Half Bathroom Remodelation
3,148
79
13
I wanted to switch my half bathroom and give it a more modern look. My inspiration came from the grain of the wood I used to cover the wall. Originally I thought to use it in a horizontal style, but when I saw the grain of the wood I changed my original idea. It was created by slicing this particular type of compressed 4x4 which I found at a local Lumber Yard. The bowl is an aluminum piece I found at a department store which was drilled to fit the faucet. The black top is plywood painted glossy black and cover in a thick varnish. The bottom shelf was made with the same 4x4’s. The wall art was created by gluing galvanized washers and glass.This is how the half bathroom was finished. To see other projects, I invite you to www.formacolorytextura.com
Supplies:
Step 1: Before
Step 2: Removed the Mirror
Step 3: The Same Wood I Used for the Tiles, Is the Same Wood I Used to Create the Under Sink Shelf
Step 4: Put Together 4 Pieces of Wood 4x4, Then Painted and Apply the Glaze
Step 5: Installed Without the Sink
Step 6: For the Sink , I Used a Normal Piece for Decoration , Make a Hole and Voilá ...now It's a Sink!!
Step 7: Put Together 4 Pieces and Apply the Polyurethane
Step 8: And This Is the Final Result.
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    13 Discussions
    jayeff
    2 years ago
    The compressed wood for the tiles looks great! I've never seen something like that.
    Forma Color y Texturajayeff
    Reply 2 years ago
    Thank you . That wood was amazing!!! I wish I could find the piece a have with the name on it , but when we moved, I don't remember where I put
    Cptkuddel
    2 years ago
    That compresses wood is extraordinary fancy! Can anyone tell the exact term, or where to buy such?
    I know I have a little piece with the name on it, but in the moving I don't know where I put it. If I find it , I will let you know the name.
    Cptkuddel
    2 years ago
    PS: Forgot to mention, I live in Germany...
