Hacking Like Mr Robot: Rasberry Pi
So if your like me you've probably found the USA network series Mr Robot quite interesting, but did you know that most if not all the "hacks" in the show are real to a certain degree. Well this instructable will teach you how to make a raspberry pi that can hack like in the show.
First things first, I am not responsible for what you do with this project. This is educational and if someone causes damages using information in this tutorial I am not responsible.
Now to the fun part...
Step 1: What We Need for This Project
1. Raspberry Pi
http://www.amazon.com/Raspberry-Pi-756-8308-Mother...
2. ARM version of kali linux
https://www.offensive-security.com/kali-linux-vmwa...
3. Win32 Disk imager
https://sourceforge.net/projects/win32diskimager/
4. SD card at least 4 GB
http://www.amazon.com/SanDisk-Memory-Frustration-F...
5. A basic understanding of the linux command line and hopefully some work with kali linux
Step 2: Install Kali Linux
Start by running Win32 Disk imager as administrator after putting your SD card in your computer, then select the kali linux image you downloaded and select your SD card for the device to write to. When finished hit write.
A warning: make sure you select your SD card, otherwise you may overwrite something accidentally.
Step 3: Finishing Up the Install
Remove the SD card from your computer and put it in your Raspberry Pi and boot. After it boots you will be prompt for a username and password, username: root and password: toor. After type: " startx" in the same command line.
Now that we have kali linux working on our Raspberry pi we need a way to communicate to it right?
Step 4: Connecting to the Pi
The Pi first needs to have a wireless adapter or Ethernet and be connected to the internet. Now we need to fire up netcat on our Pi so we can remotely connect to it. This is essentially a root kit. In the kali command line type:
"nc -l -p6996 -e /bin/sh". This allows us to connect to the Raspberry Pi via port 6996.
You also need to know the Ip address the Raspberry Pi has been assigned on the network. You can do this by typing: "ifconfig" and depending on your connection you should see the Pi's Ip address.
Now to connect type: "nc (Raspberry Pi's Ip address) 6996". An "ifconfig" should show you that you are connected to the Pi.
Step 5: What Now?
You can control the Pi and execute commands remotely as long as the network to Pi is connected to is up.
I you enjoyed this tutorial and want more, learn more about the kali linux operating system and it's tools. This is a great stepping stone into the world of hacking and computer security.
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    3 Discussions
    TiffanyL67
    1 year ago
    what can you do with this?
    neumanngregor
    1 year ago
    Use SSH Server for kali, safer as netcat, here are the commands:
    apt-get install openssh-server
    now remove run levels for SSH
    update-rc.d -f ssh remove
    load the default SSH run level
    update-rc.d -f ssh defaults
    now bakup default keys and make new ones
    cd /etc/ssh/
    mkdir default_kali_keys
    mv ssh_host_* idefault_kali_keys/
    dpkg-reconfigure openssh-server
    now restart ssh service
    sudo service ssh restart
    now make service start with os
    update-rc.d -f ssh enable 2 3 4 5
    Done.
    seamster
    3 years ago
    Interesting to know, thanks!
