Handbound Book
152,635
400
39
Pages last longer, lie flatter, and look better inside a handsome, durable hardcover. When you've completed this bookbinding project, you'll have a durable, attractive, and personalized copy of MAKE (or other magazine or collection of loose pages) that will last forever and lie flat.
This Instructable is a longer version of the article that appears in heavily edited (in a good way) form in Make magazine, Volume 5. While the editors did a great job of distilling ramblings that far exceeded the word limit I was given into a concise and useful article, the limits of space prohibited much of the additional description, background, nuance, and pictures (larger versions of all the images in this Instructable are available in this Flickr set) of my original piece. So, I thought it was worth posting my first draft. What it lacks in polish I hope it makes up for in depth.
Note: Like most thick magazines or paperback books, MAKE is perfect bound: individual leaves (a leaf represents two pages, front and back, on one sheet of paper) are collected and glued directly to the spine, where the front and back cover (a single continuous wrapped sheet) meet. Shorter magazines are often saddle-stitch bound (longer sheets, representing two leaves each, are folded and stapled at their spine), which actually cuts out a number of steps for hand binding. If you've decided to bind a saddle-stitched magazine (or several into a single book), you've saved yourself a lot of trouble and can skip ahead to Step 4 ("Stitch the Signatures").
Supplies:
Step 1: Strip the Existing Cover
Before you can begin rebinding the book, you'll first need to remove the existing cover and glued spine. I found that MAKE's cover pulled away cleanly by simply applying gentle but heavy pressure where the cover meets the spine.
Use a utility knife and a heavy ruler (a carpenter's square is ideal) to cut about 1/8" from the spine (or as far in as it takes to clear the thickness of the glue).
Not counting the two pages of advertising on a single leaf, which you'll probably feel comfortable excluding from the book (sorry, ofoto), you now have 192 loose pages (96 leaves).
It's not a coincidence that this number divides evenly into six groups of 32 pages each (not counting the ad, which was likely printed separately from the rest of the pages and added to the process just before the pages were glued). Because of the way books and magazines are produced (many pages are printed on large sheets, which are then folded and cut as a group), it's more cost efficient to keep the page count to a number that is divisible by a standard number of pages for a pass on the printer. Even if the magazine ends up being perfect bound, the publisher doesn't want to waste any pages for a pass the printer's already making any more than they want it to make an additional pass for an extra page.
When each group of pages leaves the press, it's then folded and cut to form a signature: a collection of pages that looks just like a saddle-stitched magazine and acts as a basic building block for a longer book.
Step 2: Create Signatures
If you turn a hardcover book on its end and look into its spine, you'll likely see the pages grouped into signatures. Grouping pages like this makes the book's spine much stronger and more durable, keeps pages from falling out (as sometimes happens in a perfect-bound book when the glue wears out), and allows larger books to lie flat, which will particularly come in handy for a magazine like this one, which contains instructions you'll want to keep open for review as you work. Since our perfect-bound magazine is now just a collection of loose pages, we'll now need to create the signatures.
Collect your pages into six groups of 32 pages each, discarding the leaf of ads. Clothespins do a good job of keeping them sorted while you work. (Note that I turned around the first page, so that the book now begins with the Table of Contents, rather than an ad—just a small personalization you might as well make if you're going to all the trouble to hand-bind the darn thing anyway).
Start with the first group, moving the others to the side. Opening the group as if it were a book, split it in half, such that pages 16 and 17 are facing as verso (left) and recto (right) pages, respectively.
Now, pair pages 16 and 17 together and set them aside. The facing pages beneath those should be and 14 and 19. Keep them facing each other and set them aside. The next facing pages should be 12 and 21. Keep them facing and set them aside, and continue through in this way through the rest of the group.
Perhaps this grouping seems strange, but it serves an important purpose and must be followed precisely. You'll now glue these facing pages as you've paired them, so they'll retain the original sequence of the magazine when they're folded together where pages 16 and 17 meet.
On page 16 (and, as you join the other pairs, on all verso pages in the group), make a mark 1/4" from its right edge and use your ruler to extend the mark the height of the page.
