Halloween Garage Door Silhouette
488,443
972
152
I love Halloween, and I've been looking for an excuse to try out the Dremel tool my husband gave me. I thought an eerie Halloween scene covering my garage door would have a lot of impact. Rather than a standard cut-out pasted on, I wanted to add some extra spook factor by lighting it from behind. So a silhouette was a perfect choice.
I'll apologize up front for the photography. These photos just don't do it justice. I wish I knew how to get better Halloween photos at night. Something to work on for the next instructable!
I've no special talents with drawing or tools, just a dogged determination to make something I've envisioned come to life. This took some work, but the result is well worth it. It's a traffic stopper on my street!
Also, our garage door is an old wooden one, and we don't mind screwing things like this into it. I don't think this woul d work with a roll-up panel door. Perhaps it could be mounted on a large wall, or staked into the yard with lights behind it.
You'll need:
drawing materials
roll of paper for a pattern
sharpie
tape
2 4' x 8' sheets of material. I used a 3/16th inch thick plywood I found at Lowe's. Fairly lightweight and easy to cut with the Dremel tool.
Cutting tool such as the Dremel
Sand paper (or use the Dremel again)
Black paint
Several 1" x 2"s and screws for mounting
2 to 3 strings of lights. I used 2 70-bulb strings of orange.
plastic spider
Supplies:
Step 1: Prepare the Pattern and Transfer to Pattern Paper
When drawing my design, I considered the size of my display space (a 2-car garage door), as well as the material I would be using. I used 2 sheets of thin plywood. One sheet runs horizontally, 8 feet wide and 4 feet tall. I had this cut into 2- 4x4 pieces at the store. Each side piece started as a 2 x 6 piece, cut from the other sheet. This gave me some height, and also frames the scene nicely.
I had the cuts made strategically, so that seams would not be too visible. One seam bisects the cauldron, one is between the 2 jack-o-lanterns, and the third is between the cat and the tree.
I drew the design on 8 1/"2 x 11" paper, then used the grid method to enlarge it to the proper size, which I drew on kraft paper, and then cut out. You could, of course, skip the pattern and draw the enlargement (in reverse) straight onto the back of the plywood. Or, if you'll be painting it black, you could draw it right onto the front, as any drawing lines will be covered by black paint.
Using a sharpie, I traced the pattern onto the back of the plywood. The entire design is 12 feet wide and 6 feet tall in the tallest places.
Step 2: Cut Out the Design
Use the Dremel tool to cut out the design. If you have not use this tool before, practice on some scrap. It's not too difficult, but it does take some practice. It can get away from you. Luckily, Halloween designs are very forgiving. A few jagged edges can make it look better! Nothing should be too perfect.
It took me between 1 1/2 and 2 hours to cut out this design. I thought the trees were going to be difficult, but they weren't too bad.
Apparently my cat looks very realistic, at least my dog thought so.
Use coarse sandpaper or the Dremel to sand off the rough edges. Again, no need to be too perfect. People will view this from at least 10 feet away, and probably more.
Step 3: Paint the Cut-outs
Paint the front of the cut-outs. Don't forget the edges, because they will show.
no need to paint the back. Mine were pre-primed. A small roller will make quick work of it.
Step 4: Prepare for Mounting
While the paint is drying, you can add the mounting cleats to the garage door. We ended up screwing in one set of 1" x 2 " boards against the door, and a second set of boards on top of those. We thought this was easier as we could use much shorter screws. Place cleats where two pieces of the cut-out meet. This will help to avoid light seeping through the seams. I also painted these black, in case they show through at all.
Step 5: Add Lights and Install
Put the cut-outs face down on a soft surface, or on something that won't scrape them up. Lay out your light strings, then begin taping them on. I tried to point the bulbs toward the center of the design, to cast the most light that way. I also did not go all the way to the top of the pieces, which put more light toward the bottom where the cauldron is, and gives a look of more heat at the bottom, where a fire would be. Sort of an ombre effect.
Now you're ready to mount the silhouette. You may need help with this step. Line the pieces up with the pre-installed cleats. Make sure cords and bulbs are not in the way. Also check that you will be able to reach the ends of the light strings, so you'll be able to plug them together. Also, the bulbs should not show when looking straight at the piece. Just their glow. Make your adjustments and screw the plywood pieces into the cleats.
