Gyro Stabilizer W/ Arduino and Servo
56,472
103
62
About: Software Developer of many things. Builder and tinkerer of more things. Curious of most things.
Pitch:
This is how I managed to use a MPU6050, an Arduino Nano, and two Servos to perform basic planar stabilization, as would be found on camera gimbals and so on. This is a work in progress but the guide provide hardware connections and basic code to implement my initial prototype.
My List of Parts:
1 x 6 DOF MPU-6050 module (http://goo.gl/0uxWkR) from Banggood.com
1 x Arduino Nano
2 x 9g Servos (http://goo.gl/N81jsj) from Banggood.com
2 x 10k Resistors
1 x Breadboard
Jumper wires
USB Battery pack (for independent power) or use USB power from a PC
IMPORTANT: I pay Banggood.com only w/ PayPal. I read that you shouldn't use credit cards there.
Step 1: Step 1: Push Things in and Roll Tape.
1. It took me a long time to convince me that I need 10k Pull-Up Resistors on SCL and SDA pins off MPU-6050 module. But they are vital for the MPU to function properly. Before I added those resistors, my MPU would cause lock-up w/in a minute of power-up. Also pay attention to the #2 and #3 below for complete solution.
(Updated on 1/17/16)
2. Jeff Rowberg @ I2CDevlib.com points out ADO pin must be connected to GND (I2CDevlib.com post).
3. ArsenioDev also points out that baud rate for MPU should be kept at maximum 115200.
4. Thank you for the tips! The tips above completely solved my lock-ups!
5. I'm now running on a DIY Uno w/ ATmega32P-PU w/ clock and two caps and it's running equally great! ATmega by itself only takes about 3ma right now, aside from the MPU and Servo powers.
For wire connections, use the diagram or pictures as a reference. (Also explained in the code)
MPU -> Arduino
VCC -> 5V (this powers the rail and hence the whole system including the servos)
GND -> GND
SCL -> A5
SDA -> A4
INT -> D2 (I have it but not used in current software. I'm polling, not interrupting in this set up)
IMPORTANT: In addition to the wires above, two 10k resistors:
SCL -> 10K resistor (BROWN-BLK-ORANGE-Whatever) -> 5V Rail
SDA -> 10K resistor -> 5V Rail
ADO -> GND (Per Jeff Rowberg @ I2CDevlib.com - See Above)
SERVO 1 -> Arduino
This is the first servo taped (I know it's totally a hack job) on the breadboard, and this is oriented so that it would rotate around the long (or longitudinal or roll) axis. My servos had Brown-Orange-Yellow wires.
BROWN -> GND
ORANGE -> 5V Rail
YELLOW -> D10
SERVO 2 -> Arduino
This is the second servo that is mounted to the servo 1 which controls the pitch axis. Again, it's wrapped even worse than the first one so it's barely visible in the picture.
BROWN -> GND
ORANGE -> 5V Rail
YELLOW -> D11
Step 2: Step 2: Check the Servo Orientation
For the code to work correctly w/o any adjustment, it would help to make sure the servos are oriented the same way as mine. I know the tapes make it terrible to discern. Sorry... If you tape up, or screw everything together and find out that something's turned around, it's no big deal. We'll fix it in the next step.
Step 3: Step 3: Send 1's and 0's to the Arduino Nano
Of course any Arduino should work, but I've been using these Nanos a lot for their affordable price.
Upload the code using the USB cable from your PC. If you have a long cable, you may just leave it alone and let it power the unit. I taped (I know. This is the last one.) a USB power bank underneath the breadboard so I can hold it and feel cool about my sticky mess.
BTW, I have been using the USB brick underneath a breadboard and use USB output to power an Arduino or even connect to a USB-Serial interface (Like an FTDI interface) to power the breadboard and it's been very handy.
It should fire up, and should start it's wake-up dance. It's designed to sweep on both axis to clear the area. If it hits the chassis or things like that, it's possible the mount is too restrictive or servo is mounted backwards.