Cover the left side of the verso page with a piece of scrap paper (you're going to use a lot of scrap paper for this project, so you might want to stock up now), up to the line you've drawn. Using an acid-free, nontoxic adhesive (I'm a YES! man, myself) and a brush, apply a thin coat of glue to the 1⁄4" gulley on the right side of the page. Line the recto page up with your line to glue the two facing pages together.
Do the same for each pair of leaves in the group and return them to the order the pairs were in when you first split the group in half.
Jog the group together to stack them evenly, and fold them along the center of the facing pages. Holding the outside edges of the pages and making a crease at the top and bottom first helps keep the fold uniform and centered. Optionally, and for the smoothest fold, use a bone folder (found by that name in the bookbinding section of most craft stores) to smooth out toward the crease. You've just completed your first signature.
Do the same for each group of pages and collate the finished signatures in their original order.
To make sure your signatures remain in the correct order when you stitch them together, you might want to use a pencil to lightly sign each signature (this is where the term signature actually comes from) with a number near the spine. You've now turned your loose pages into a collection of folded and gathered sheets and are at stage of the publishing process known as F&Gs.
Step 3: Prepare Signatures for Stitching
Before actually binding your F&Gs, you now must sew them all together around strong, 1/4"-width linen tapes (ask for bookbinding tape at your local craft store) at the spine. This process creates the added durability offered by a hand-bound book.
Using three tapes, running perpendicular with the folds of the signatures, provides for the strongest spine. With your ruler and pencil, make eight marks along the fold of the first signature. Make your first mark 1/2" from the head of the signature, and make another 1/2" from the foot; these marks will hold the kettlestiches (the points where one signature is sewn to the next).
The other six marks represent the points where you'll sew around the tapes (two marks--an in point and an out point--for each tape). Keeping these marks in pairs just a fraction wider than 1/4" (to prevent puckering around the tape when you sew around it), space the three pairs evenly between the two kettlestitches. Stack the remaining signatures to make the same marks, at the same measurements.
Use a medium-duty awl to pierce through the marks you've made in each signature. The holes should be just wide enough to allow a needle to work its way through, keeping the thread as snug as possible against the hole; don't create a huge opening.
Now, you're just about ready to sew. Though using a stitching post is not absolutely necessary (as long as you keep a steady hand, make sure the tapes remain taut, and ensure that the signatures stay even while you sew), it does keep the work organized and easier to manipulate with the only two hands you have. If you have one available, set it up with the tapes stretched tight and spaced to match your holes.
If you're stitching freehand, simply line up the tapes as you stitch; keeping in mind the way they look when attached to the stitching post should help visualize the goal you're looking for.
Step 4: Stitch the Signatures
Using a binder's needle (or similarly heavy needle, such as a tapestry needle) draw about 30" of binder's thread (a thick, durable, acid-free linen) through the kettlestitch at the foot of the last signature.
Exit the spine at the next hole and then enter the spine again, stitching around the first tape.
Keep stitching in this way until you exit the spine at the head kettlestitch. Place the next signature over the one you've just stitched and enter the spine at its head kettlestich. Stitch this signature around the tapes just as you did the previous signature. When you exit the foot kettlestitch, before entering the foot kettlestitch of another signature, loop the thread around the foot kettlestitch of the first signature, making a knot.
You'll do this at the foot and head kettlestiches for the remaining signatures, to prevent gaps between these otherwise unstitched contact points between adjoining signatures.
When you run out of thread, knot a new 30" length to the existing thread. The best place to add new thread is just before re-entering the spine around a tape.
Keep stitching till all the signatures are connected, and tie a knot at the last kettlestich. Your signatures are now all sewn up and are just about ready to join to a cover and spine.
Remove the work from the stitching post. At this point, it's a good idea to apply a bit of glue (about 1⁄4") to the inside of the first and last signatures (use a piece of scrap paper to protect the portion of the page you don't intend to glue) and put the work under heavy weights (I find The Compact Edition of the Oxford English Dictionary works quite well) overnight. Even after the tightest stitching job, you'll likely find the signatures are a little loose on these outside edges, and this does a good job of firming up the book block as a solid unit.
