Hack Any Radio Into a Guitar Amp V2
13,137
116
18
About: I've always liked pulling things apart - it's the putting back together again that I have some issues with.
Turn any radio into a guitar amp.
This is probably one of my favourite hacks that I have ever stumbled across! It’s so simple that anyone with a soldering iron and screwdriver can do it.
All radios have an amplifier built into them – it’s how you're able to increase the volume. What this hack allows you to do is to tap into the radio’s amplifier so you can play guitar through it.
You may be thinking why in hell would I want to do that!
Hacking a radio can give you the most amazing vintage tone. The distinct “Lo-fidelity” sounds that come out of these vintage radio’s will really surprise you. It’s a real raw and dirty sound which is perfect for playing some bluesy riffs. There is also the added bonus of creating your very own sound as no 2 radios are ever alike.
When you get your hands on a radio that you want to hack, there is a good chanec that its seen some miles. The speaker might hiss or rattle, the volume could jump around or it has some other left-of-centre feature which is what makes these amps so cool. You never know what sound you are going to get.
I've made a few of these now and this version has added filters in the way of capacitors so the sound is even better. You can swap from a clean sound to a low down dirty sound at a flick of a switch.
Step 1: Things to Gather
Parts
1. Vintage radio. If you don't have one lying around, then try a thrift store, 2nd hand shop or eBay
2. 220uf Cap - eBay This is a good quality audio cap. You can use a cheaper one if you want to but it might affect the sound quality.
3. 100nf Cap - eBay
4. SPDT Switch - eBay
5. 10K Potentiometer - eBay
6. 1/4 mono, input jack - eBay
7. Prototype board - eBay
8. Wires
Tools:
1. Soldering Iron
2. Guitar
3. Guitar cord
4. Drill
5. Screwdriver / Phillips head
Step 2: Finding the Right Radio
I'm no expert on this hack, but after some research and a little experimentation, I worked out that there are some radio's that will work better than others. I have included some notes below on what to look for when your out searching for a vintage radio to convert.
The trick is to find one that has some style and is large enough to pump out some decent sound. You can modify small transistor radios but you'll probably find that they aren't very loud or have any distortion. If the radio has no handle and a wrist strap or is in a little leather case it will be a bit too small to waste you time with. This is due to the small, crappy speaker that they come with.
Look for a radio that's at least a 3 inch speaker. It will ensure the speaker is big enough to have an effect on the tone. The size and quantity of the batteries that the radio takes will also effect the tone! The bigger the size of battery the fuller the tone and the more volume the radio will have. Try and find a radio which takes "C" or "D" batteries as these will give you the best result. The radio I used takes 6 X "D" cell batteries so has plenty of power to drice the 5 amp speaker.
If your radio has extra controls like bass, tone or trebble, then you are in radio amp heaven. These will give you extra ways to change the sound and tone of the amp.
Radios which take a 9v or AA batteries won't give you the best sound. It is definitely worth experimenting though and seeing what type of sound you can get out of the small "transistor" type radio's. You never know...
Step 3: Open Up You Radio
The first thing you'll need to do is to open the back of the radio. You need to be able to get to the volume potentiometer do be able to do this mod. This hack won't affect the radio's ability to play music either so you'll still be able to listen to music through it.
Steps:
1. Flip the radio over and remove the screws holding the back into place
2. With a screwdriver, lever off the knobs and switches. They should pop off with some jiggling.
3. Gently remove the cover making sure that no wires are pulled out.
4. You should be able to see the volume pot and also the solder points.
Step 4: Making the Circuit - Breadboarding
The circuit is pretty simple to make. I'd prototype it first though on a breadboard and then test it first, you may have to change the value of the capacitors for your radio.
Steps:
1. Breadboard the circuit first then test it on the radio.
2. To test you'll need to solder a jumper cable to a ground point on the radio - I used the ground solder point on the speaker
3. The other jumper cable which will be the positive one will be used to probe the volume pot to determine which is gthe right solder point. Once you have found it (you will be able to hear the guitar through the speaker when strummed), then you can solder the jumper wire to it and experiment further.
4. Put the radio onto AM and tune it so it's not on a radio station. You may hear some static or noise, if you, turn down the radio until you don't hear it any longer.
The next step will go through ghow to find the right solder point.
Step 5: Finding the Right Solder Point on the Volume Pot
When deciding on where to add the positive wire on the voltage pot, you need to do a little bit of testing. There are usually about 5 solder points that the voltage pot has, and the wire from the jack will need to be soldered to the right one for the amp to work.
Steps:
1. With the breadboarded circuit connected to ground on the radio and the lead plugged into the 1/4" jack and the guitar, you can start to probe and work out where to attach the positive to the volume pot
2. Place the jumper lead against the first solder point on the volume pot and strum the guitar. If you near nothing, move onto the next one.
3. Once you find the right one (you'll here the guitar through the speaker) solder the jumper lead to it
4. Experiment with different cap values if necessary until you are happy with the sound
Step 6: Making the Circuit
I've included a schematic for the circuit along with the fritzing file in case you want to make any changes. You can download fritzing here to make your own circuit shematics.
Steps:
1. Use the schematic and start to build the circuit
2. You'll need to add some wires so you can connect these to the pot, switch and 1/4' socket. Make sure that they are longer then necessary - it's easier to trim then to add.
3. Once the curcuit is built, you then need to add the components into the radio
Step 7: Adding the Components to the Radio
To be able to plug the guitar inot the radio, you'll need to find a good spot to add the jack (and other components). The good thing is, most radio's have empty space inside to add extra components.
Steps:
1. First identfy where to add the 3 components to the case of the radio. You'll also need to be able to stick the circuit down as well so make sure there's enough room inside for that as well.
