Hack a Drill - Powerful Gearmotor!
50,864
517
37
About: I am a sound designer who's studied computer game development, run my own sound design business and like to build thing in my spare time.
In this Instructable I will show you how to get a powerful gearmotor from a cordless drill!
I found this cordless drill in the scrap bin at a second hand store. When I got home I discovered something odd (video...)
Supplies:
Step 1: Materials
  • Cordless drill for hacking!
Step 2: Tools
  • Philips head screwdriver
Step 3: Disassemble
Unscrew all the screws holding the two halves together. If it doesn't come apart, there might be some screws under the stickers or the grip pad.
Step 4: The Guts
Step 5: Removing the Chuck
Inside the chuck is a screw. This screw is threaded in reverse so that when you turn it to the right, it comes loose. This part might require some gentle persuasion. Don't throw away the screw, you'll need it when attaching stuff to the motor later.
Step 6: Removing the Clutch
The clutch is attached with two screws. It's spring loaded so be careful removing it. Also, removing the clutch will expose the ballbearings inside, hold the motor upright so they don't fall out.
Step 7: Fixing the Gear
Remove the ball bearings inside the clutch by turning it upside down. To fix the gears in the 'drill' setting we need to insert two set screws in the holes where the ball bearings where. Screw them in until you can turn the motor shaft without it slipping.
Step 8: That's It! We're Done!
Enjoy your gearmotor!
Step 9: Extra
We got a lot of parts for other projects!
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    37 Discussions
    I've got a couple of these from thrift stores too. I'm holding off on the clutch disassembly though, I think it may be a handy feature after all. I plan on using one to drive the leadscrew on my lathe carriage, and an adjustable clutch could work as a simple travel limit if it hits a way bed stop fixture, normally you don't want to do that with the internal gears as it would strip them, but this should do the job.
    Moggie37BeachsideHank
    Reply 2 years ago
    Hi Hank,
    What are you going to use to control the motor. I want to put a power feed on my mill drill.
    BeachsideHankMoggie37
    Reply 2 years ago
    Hi Moogie, I've been experimenting with switching power supplies, but most do not like the inductive load a motor throws out, I have some transformers so I think I'll cobb together a simple linear one, perhaps with pulse width modulation speed control.
    Bamaan
    4 years ago on Introduction
    I have trouble removing the chuck. I removed the screw (Thanks to your reverse thread tip). But I can't get the chuck of the shaft. Do I have to lock the shaft before removing the chuck and how should it be done? Is there another trick?
    clutchsterBamaan
    Reply 4 years ago
    Here is one easy way. Start drill disassembly by removing chuck first. With screw removed, insert the short end of an L shaped 1/4 in. allen wrench into the chuck and tighten the chuck down on the wrench. Then smack the long end of the allen wrench with a hammer it should break loose. If after a couple of tries the chuck does not break loose hit the allen wrench in the opposite direction. Good luck.
    MichaelAtOzBamaan
    Reply 4 years ago on Introduction
    Put the largest that fits, right-angle allen key (short end) into the chuck, tighten. Motor in vise or clamp, whack the long end of the key with a hammer hard a couple of times (anticlockwise). Took three good blows for me.
    simon.w.nordbergBamaan
    Reply 4 years ago
    The chuck is threaded normally. If your put the gear in 'drill' you should be able to unscrew it. You could also try inserting a piece of metal with an angle in the chuck as a leverage.
    killboxguruji1
    they require a fair number of lbs pf force to get moving, but yeah, they make good little 12-18v generators. remember to put in a diode to keep the motor from running off of your charge when the wind dies down you will probably need a strong wind or a pretty large turbine,
    John916R
    I work at a Habitat for Humanity Store and when ever we get old drills in, we strip out the motors and sell them.
    Aunt Jane
    This is so cool! However the video is only 15 seconds and I really could use some visual instrucition!
    simon.w.nordbergAunt Jane
    Reply 4 years ago
    Yea the video only shows the drill being all crazy going the wrong way...
    GregQ
    You can use these drills as generators by putting a bent crank shaped rod or Allen wrench into the chuck, and tapping power off the charging jack. Cut the transformer off a charger to get a convenient cord & plug. This doesn't work w/drills that recharge batts in a separate holder. You can still make D.C. regardless. I ran a slot car off one:crank one way for fwd,backwards for reverse. The more amps you pull, the harder it is to turn, making a great sci. demo gizmo.
    jeffcole
    So many possibilities for a geared motor. Thanks for the ideas!
    meat_chris
    Now that you've removed the motor, how do you power it? An instructable on that would be the other half of the puzzle.
    mikeshorr117
    4 years ago
    Cool idea, but is there an easier way to get a strong motor than to take apart a drill? Can you just buy them?
