H-bridge Module
2,007
32
6
About: radom diy projects
simple h-bridge module for your projects
Supplies:
Step 1: Print the Pcb
open the .pcb file with expresspcb
print the pcb.. i use toner transfer method
Step 2: Schematic & Connection Diagram
the mosfets i use are from a laptop's broken motherboard
i found the FDS8884 N-Channel.. the most fast switching mosfets are ok...
also you can take a look the datasheets for each one you find
Step 3: Solder the Mosfets
solder the mosfets and the 2x 10k resistors
Step 4: Test the Circuit
i test it with 24v power supply and a powerfull motor
* You must use a fuse
* Never turn on both of two inputs
Step 5: Put a Heatsink
if the load is big put a heatsink for better results
always look the datasheets for voltage and amperage
Step 6: Ready
its ready..
you can use it with microprocessors (PIC/Atmel) arduino, rc cars or for any project..
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    6 Discussions
    VirajP16
    Question 11 months ago
    could u share the circuit diagram for breadboard ?
    1 answer
    andreash79VirajP16
    Answer 11 months ago
    hello!!!
    the circuit diagram is at step 2
    ismail_ozkaya
    1 year ago
    Hi Andreash. Perfect share. One Questions ? this circuit is connected to the motor how many amps maximum??
    Maker_Inc
    1 year ago
    a and b in the test circuit diagram those goes in microcontroller
