Gumball Machine Fish Tank
105,107
305
35
About: Hi, I'm Jen! In my free time I'm a crafter, food lover, and cake decorator. I also can't stop taking photographs! I have a genuine love and appreciation for all things creative and handmade.
What says 'I love you' better than the gift of a pet goldfish? I know it's not a fuzzy little kitten or a tiny soft puppy but it is a lot easier to take care of. Be unique on Valentine's Day and make a special fish tank that will be remembered for a lifetime.
This old dusty gumball machine I found in the basement needed revival and turned out to be a fantastic home for our new little fish!
You will need the following items to make this fish tank:
-gumball machine
-sheet of glass
-glass cutter
-breaking pliers
-sharpie marker
-glass grinder (or a file)
-safety goggles
-aquarium sealant
-decorative rocks
-aquarium plant
-goldfish!
Supplies:
Step 1: Disassemble Gumball Machine
Remove all inner workings of gumball machine (or what's left of it). All you need to have is the base, bowl and top cap.
Step 2: Cut and Grind Glass
Using a sharpie marker trace around the bottom part of the glass bowl (of your gumball machine) onto your glass.
Using a quality glass cutter score the glass along the traced line. If you don't have breaking pliers you can try to break the glass with your hands but I highly recommend the breaking pliers for breaking glass. It is easy to cut yourself otherwise.
Once you have a rough circle cut you will need to smooth the edges of the glass. A glass grinder is the fastest and easiest way to do this, however, you could use a file. Either way, make sure all the edges are smooth and not sharp anywhere. You don't want your significant other slicing their fingers when it comes time to clean the tank!
Once the glass circle is cut and edges are smoothed lay it on the bottom edge of the glass bowl to make sure your cutting was accurate. Make adjustments if necessary. The last thing you want is to seal the pieces together and then it doesn't fit on the gumball machine base!
***Wearing safety glasses is always a good idea when dealing with glass. Small glass shards are often times flying around, especially when using a grinder.
Step 3: Seal Glass
Once your glass circle is cut you will need to seal it onto the glass bowl.
Using aquarium sealant lay a thick bead along the bottom edge of the glass bowl. Carefully line up glass circle on top of the sealant and press firmly to get a good seal. Clean off excess sealant with a paper towel. Let dry according to sealant package.
Step 4: Finish Fish Tank
Add decorative rock and aquarium plants to the bowl. Fill with water and add goldfish!
Give to your loved one for Valentine's Day!
**Please note - a goldfish will eventually outgrow a fish bowl and will need a larger home to stay healthy. However, I was assured by the store I purchased the goldfish from that it will be safe and healthy for about six months (maybe longer) before needing to be moved. This was based on the size of goldfish purchased and the bowl. Make sure the tank is properly cleaned at least once a week.
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
  • IoT Challenge
    IoT Challenge
35 Discussions
Pattymouth
7 years ago on Introduction
I think this is adorable. I've owned lots of fish that have lived long lives in small bowls. If you're worried about size, move him to a bigger bowl when he gets bigger. I don't mean to be insensitive - really - but it's not like you're keeping a brain surgeon locked in a closet. It's a goldfish. If he has any 'thoughts' at all, they will probably be that he's happy to be away from the nasty tank and tapping, gawking kids at WalMart and in his own cozy apartment.
KristaL22
1 year ago on Introduction
Every pet site as well as our vet says tanks like these are a no no. There's no filtration system so within a couple hours the fish are swimming in their own toxic waste. Making it harder and harder for them to breath imagine spending days struggling to breath til someone gives fresh water only to repeat the cycle a few hours later.
DIYPetKeeper18
1 year ago
please don't put fish in this! Goldfish need a minimum tank size of 20-40 gallons depending on the breed you have (look it up) and bettas need a minimum tank size of 2.5 gallons. And how does air get in??? If you want to put something in this, put some fake decor in it or better yet, gumballs! That's what the dang thing was made for! Not fish!!!
Herbruikbaar
3 years ago
Wow, this is really nice!
SydR1
3 years ago
I may sound dumb with this question cause there obvious air flow... Lol so I'll apologize in the beginning! (It's late after a few margaritas ?).. Anyways, I have owned many Betta fish growing up, all living in fish bowls.. With this type of bubble gum tank/environment, where does the fresh air circulation come from? Was there a step I over looked?
Thinking this idea would be great for my boyfriends kids!!
Appreciate any insight into doing something cool like this.. His first Betta died right away and I want to cheer him up with a cool unique idea.
Thanks guys ?
TheFishGirl
3 years ago on Introduction
This is SO in humane.... I have 4 guppies in a ten gallon tank. Bettas need more room than that! Please research before you get an animal!!!
kenyer
4 years ago on Introduction
I love this idea. I have a gum ball machine catching dust in the garage that I might turn in a seamonkey-tank like this.
awesomness2002
5 years ago
High five this is great. Does it work for betas as well?
14, 11:43 AM.jpg
GMWGumballs
5 years ago on Introduction
You can buy a fish tank gumball machine at Gumball Machine Warehouse in the pet food machines section. It cuts out the time needed to create the machine since you can buy it suited for a gilled companion. There are also holes in the top so you can feed in an air pump if that is needed.
PutABirdOnIt
It's an older posting, but still...PLEASE don't give live animals as gifts or put a goldfish in something so small and stagnant, unfiltered water.
I think this would be a cute idea to grow gel beads for the kids or make a terrarium with some cool air plants.
Iselilja
5 years ago
This is amazing! I bought the exact same gumball machine to convert it into a fish tank and once the fish outgrows the tank I'll be using it as a terrarium :) thank you!!!
jtmck26
5 years ago
How tall is this gumball machine
amonj02
5 years ago
What would happen if you pulled the thing that lets the gimbals come out?
wold630amonj02
Reply 5 years ago on Introduction
I guess it would be time for sushi!
Kidding, really. It's all sealed on the bottom.
My boyfriend has made something like this, by converting a gum ball machine into a small tank. There are ways to add a filtration system to it that you can't see it from the outside.
And fyi, you need 1 gallon of water per inch of fish in your tank.
komecake
Reply 6 years ago on Introduction
Even for a betta, this is small. It can be done, but they will be much happier and healthier in at least 2.5 gallons. I have mine in a 5 gallon now and his color changed completely and he is so much healthier in a bigger tank.
grannyjones
A wonderful setting for a single betta.
They live very well in small bowls--just don't put TWO in the same container!