2. Drill 3 holes into the radio and secure the pot, switch and jack into the case
3. Place the circuit inside and make sure you can secure it in place later on
Step 8: Connecting the Circuit
Steps:
1. It's now time to wire-up the circuit to the components.
2. Start with wiring-up the switch to the 100nf cap and ground on the speaker. You can attach the ground wire to any ground point on the radio
3. Next wire-up the 10k pot. This is used for volume control and helps filter the sound
4. Lastly, wire-up the 1/4" jack and attach the wire to the solder point on the radio volume pot
5. Plug in your guitar and test to make sure the curcuit is working. If everything is working you should start to hear some sweet sounds coming from the speaker.
Step 9: How to Use the Amp
As I mentioned earlier, the hack won't damage the radio at all and you can still use it just as a radio. Using the amp is very simple but I thought I would add a couple of tips
Steps:
1. Don't have the volume up too loud. As a matter of fact, turn it right down and just have it on
2. You can use either AM or FM, I don't find there is any real difference
3. Tune in the radio so it's not on a station
4. Plug the cord into the jack on the radio and then plug it into your guitar
5. Try adjusting the 10K pot you added and strumming the guitar. Find the sweet spot for the volume. You can also turn it up on the radio volume pot as well. Just note that you might hear some background static if it is too loud. The radio I used can be turned right up without any noise. The amp does become too sensitive though and the sound starts to decay a little.
6. If your radio has bass and trebble control then play around with these as well. You can get some awesome sounds by adjusting them.
7. Try flicking the switch. You'll find that you either have a very clean sound or a grungy, lo-fi sound.
8. Lastly, have fun playing your amp and experiment to see what other sounds you can get out of it.
Trash to Treasure
This is an entry in the
Trash to Treasure
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    18 Discussions
    attosa
    24 days ago
    This is beautiful and high on my list of advanced to-do's :)
    lonesoulsurferattosa
    Reply 20 days ago
    Thanks very much. It's a fun and easy hack to do so def give it a try
    wclapie
    4 weeks ago on Step 9
    Years ago ( I hate to think how many), I used a basic version of this for a mike amp kit and for a piezo kit. Nice basic use and "kit and trash bashing" to use things you already have. Thanks for the circuit update. Far, far better than what I have made.
    lonesoulsurferwclapie
    Reply 4 weeks ago
    I had an old mike lying around and stuck it into the amp last night - didn't sound half bad!
    Thanks for checking it out
    wclapielonesoulsurfer
    Reply 27 days ago
    I have tinkered with circuits, amp mods, ultrasounds and sonics since time immemorial it seems at the ripe old age of 58. The basic ones I mad with a mike and an old AM radio. Worked, "staticy" and whatnot but served as nice mini-amps. The old phone speakers and mouthpieces made nice elements for "fish clickers" with a modded 555 ic chip. Ah, memories.
    JamesA41
    4 weeks ago
    Cool retro build. I have a Kenwood KR-720 that I'm thinking about either installing in a, or just using the, Klipsch Promedia 2.1 powersupply and amps to make into a THX certified 2.1 system. Good motivation reading this as I've been studying some other systems... though recall I need to make a capacitor order for some nice low impedance Panasonics and low ESR's Nichicons. Thanks for sharing and great save!
    lonesoulsurferJamesA41
    Reply 4 weeks ago
    Cheers.
    Def get some good quality caps. They don't really cost much more and they perform so much better in audio projects
    jeff.verive
    4 weeks ago
    Nice hack, and certainly suitable for an electronics enthusiast. I've done this basic hack several times in the past 45 years, and it is a simple way to make a personal guitar (or utility) amp while recycling an old radio.
    To minimize hiss it's a good idea to twist tightly the wires from the audio jack.
    lonesoulsurferjeff.verive
    Reply 4 weeks ago
    Thanks for the tip. So you twist the ground and positive wires together?
    Reply 4 weeks ago
    Some type of choke or coil would help too. If your in the US of A, 60Mghtz line noise is a bear to deal with at times.
    nickton
    4 weeks ago on Step 6
    You might want to use the word "correct" instead of "right" in some sentences. Dumb people like me might get the wrong idea if you know what I mean. Just a thought. Excellent hack though. Unfortunately so far you may have lost me on the word "breadboard". For me a breadboard is usually made of laminated wood.
    wclapienickton
    Reply 4 weeks ago
    "Breadboard" in electronics is a basic plastic or other material "board" you use to wire in part and pieces of electronics to test various circuit ideas before you make a permanent version. Saves a lot of oops and ouches later.
    gravityisweak
    4 weeks ago
    Awesome! These are some of my favorite types of instructables. Relatively simple electronics hack that really changes or improves the function of appliances that are so easily neglected or forgotten about. One that leaves you thinking "why haven't I thought to do this yet" and gets you excited to hurry out and grab the parts so you can get to it right away. Great work as always!
    lonesoulsurfergravityisweak
    Reply 4 weeks ago
    Cheers mate. Definitely a really fun and easy hack. At one stage I had like 10 radios in the garage all hacked to guitar amps! This one though with a caps added turned out great.
    meswanson
    Very simple and useful hack of an old radio. Keeps another item out of the land fill. I had that exact radio for years when I worked construction. It would be blast my favorite radio stations. I hacked it with a 120v ac to the dc voltage it needed so I was not buying batteries.
    All you need to beef up your guitar playing fun it a tuning aid. You guitar is way out of tune.
    Nice job thanks!!
    lonesoulsurfermeswanson
    Reply 4 weeks ago
    It’s actually a great radio. I’ve been using it in the shed.
    I’ve got a tuner but the battery was dead and I had to try and tune by ear. You can tell that I’m tone deaf :) plus I’m missing a bottom e string. Time to get serious and sort out my guitar which is actually a very nice one.
