Gum Drive
32,534
55
48
Reuse that old or broken iPod mini in a fresh, sweet, and slightly minty way. You might even be able to have the same color case!
Step 1: The Acquisition and Idea
Maybe you sat on your favorite iPod and broke the screen. Maybe the case got scratched and smashed when you were chair jousting at 3 AM last weekend. Either way, you're out one sweet tunes machine, but still have an excellent data storage device.
I acquired this iPod mini from a friend. The screen was broken, and the buttons no longer functioned properly. He had actually removed most of the casing himself, therefore picture documentation is lacking in that department. Knowing about the iPod's file storage capability, the obvious option was to make a super sweet four gigabyte portable hard drive.
Step 2: Software Handling
Upon plugging any iPod into your computer, iTunes opens automatically. Apple likes the iPods to update through iTunes, mostly to make things simpler for the user in my opinion, but in this case we need to look at its storage capabilities. Due to my currently disorganized room, the next steps will be demonstrated with a third generation iPod, not the iPod mini previously mentioned.
Step 3: Enabling Disk Use
In the previous step the checkbox "Enable disk use" is left unchecked. When you check it a warning box appears informing you of possible doom should you yank your iPod out of the computer connection without manually ejecting it first. Easy peasey, you can handle that. Fire away!
Step 4: Files!
Having enabled disk use, you should wait for your iPod to finish automatically updating before removing it from the connection with your computer. After each automatic update the iPod is immediately ejected from the computer by iTunes, hence the reminder to need to eject yourself. Having disconnected your iPod, the next time you reconnect it to the computer it should appear on your desktop or in your "My Computer" thing on Windows. Now you can put files on it!
Please note that Apple did a good job of hiding the folder your music in kept in on your iPod. Enabling disk use alone will not allow you to move music imported by iTunes around in the Finder or outside of iTunes. In order to recover song files from a broken iPod, try searching versiontracker for a program to help you with that on your computer.
Step 5: The Battery and Hardware
Closer inspection of the iPod mini reveals the two heaviest and bulkiest parts of the machine: the hard drive and the battery. The hard drive (which says "Microdrive" on it) you obviously need to store files. However, the iPod will run without the battery (the other blue square thing) if, and only if, it is connected using a firewire iPod cable. If the iPod you are using is a mini, you can certainly do away with the battery entirely, but you rely on having a firewire connection to every computer you wish to use it on. I recommend that you keep that baby in there.
Step 6: Casing
Casing is a difficult, but fun subject to attack. Any material used needed to be the right size, and flexible enough to cut a slit for the iPod connection.
I decided that using a metal case without any inner lining might make unwanted and possibly device-ruining connections on the circuit board. That eliminated a soda can case.
Originally, as you can see in the photos, I used a simple cardboard case scotch taped together to hold the device. It did the trick, but I kept having to cut the scotch tape to show off my handiwork. Too much work.
I finally discovered that an Orbit gum case is precisely the right size for a stripped down mini. It's flexible. It opens easily, but can be taped shut to prevent accidental slippage. It even comes in different colors similar to the mini's original casing, and your friends like you even more when you inexplicably give away an entire pack of gum. All in all pretty sweet. Just make sure no one throws it away thinking it's a regular pack of gum. Maybe that's what happened to mine...
    • Faux-Real Contest
      Faux-Real Contest
    • Epilog X Contest
      Epilog X Contest
    • Comfort Food Challenge
    48 Discussions
    drdownbrowndjstormdragon
    Reply 10 years ago on Step 6
    LOL! Thats my current project. I just dismantled my ipod mini which a kid at school so kindly gave to me (woot to adam) and i am actually on newegg.com right now ordering a 4gb CF card. Umm, i may even go up to 8gb... it depends how much my next check is (: . When and if it works, i will post an instructable.
    yogibearasdrdownbrown
    Reply 6 years ago on Step 6
    I dont get it, whats the point of using a cf card instead of the hard drive in the ipod, besides the fact that apple will no longer meddle with the files, in which case why wouldnt you just put your music on a flash drive seeing as that i pod has no controlls anyway? Forgive me if this is a stupid question.
    renegade770djstormdragon
    Reply 8 years ago on Step 6
    Yes, the CF card will read exactly the same as the standard hard drive. As long as you installed the CF card and adapter properly, it should work.
    lakaiorion
    9 years ago on Step 4
    actually all u need to do is go under ur control panel and under folder options, check the box next to show hidden files
    Derin
    10 years ago on Introduction
    i plan on modding it a little...just ordered a box of broken ipods...hope they accept my request
    DerinDerin
    darn they wont
    YOU LOST ANOTHER CUSTOMER YOU STUPID COMPANY CALLED APPLE!!!!!!
    DerinDerin
    must...............................get...................................mac..............................somehow.......................*puts tinfoil hat on*.................aaah...................cant.................escape...................the...........................feeling
    toogersDerin
    ugh, artemis fowl joke. everyone at my school liked that book at one time, but i didn't ever like it.
    Derintoogers
    . I wasnt doing an artemis fowl joke.I never read the book anyway.
    Awesomeseries
    Redgerr, its best if you use a flat end screwdriver, and pry it open. worked for me. mine looks a little different on the inside. i guess its because its a 15 gig. huge harddrive! nice intructable! inspired me to finally figure out some thing to do with one of the 8 ipods ive won in the past 3 years.
    Redgerr
    okay i made one of these last night with my ipod mini but i dont get how to take the case off! its really hard lol your instructable works great though :) thanks again
    Redgerr
    i just found a old mini my mom had and i think i might do this! awsome idea :O thanks!! :D
    blink182
    11 years ago
    hey, im new to this whole "dismantling my expensive devices" thing, and im hoping my old mini will find a way to get broken any day now. Anyway, how do you go about opening the iPod?