If a servo seems mounted backwards, you can adjust the code to reverse it's command:
<p>Servo1.write(-mpuPitch + 90);<br>Servo2.write(mpuRoll + 90);</p>
If the command seems to be adding to a change and not correcting it, you may try to reverse the sign of the mpuPitch or mpuRoll. Also, +90 is there because I oriented my servos so that 'normal' horizontal position would be in the middle of the servo range. You may play w/ that value as well depending on your installation.
Step 4: Step 4: Help Me Out Please
I learned a tremendous amount already from everyone w/ their awesome comments on Reddit. (https://goo.gl/lI0ir3)
So please help me make it better and learn lots of other things. I put Kalman Filter and PID on the list of things to read up to improve the command logic. Thank you for reading my first instructable.
P.S. If it does lock up on you, a reset on arduino should get it going again. Sorry.
6 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
62 Discussions
dizzypizzyizzy
Question 22 days ago on Introduction
I uploaded the program, on arduino mega 2560, I installed the servo like in the picture, I used MG996R servos, the two servo's tweek at first then servo1(bottom) always position in at maximum left, then it stop. The serial monitor said MPU connection failed.
what can be th problem sir? hoping for your fast response, I'm a student a a beginner in programing,
*update. I managed to make th MPU connection successfull, but all it still does is tweak the servo's at first then stay idle, even if I tilt the gyro..
kashyap0071232000
Question 4 weeks ago
I uploaded the program and it worked but for a few seconds and then it restarts again plz tell me how to fix this
1 answer
woojaykashyap0071232000
Answer 24 days ago
Hello, can you tell me if you have pull up resistors connected to the I2C pins? If they are, and if the arduino is restarting, you may have buffer overflowing from the MPU. In the code, you will see a few 'flush' calls that drains the MPU data. You can try to add more flush calls especially if you are doing a of additional work between each loop.
blackie99
1 year ago
Great project! I used a Nano and the system adjusts for MPU-6050 pitch and roll orientation changes very accurately! Many thanks to Woojay! Next, I would like to control 3 servos - for pitch, roll and yaw. Does anybody have connection and sketch suggestions for three axes?
LuizL14blackie99
Reply 8 weeks ago
Good night!
Do you use ESP32? TKS!
MaazA10
3 months ago
Really helpful, tweaked my arduino UNO and got the damping of both MG995 near to critical with +-0.2 (assumption of analysis) of tolerance (shaking without moving mpu) .... might get more stable by implementing on something useful.
woojayMaazA10
Reply 3 months ago
Awesome! That's great to hear!
NuklearNadal
Question 1 year ago on Introduction
Hi,
Great project, but i have problem with it i use arduino uno, and when i start program it writes mpu failed to connect and arduino external interupt 0 and fifo overflow can you help me
1 answer
woojayNuklearNadal
Answer 10 months ago
Sorry it's been a while. If it keeps overflowing, you can try to flush the data stream more often than I do. You'll notice that I send a 'flush' command once in a while, and you can try to dump data frequently to reduce overflowing. Hope that helps.
paul.sneed.39
1 year ago
pretty sweet!. I made a sweet gimbal, but I'm having issues with the programming though.