Step 5: Glue the Spine
We now need to attach the mull (a strip of cloth) to the spine and tapes. Connecting cover boards to the mull, rather than directly to the signatures themselves, allows for a strong but flexible backbone (hint: this is the key to creating our lay-flat binding), reinforcing the spine and giving you something to connect the front and back covers to. The best cloth to use for mull is white linen fabric with a weave that's loose enough to allow sufficient paste penetration but tight enough to remain strong under pressure. Your knowledgeable craft store clerk should direct you to the perfect cloth specific to this task.
Making sure to keep the work even on all sides and the spine straight, tighten your work in a press and tub. If you don't have one of these lying around (and if this is your first bookbinding project, chances are, you don't), no worries: a vice should work just as well. Just make sure to protect the work from any harsh edges of the vice.
Cut a piece of mull tall enough to cover your kettlestitches and three inches wider than the width of the spine.
Brush a generous amount of glue from the head kettlestitches to the foot kettlestitches and the full width of the spine, including the portions of the tapes that rest over the spine (don't paste the free ends of the tapes).
Measure 1 1/2" in from either side of the mull to mark the area where it will attach to the spine. Then, generously brush the spine area with glue.
Attach the mull to the spine, covering the head and foot kettlestitches, and work the cloth into the spine with your fingers and a clean, dry rag until the glue is set (brush on a little more glue, if necessary). Leave in the press to dry overnight. Your basic book block is now (finally!) ready to bind.
Step 6: Build Cover Boards
You'll need to cut three boards for your hardback case: the front cover, the back cover, and the spine. Your local craft store should stock binder's board (a durable, yet flexible board, about 1/8" thick) for this specific purpose, but in a pinch, chipboard or illustration board should also work.
Using your carpenter's square and utility knife, measure and cut the cover boards. Each cover should be 1/8" longer on the head, foot, and fore edges. Every board has a grain, which usually runs the length of the board. Make sure to cut every board with the grain; otherwise, if any stretching or warping occurs, the error will be much more obvious when two boards stretch in different directions.
The edge on the spine side of the front cover should be reduced by the thickness of two boards (in my case, 1/4"), to accommodate the hinge. Altogether, then, the front cover should be cut to 1/4" taller than the height of the book (1/8" added to the head and foot) and 1/8" narrower than the width of the book (after adding 1/8" and subtracting 1/4").
Cut the spine board to the same height as the covers. Normally, the width of the spine board should be the width of the book block, plus the thickness of the front and back cover boards. But since our book is significantly thicker at its spine than at just 1/4" further in, cutting the spine board to the same thickness as the width of the spine edge of the signatures is more appropriate and will slightly reduce the unwanted effect of a thicker spine than fore edge.
You now have your rough boards. Before attaching them to your book block, use a medium-grit sand paper to smooth out the rough edges. Otherwise, over time, these edges might catch on shelf edges and wear through the cover paper.
Step 7: Attach the Cover Boards
With your book block of signatures lying face up, place a piece of scrap paper (wax paper actually works better, if you have it) between the mull and the tapes and another piece of scrap paper beneath the tapes. Brush the mull with glue.
Remove the top piece of scrap paper. Press the front cover board against the mull, making sure 1/8" of the board extends over the head, foot, and fore edges.
Open the front cover and rest it against a board (or another book) roughly the same thickness as your book along the spine for support. Rub down the mull with a clean, dry cloth or paper until the glue works into the board and becomes almost dry.
Now, apply glue to the tapes and glue the tapes to the mull and cover board, making sure the tapes are perpendicular with the spine. Discard the second piece of scrap paper, and place a clean piece of scrap paper between the cover board and the first signature. Making sure the board is still straight, place the book under weights to dry for a half hour.
To make a more uniform surface (because any variance might show through the endsheets), draw a line on the inside of the cover 1" from the spine and use your utility knife to trim the mull and tapes only along the line (don't cut into the board).
Place a fresh piece of scrap paper between the cover and the first signature, and turn the book over. Repeat the process for the back cover. Your project should start to look like something resembling a book at this point.