As a final touch, I dangled a plastic spider from the witch's hand. It was just too delicate a shape to cut out of wood.
Step 6: Plug It in and Enjoy
Plug in (careful of the cord and the movement of the garage door).
Enjoy the intensifying light effects as daylight fades. I like this design because it's very noticeable in daylight, but it really comes to life in the dark.
It's a traffic-stopper for sure. Can't wait for Halloween!
Make it Glow!
Runner Up in the
Make it Glow!
Halloween Decor Contest
Second Prize in the
25 People Made This Project!
  • Fandom Contest
    Fandom Contest
  • Woodworking Contest
    Woodworking Contest
  • IoT Challenge
    IoT Challenge
152 Discussions
mcorbinMariapurchases23
Reply 7 months ago
I moved this year, and now have a blue garage door, configured differently than my previous one. I still used the orange lights, but because of the darker background, and because we didn't leave as much space between the piece and the door, I"m not getting as much reflected light out. Next year I will experiment with brighter lights, or a different way of mounting that gets me more space.
Answer 9 months ago
I just moved into a house with a blue garage door. I think it is going to look cool with white or purple lights. Maybe you want to paint it a lighter color, or a midtone green or orange or gray. White lights would be good, or a color that will contrast, or a similar color to play it up. I think it would be really interesting on a black garage.
spiderb1
7 months ago
So cool!
GlueGun_RaR
7 months ago
This is gorgeous and so adaptable to various Halloween themes. We're doing Coco this year, and now I know exactly how to light up my garage door with a giant guitar. THANK YOU! And I love the fact that you have a German Shorthaired Pointer. Best breed of dog ever. You ROCK!
mcorbinGlueGun_RaR
Reply 7 months ago
I'll be looking for your instructable on the guitar! (Saw your Dante a couple days ago. Great. And I loved that you picked up some pallet strapping from the floor of the hardware store to use.) Our Lola is a great dog for sure. Kind of a goofball, but a really nice dog. (She's our first dog.)
Riggs511
7 months ago on Step 2
The dog sniffing the cat.... typical!!
Lol.
Great idea. Great job.
I ,too, love Halloween. More than Xmas.
Have a great holiday.
Treasure Tabby
7 months ago
Oo love this idea only if it was me I'd make it in to a Christmas theme and have a big nativity like this. Oh and it has to have some realy cool looking angels on it too.
mcorbinTreasure Tabby
Reply 7 months ago
I want to see what your cool angels look like! I made a Christmas one. It's a Bethlehem scene. I have a picture in the comments somewhere.
jbrauer
Tip 7 months ago
For enlarging images, I use a little Artgraph Tracer Jr. You can pull the lens out and use a section of a paint roller tube to make larger images on the plywood. The extra distance from the bulb makes a really weak image, so I sketched my cut line in a darkened room.
mcorbinJord201
Reply 9 months ago
Look through the comments Somebody posted one.
kwalder
1 year ago
I just made this, waiting for the paint to dry now, and to the people wondering how to draw it on plywood I say just draw it by hand. (I love that now someone posted the drawing from Illustrator, that is fantastic.) However I had to resize the image to fit my house and after spending waaaay too much time trying to figure it out, I just grabbed a pencil and an eraser and drew it all by hand. It really was not that difficult! Worth a try instead of spending a ton of time calculating and trying to draw a grid.
mcorbinkwalder
Reply 1 year ago
Share your pictures with us when it's up and lit, please. Many improvements have been made to my original project, and now people don't ask me questions about it, they ask other posters. Very cool.
mcorbinjoecannon
Reply 1 year ago
Looking through all the fantastic versions made over the last 3 or 4 years.........I can't get over the incredible detail you put into your trees and jack-o-lanterns. Really fantastic. You must be pretty skilled with tools.
Do you care to share your copy. I'd love to try this, going to have to do it the way you did. Thanks in advanced. Inga_mcclellan@yahoo.com is my email. Yours looks amazing as well. Love the faces in the tree's.
mcorbinjoecannon
Reply 2 years ago
Your trees are great. Wonderful detail.
I did the witches in 2 pieces just to make it easier to handle and store.