Archiving built core (caching) in: C:\Users\Paul\AppData\Local\Temp\arduino_cache_716588\core\core_arduino_avr_nano_cpu_atmega328_b327234c182a9507b43cdc52bd64fc97.a
C:\Users\Paul\AppData\Local\Temp\ccCJUtOe.ltrans0.ltrans.o: In function `__static_initialization_and_destruction_0':
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:70: undefined reference to `MPU6050::MPU6050()'
C:\Users\Paul\AppData\Local\Temp\ccCJUtOe.ltrans0.ltrans.o: In function `setup':
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:125: undefined reference to `MPU6050::initialize()'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:129: undefined reference to `MPU6050::testConnection()'
C:\Users\Paul\AppData\Local\Temp\ccCJUtOe.ltrans0.ltrans.o: In function `dmpInitialize':
sketch/MPU6050_6Axis_MotionApps20.h:328: undefined reference to `MPU6050::reset()'
sketch/MPU6050_6Axis_MotionApps20.h:339: undefined reference to `MPU6050::setSleepEnabled(bool)'
sketch/MPU6050_6Axis_MotionApps20.h:343: undefined reference to `MPU6050::setMemoryBank(unsigned char, bool, bool)'
sketch/MPU6050_6Axis_MotionApps20.h:345: undefined reference to `MPU6050::setMemoryStartAddress(unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:350: undefined reference to `MPU6050::setMemoryBank(unsigned char, bool, bool)'
sketch/MPU6050_6Axis_MotionApps20.h:359: undefined reference to `MPU6050::getXGyroOffsetTC()'
sketch/MPU6050_6Axis_MotionApps20.h:360: undefined reference to `MPU6050::getYGyroOffsetTC()'
sketch/MPU6050_6Axis_MotionApps20.h:361: undefined reference to `MPU6050::getZGyroOffsetTC()'
sketch/MPU6050_6Axis_MotionApps20.h:371: undefined reference to `MPU6050::setSlaveAddress(unsigned char, unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:373: undefined reference to `MPU6050::setI2CMasterModeEnabled(bool)'
sketch/MPU6050_6Axis_MotionApps20.h:375: undefined reference to `MPU6050::setSlaveAddress(unsigned char, unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:377: undefined reference to `MPU6050::resetI2CMaster()'
sketch/MPU6050_6Axis_MotionApps20.h:384: undefined reference to `MPU6050::writeProgMemoryBlock(unsigned char const*, unsigned int, unsigned char, unsigned char, bool)'
sketch/MPU6050_6Axis_MotionApps20.h:391: undefined reference to `MPU6050::writeProgDMPConfigurationSet(unsigned char const*, unsigned int)'
sketch/MPU6050_6Axis_MotionApps20.h:395: undefined reference to `MPU6050::setClockSource(unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:398: undefined reference to `MPU6050::setIntEnabled(unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:401: undefined reference to `MPU6050::setRate(unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:404: undefined reference to `MPU6050::setExternalFrameSync(unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:407: undefined reference to `MPU6050::setDLPFMode(unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:410: undefined reference to `MPU6050::setFullScaleGyroRange(unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:414: undefined reference to `MPU6050::setDMPConfig1(unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:416: undefined reference to `MPU6050::setDMPConfig2(unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:419: undefined reference to `MPU6050::setOTPBankValid(bool)'
sketch/MPU6050_6Axis_MotionApps20.h:422: undefined reference to `MPU6050::setXGyroOffsetTC(signed char)'
sketch/MPU6050_6Axis_MotionApps20.h:423: undefined reference to `MPU6050::setYGyroOffsetTC(signed char)'
sketch/MPU6050_6Axis_MotionApps20.h:424: undefined reference to `MPU6050::setZGyroOffsetTC(signed char)'
sketch/MPU6050_6Axis_MotionApps20.h:435: undefined reference to `MPU6050::writeMemoryBlock(unsigned char const*, unsigned int, unsigned char, unsigned char, bool, bool)'
sketch/MPU6050_6Axis_MotionApps20.h:439: undefined reference to `MPU6050::writeMemoryBlock(unsigned char const*, unsigned int, unsigned char, unsigned char, bool, bool)'
sketch/MPU6050_6Axis_MotionApps20.h:442: undefined reference to `MPU6050::resetFIFO()'
sketch/MPU6050_6Axis_MotionApps20.h:445: undefined reference to `MPU6050::getFIFOCount()'
sketch/MPU6050_6Axis_MotionApps20.h:450: undefined reference to `MPU6050::getFIFOBytes(unsigned char*, unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:453: undefined reference to `MPU6050::setMotionDetectionThreshold(unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:456: undefined reference to `MPU6050::setZeroMotionDetectionThreshold(unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:459: undefined reference to `MPU6050::setMotionDetectionDuration(unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:462: undefined reference to `MPU6050::setZeroMotionDetectionDuration(unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:465: undefined reference to `MPU6050::resetFIFO()'
