Hack an Auxiliary Input to a Car Stereo
3,109
8
Here's how to hack an auxiliary input to your car’s stereo:
https://www.youtube.com/watch?v=ON_JRcDdbKo
Adding a 3.5mm jack is the cheapest way to get a clear audio signal from your phone to your car’s stereo, without having to worry about distortion or interference with a cassette adapter or FM transmitter, aftermarket radio wiring, or expensive MP3 adapters.
Supplies:
Step 1: Disassemble the Dashboard
The first thing is to remove the radio from the dash.
The console lid, radio side trims, driver’s lower foot-well cover (under the steering wheel) glove-box and clock need to be removed to get at the radio screws.
The side panel screw on either side is hidden behind the glove box and driver’s footwell panel.
Step 2: Remove the Stereo From the Dash
One screw behind the clock.
Two screws below the radio.
Then disconnect the radio. If you have navigation, its heavy.
Step 3: Head Unit Dissassembly
Begin to remove all the screws to take apart the headunit.
Remove the GPS or storage cubby and separate the radio face.
Remove all the screws from the stereo casing, including the 6 CD changer and the cassette deck.
Step 4: Determine the Inputs to Solder To
This radio has three main inputs, the radio, the cassette and CD.
Flip the board over and you can see the connector solder points that we are going to wire a 3.5mm headphone plug to. On this radio, it’s a direct connection since they are all analog inputs.
Step 5: CD Changer
For connecting to the CD changer, the Left, right and ground channels are clearly marked. In fact, the ground is common for all three inputs. The CD drive will require a CD with a silent CD track burnt on it to play in order to trick the headunit into reading from the CD drive. It will also work with a CD that has music on it, though it could mess up the audio system when you disconnect your phone, so a silent CD is recommended.
Step 6: Radio Tuner
For connecting through the radio lines, the right, left and ground channels are clearly marked under the tuner. Simply solder to a 3.5mm jack, and the audio from your device will simply override the audio from the radio tuner:
Step 7: Cassette Deck
For the cassette deck, the left, right and ground are clearly marked. You’ll need a blank cassette tape to trick the stereo into thinking there’s a cassette in the drive and read from that source. The sound will still be clearer than using a regular cassette adapter because it doesn’t have to go through mechanical conversion to the magnetic tape stripe. Furthermore, the head from the cassette player can be disconnected to rid of the hiss noise that the blank tape may create.
Step 8: Soldering the 3.5mm Plug
I soldered wires to all three inputs and routed them out of the case to test inside the car.
Here is the completed “harness" I used for testing.
The heart of this aux hack is a 3.5mm cable which you can
get from the dollar store for $1. You can also get a female jack and bolt it to an interior trim panel, such as the radio face or center console. The 3.5mm plug has left, right and ground wires that connect to the respective wires soldered earlier.
Step 9: Test the AUX Input
Plug everything into the dash and try out each input.
The CD player method worked the best, followed by the radio. The cassette player method didn’t work directly due to the jack detection on my phone not detecting headphones were plugged in, though I did hear a static pop when I plugged it in so I’m sure it’ll work with other MP3 players.
Enjoy!
This hack was performed on an Infiniti G35 but is similar to many car audio systems.
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    2 Discussions
    infoathumcabs
    6 weeks ago
    May be useful for my drivers too ;)
    Lee Wilkerson
    7 weeks ago
    All good, but it is a mistake to exclude a DPDT switch or its electronic equivalent to isolate different sources from one another. Probably a good thing to load the input circuit with about 1K Ohm/channel, too.
    I made this same type of modification to several 2000 series Delcos in the 80s. Connected to a pair of home speakers, it was truly amazing the quality I got from them.
