Hand Forged Cthulhu Cutlass
10,116
170
31
This bladesmithing project is advanced, and contains a number of steps and techniques. Many of the techniques are worthy of their own Instructable. My goal here is to provide an overview of the entire project.
Step 1: Cutting the Steel Bar and Guard Material
This is the 5160 flat bar stock and 16 gauge mild steel guard material. The 5160 has been cut close to final size and the mild steel is close to it's final profile.
Step 2: The Forged Blade
Here the blade has been forged to shape, including the edge bevels. I used 2.5 and 4 pound hammers, a 125 pound anvil, as well as a hydraulic forging press. I used large flat dies on the press to maintain the blade's flatness and straightness during the forging process.
Step 3: Rough Grinding
Here the blade has been rough ground with a 60 grit belt on a KMG grinder equipped with a flat platen.
Step 4: Blade Hardening and Finishing, Starting the Fittings
Here the blade has been hardened and finish ground.
I hardened the blade by heating it in a 22.5" computer controlled Evenheat oven and quenching in a commercial quench oil. The blade was then tempered.
The bevels were ground to 120 grit, and then soaked in ferric chloride to remove the forge scale and to create a gray patina. The blade flats were left "as forged". I then wire wheeled the entire blade, giving it a glossy, gun-metal gray finish.
The guard was shaped by using an oak die, and refined by cold forging with a light hammer on the horn of my anvil. It was then cold blued in a selenium / phosphoric acid solution.
The white oak handle has been roughed out and drilled through.
I tapped an octagonal piece of mild steel to serve as a temporary nut to hold everything in place for the final final fitting. There was a lot of assembly / disassembly while everything was fit up.
Step 5: Cup Guard, Handle, and Copper Kraken
Here the cup guard has been fitted with an ostrich leg skin overlay and leather bolster on top, and stingray skin on the inside.
The oak handle has been torch scorched and stabilized under a vacuum with wood hardener. I use two part marine grade epoxy putty to fit the tang hole perfectly to the tang.
The hilt assembly is then temporarily assembled for fitting and adjustments.
In the last picture there is a copper fitting depicting a deeply etched kraken. I used a masking process and ferric chloride soak to make it.
Step 6: Wooden Scabbard
This is fairly self explanatory. I cut the 1/4" poplar on a band saw, used wood glue, and clamped it up.
Step 7: Sintered Bronze Cthulhu Head
I made this bronze Cthulhu head by pressing a mixture of bronze powder, methylcellulose, and water into a silicone mold, allowing it to dry, and then firing it, sintering the bronze powder into solid bronze. It is attached to the leather backer with contact cement and two screws.
Step 8: The Eye of the Kraken
Here the scabbard has been sanded and stained.
This kraken eye was made by mounting a glass cabochon on a printed eye graphic, mounting that on leather, and covering it with an ostrich leg skin eyelid.
Step 9: The Finished Sword...
    • Organization Contest
    • Build a Tool Contest
    • Pie Contest
      Pie Contest
    31 Discussions
    tgdulahurricanescratch
    Reply 4 months ago
    1/4" at the base with a full length distal taper to just under 1/8" above the bevels at the tip.
    hurricanescratch
    Question 4 months ago on Step 9
    How thick 5160 bar stock did you use and what where the dimensions of the blade? it looks like 2" to me but i cant tell. thank you
    Reply 4 months ago
    The bar stock was .25" x 1.75" hot roll. The finished blade was a bit over 2" at the widest point by 18" long.
    ElijahH16
    2 years ago
    Excellent work! How long did you make the handle? I am in the process of forging another cutlass myself and would like to hear your opinion about handle length. I tend to make my handles a bit too long for fear of having an uncomfortably short grip. Your response would be greatly appreciated. Again, thank you for sharing your outstanding work.
    tgdulaElijahH16
    Reply 2 years ago
    This one was custom for a very large man, so the handle is about 4.75". For an average sized hand I'd go 4.25".
    Tom tee
    2 years ago
    Could you just give me a quick update on the sintering part? I mean as in what's the weight numbers of what you used (ratio wise maybe). Also, I'm guessing you used warm water, but can it also be done with Carboxymethylcellulose?
    Sorry for a spam of questions, but an answer would speed my project up some.
    tgdulaTom tee
    Reply 2 years ago
    3 parts bronze powder to one part methylcellulose by volume. Carboxymethylcellulose will work. I used room temperature water - just enough to get a very thick clay - too thin and it's sticky and will sag.
    deluges
    2 years ago
    This is amazing, thanks for sharing! As Troy said, it'd be even better with images of the process :) Still very inspiring.
    I think an instructables on the bronze sintering methode you used would be extremely interesting for a lot of people arounf here (including me)
    tgduladeluges
    Reply 2 years ago
    Yeah, I know this is a pretty high level overview. I intend to do a separate Instructable for each stage as I do them on new projects. THANKS!
    alimorina
    2 years ago
    hail hydra!
    smartrem
    2 years ago
    I love the copper kraken, which you'd make an instructable about it. Voted!
    Tom tee
    2 years ago
    Can I ask where you got the Cthulhu head mould from?
    tgdulaTom tee
    Reply 2 years ago
    I made the mold with two part silicone molding compound. The original is a refrigerator magnet I've owned for years.
    Mipy
    2 years ago
    BTW I voted for this