sketch/MPU6050_6Axis_MotionApps20.h:468: undefined reference to `MPU6050::setFIFOEnabled(bool)'
sketch/MPU6050_6Axis_MotionApps20.h:471: undefined reference to `MPU6050::setDMPEnabled(bool)'
sketch/MPU6050_6Axis_MotionApps20.h:474: undefined reference to `MPU6050::resetDMP()'
sketch/MPU6050_6Axis_MotionApps20.h:478: undefined reference to `MPU6050::writeMemoryBlock(unsigned char const*, unsigned int, unsigned char, unsigned char, bool, bool)'
sketch/MPU6050_6Axis_MotionApps20.h:482: undefined reference to `MPU6050::writeMemoryBlock(unsigned char const*, unsigned int, unsigned char, unsigned char, bool, bool)'
sketch/MPU6050_6Axis_MotionApps20.h:486: undefined reference to `MPU6050::writeMemoryBlock(unsigned char const*, unsigned int, unsigned char, unsigned char, bool, bool)'
sketch/MPU6050_6Axis_MotionApps20.h:489: undefined reference to `MPU6050::getFIFOCount()'
sketch/MPU6050_6Axis_MotionApps20.h:494: undefined reference to `MPU6050::getFIFOBytes(unsigned char*, unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:503: undefined reference to `MPU6050::readMemoryBlock(unsigned char*, unsigned int, unsigned char, unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:506: undefined reference to `MPU6050::getFIFOCount()'
sketch/MPU6050_6Axis_MotionApps20.h:512: undefined reference to `MPU6050::getFIFOBytes(unsigned char*, unsigned char)'
sketch/MPU6050_6Axis_MotionApps20.h:521: undefined reference to `MPU6050::writeMemoryBlock(unsigned char const*, unsigned int, unsigned char, unsigned char, bool, bool)'
sketch/MPU6050_6Axis_MotionApps20.h:526: undefined reference to `MPU6050::setDMPEnabled(bool)'
sketch/MPU6050_6Axis_MotionApps20.h:535: undefined reference to `MPU6050::resetFIFO()'
sketch/MPU6050_6Axis_MotionApps20.h:536: undefined reference to `MPU6050::getIntStatus()'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:138: undefined reference to `MPU6050::setXGyroOffset(int)'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:139: undefined reference to `MPU6050::setYGyroOffset(int)'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:140: undefined reference to `MPU6050::setZGyroOffset(int)'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:141: undefined reference to `MPU6050::setXAccelOffset(int)'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:142: undefined reference to `MPU6050::setYAccelOffset(int)'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:143: undefined reference to `MPU6050::setZAccelOffset(int)'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:150: undefined reference to `MPU6050::setDMPEnabled(bool)'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:154: undefined reference to `MPU6050::getIntStatus()'
C:\Users\Paul\AppData\Local\Temp\ccCJUtOe.ltrans0.ltrans.o: In function `processAccelGyro':
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:193: undefined reference to `MPU6050::getIntStatus()'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:196: undefined reference to `MPU6050::getFIFOCount()'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:202: undefined reference to `MPU6050::resetFIFO()'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:214: undefined reference to `MPU6050::getFIFOBytes(unsigned char*, unsigned char)'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:220: undefined reference to `MPU6050::resetFIFO()'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:231: undefined reference to `MPU6050::resetFIFO()'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:238: undefined reference to `MPU6050::resetFIFO()'
C:\Users\Paul\Dropbox (Personal)\AppData\Arduino\servo_gimbal\FWBCTKRIJD79BCA/FWBCTKRIJD79BCA.ino:245: undefined reference to `MPU6050::resetFIFO()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Nano.
azarias84RaimiN
Reply 10 months ago
im stuck in the same part, somebody can help us?
myless8
1 year ago
This is an awesome tutorial. Question:
Which libraries are needed to run these?
I see the following:
Servo.h
I2Cdev.h
MPU6050.h (if relevant)
I know, though, that different people write similar, but not necessarily compatible libraries. Which are the ones, specifically, I should get?
RaimiNmyless8
Reply 10 months ago
did you solve the problem
myless8RaimiN
Reply 10 months ago
No, I failed to ever follow through on this project and the questions I had with it.
MilinP2
1 year ago
why is it showing me compilation error in arduino.ide
NisagaLMilinP2
Reply 1 year ago
Download libraries from this link and try again
https://github.com/Isaranu/diy-servo-gimbal
