Hack an RC Car's Unused 3rd Channel!
85,808
259
68
About: I'm entirely self taught in electronics, although I do have a chemistry degree which I currently don't use at all in my day job but that's totally okay! Currently studying robotics, Arduino, microcontroller...
So, as we all know most remote control (RC) cars use only 2 channels on their remote control: one for forward and backward, another for left and right. What you may not know is that there is an unused third channel on most RC cars! Cheap cars such as the New Bright line found at places like WalMart and Target use a standard chipset (RX-2/TX-2) found in many many remote control vehicles.  Today we will be hacking that third, unused channel.  On the RX-2/TX-2 datasheet, that third channel is called the "Turbo Mode".
This Instructable showcases a couple of example projects I made to test out if I could take advantage of this unused "Turbo Mode" and operate a gun turret remotely. I built two vehicles - one using a fully automatic battery powered Nerf gun and another using a battery powered squirt gun with an electric pump.
EDIT: I originally titled this "Hack an RC car's unused 5th channel!" but I've since been informed that it's actually just three channels.  The forward/backward and left/right controls are just two channels!  If you see me refer to a 5th channel, just imagine I said three, okay?
EDIT #2: (5/28/13) I recently made another project and Instructable very similar to this one. I mounted an Airsoft machine gun on the top of an RC car! Here's the link to see a full video tutorial to make it: https://www.instructables.com/id/Airsoft-Gun-on-an-RC-Car-Hack/
Helpful Guides:
Step 1: Supplies List
I was amazed to find that between your local Walmart, Target, and RadioShack one can find all the parts necessary for this project!  In fact, this project is so quick and easy that you can do it in mere minutes if you know what you're doing.
You will need:
From Target, WalMart, Toys 'R Us, or wherever: From RadioShack:
Step 2: About Driving DC Motors...
Okay, so check out page 6 of the datasheet I included.  You can see that if you put in a button or switch in the controller that shorts pin 6 to ground you will activate the third "Turbo" channel.  This causes the receiving chip to output 3v on its pin number 12.
Now, we can't just power a DC motor directly from that RX chip.  First of all, the voltage probably isn't high enough.  Second of all, the amount of current needed to power the motor is absolutely not going to be provided by that little chip (I measured 1 Amp for the Nerf gun!).  We need something else to take that 3v signal from the chip and use it to turn the DC motor in whatever toy you're hacking on and off and power it directly from the battery.  That something is the TIP120 transistor.
The two tutorials I listed in the introduction of this Instructable pretty much spell it all out.  I made up a drawing of the circuit, but basically it is just a circuit that takes the 3v signal from the RX-2 chip and switches the battery power on and off for the motor.  The diode, pointing AWAY from ground toward the transistor, is to help prevent back voltage from the motor frying the RX-2 chip.
Step 3: Go Crazy With It and Make Some Stuff!
Now for the really fun part - go make some stuff!  The motor in the previous step's diagram is just whatever motor you find in some toy.  In my case, it was a Nerf gun and a squirt gun.  Included are some pictures and stuff of what I made, just check out the captions for each picture for more info.
I put in a beefier battery to give myself some more playtime and the car some extra "oomph".  Original battery was 6v and lasted a measly 15 minutes.  This one is 7.2v NiMH and is 2800mAh.  Just solder a connector to the battery terminals of the car, hook in your new battery, and you're good to go!  So far as I know the little DC motors in both the car and the toys I used can handle the extra voltage without any issues.  If someone out there is more knowledgeable about this topic then I'm all ears!
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
68 Discussions
HamishM15
2 years ago
Is it possible to run a servo from this?
daniex611
3 years ago on Introduction
Is is possible to add another back/forward motor onto pin #6? I want to repurpose an old RC car and possibly build a small dynamic RC sub. If this is possible, how could I do this? I would need to be able to reverse the motor, so i know that i would need 3-way switch to control the motor. This new motor would be for dive planes to bring the sub down and the usual backwards/forwards motor for the drive. the left/right would stay the same for the rudder. If you could help me with this that would be awesome! Thanks in advance.
artrjc
I know how to make it work right, but to go in both directions you need another RC unit whiches uses the other half - like 27MHz virses 49MHz.
oldsmarracin
4 years ago on Introduction
could one use a 2n2222 transistor i tried but i may be doing something wrong
gunman15
5 years ago
I am going to have to do this, do you know of a way to attach a live feed cam to it also.
lukeD
4 years ago
I am currently trying to do it with the tx2c, I got the right datasheet but nothing seems to work, anyone got ideas for me?
lukeD
4 years ago
THANK YOU A LOT!
In my case I am going to mod my rc boat, im planning to make a feeding boat for carp fishing. The third channel will be used to flip a box or someting (filled with food for carp fishing, to say it simply) so al the stuff in it will fall out of it. That way I'll be able to feed the carp on just the right spot (wich isn't the case if you throw it by hand).
Nice and clearly Idle!
Itchyzombie
5 years ago on Introduction
I'm a 12 year old and I'm proud to say, I did it. :)
if you need help search up the ic on your car, my New Bright was different so thats what I did.
I put a breadboard on top of the hull instead, for my arduino and stuff.
cplnerf
is there any cheap way to send live video feed through? Do you know of any app and cheap camera pair that will work over bluetooth on an iPhone?
4lifenerdfighter
5 years ago on Step 2
Is the third channel analogue like the other two? Can you choose the strength of the water?
ldrago808
Where does the other end of the battery connect to?
gravityisweak
So the TX-2 Turbo chip is in the remote. The RX2 chip is in the car, is that correct? Let's say I don't care about the car moving forward or backward anymore, and just wanted to make a stationary mounted nerf gun that I could remote control to shoot at people walking up my driveway. Would it make the project any simpler? I'm pretty interested in figuring out how to use cheap remote control car guts as on/off switches for random objects.
cplnerfgravityisweak
Reply 5 years ago on Introduction
just wire the gun up to one of the drive motors, make sure you know what your are doing though
tman27
5 years ago
That is f@&&!/&! Awesome
robo10302
6 years ago on Introduction
Hello,can you please help me?on the receiver the IC is the same(RX-2B) But on the transmitter my IC is (TX-2E),will you please give me some suggestions on schematic of this IC?Its a different car:)
