throw mine in an ultrasonic cleaner with a bit of window cleaner to clean it up every now and then.
theTobster5001999MartyK1
Reply 1 year ago
thank you for the very quick response! i think i'll try electric guitar strings then. if i do try acoustic strings again then i'll let you know if the clear lacquer works
deluges
1 year ago
Nice. Favorited
Stadjer64
2 years ago
Thank you very much for explaining! I have completed the ring as described and it turned out to be very nice.
Stadjer64
2 years ago
I really love this design! The moment I saw it I knew I had to try and make this ring. So I started with the paracord and later with a guitar string. The video tutorial was very usefull. The only problem is that I can't figure out how to make the double knot. I finished the working end next to the standing end but don't know how to weave from this point in order to get the double lines. Could you please help me out?
Thank you.
finished
MartyK1Stadjer64
Reply 2 years ago
In order to double it, you simply follow parallel to the original path starting from the standing end until you return to the beginning.
Stadjer64MartyK1
Reply 2 years ago
Hi Marty,
I have been working on this ring for days now but still don't get it right. When you say follow the original path, which steps do you mean? Could you explain please? Thank you.
MartyK1Stadjer64
Reply 2 years ago
Not sure exactly how to explain it in words, but I'll try. The "working end" starts right along side of the "standing end" and follows it using its "overs" and "unders" until you get back around to the standing end again... with the Spanish ring knot, it should be 5 complete turns until you come back to your starting point.
MartyK1MartyK1
Reply 2 years ago
In this video:
at approximately 3:15, it shows the working end being threaded along the left side of the standing end. At this point, it's a complete Spanish ring knot. However, to double it, it's easiest to go RIGHT of the standing end, and follow that lead, always staying to the right of that lead, never crossing itself, but paralleling it. Hope this helps clarify.
Stadjer64MartyK1
Reply 2 years ago
Thank you, I will give it another try.
njreyn
3 years ago
Interesting way to finish. I've made a few rings and bracelets from my used guitar and bass strings using loose turk's heads, but they're lying around waiting for me to cypher out a way to finish them. I was figuring on soldering them, but my soldering kung fu is weak so the pieces lie there waiting for me to get up the gumption. I'll have to give this way a try. Thanks for the inspiration!
MartyK1njreyn
Reply 2 years ago
Finally go around to trying this with solder. It was a little sloppy, but I cleaned it up and smoothed it with a dremel too and small grinding bit. Feels better on my finger.
MartyK1njreyn
Reply 3 years ago
Thanks. Not having an easy way to finish the ring always my reason for not making a ring before. Soldering guitar strings seemed like it might work, but I didn't feel like the lead content in solder would make me feel safe wearing it. Also, my soldering looks like kung poo.
godsdogMartyK1
Reply 3 years ago
Plumbing solder contains no lead. Requires a significant amount of heat though. Flux will definitely help. I like to dip the solder in flux that way it doesn't just burn off when I'm heating up the components being soldered. Good luck!
DragonTamer458
2 years ago
I made this with one of my old cello strings. Worked brilliantly. Thanks for sharing
CarlosS107
3 years ago
I love this for the optional and "not needed" items!
MartyK1
3 years ago
Here's an earlier version using a much thicker string. I found thicker strings harder to work with and more susceptible to kinking.
emunahmakes
3 years ago
This is way awesome! Would like to try with my old bass strings ;)