Step 8: Cover the Cover
To cover the unsightly skeleton you've created so far, you'll now cover the exterior of the boards with a single piece of decorative paper, which will wrap around the front cover, back cover, and spine. To accommodate this wrap, use your utility knife slit the mull by 1/2" where the covers meet the spine at both the head and foot edges; doing so creates room to slide the paper's turnovers over the edges of both the covers and the boards.
Now, you're ready for your paper. Pick a piece of decorative paper or cloth that suits your project. It should be thin enough to fold easily (I've learned the hard way how hard leather and thick cloth are to work with) but strong enough to hold up to glue and wear. The piece you use should be large enough to more than cover your front cover, back cover, and spine.
Lay your cover paper face down and use your carpenter's square and pencil to measure and mark the placement of your boards. Allow a 1/2" (or the thickness of four boards) turnover (the area of paper that extends beyond the edge of the board, which you will turn over to finish the edge) for all edges and 1/4" (or the thickness of two boards for each hinge (the area between the spine and cover).
Attach the spine to the cover paper where marked by brushing the paper with glue, positioning the spine board, and pressing firmly. Turn the paper over and rub the paper with your bone folder to secure the spine to the paper and gently mold the paper over the edges of the board.
Next, attach the front cover board. Brush the area you've marked with glue, working from the center outward to just over the line and slightly into the turnovers and hinge. Position the board precisely between your marks and press down firmly. Turn the book over and rub down the exterior of the cover with your bone folder, pressing from the inside out to remove any air bubbles or wrinkles.
Now, it's time to attach the backboard. Apply the glue in the same way you brushed it on for the front cover. To position the board without creating any creases or wrinkles, hold the back cover board with one hand and lay its fore edge down on the paper, lining it up to meet your mark for that edge. With your other hand, pinch the paper to the board on that edge, and slowly work your hand along the back of the book, pressing the paper to the board as you go.
Turn the book over and rub down the back cover with the bone folder, just as you did with the front cover, working the folder into the hinge to seal the paper to your book block around the spine. Turn the book over again and work the folder into the hinge of the front cover.
Wrap the book in wax paper and press for a half hour in your press, vice, or under heavy weights.
Before folding the turnovers, you'll need to miter the corners, removing the excess paper at the tip of the corner to prevent an unsightly (and potentially damaging, over time) bulge where the head (or foot) and fore edge fold over each other. Use your ruler and pencil to make a mark 1/4" out from the corner of the board. Draw a line at a 45-degree and cut away the excess to create your miter. Miter the remaining three corners in the same way.
You're almost done. It's time to fold over the turnovers. Lay the book open and brush a sparing amount of glue across the length of the head turnover. Folding this turnover can be a bit tricky. Stand the book up on its foot edge and use your fingers to gently roll the edges of the head turnover over the top of the board, working from the spine out toward the fore edges. You might need to use your bone folder to work the paper into the spine, since this area might be a little tight, even though you've slit the mull to accommodate the paper (without doing so would have made this step impossible). Do the same for the foot edge.
Before pasting the turnovers on the fore edges, apply a small amount of glue in the crease at the corners and fold over a small portion of paper to create a neat hem. Doing so keeps the paper seam away from the edge of the book and covered by the endsheets.
Brush the first fore edge with glue, fold the turnover, press it firmly, and smooth out any wrinkles or air bubbles.
Use your bone folder to tap each of the corners to make them a little blunt. Removing the sharp edges will help protect the book from wear of sliding it on and off shelves.
Lay sheets of scrap paper between the cover boards and your book block of signatures, and press under heavy weights overnight.
Step 9: Finish Up
Your book should now look like a book. The last remaining step is to cover the unsightly interior of the front and back cover. In addition to finishing off the book and making it look more attractive, pasting endsheets also increases the strength of your book, because it acts as a final reinforcement to draw the cover to the spine. If you were making a blank book, using the first and last pages of the book as your endsheets (and perhaps then covering them with a nice decorative paper to finish them off) would add the most additional strength, since those pages are actually stitched and glued to the spine.
But since your first and last pages actually contain content (including the important TOC on the first page), you'll want to use paper specific to this task. I decided to use MAKE's original wraparound cover as my endsheet for the front cover board. Its thick stock works well for extra support and looks quite nice. I simply trimmed it to fit (leaving a the same distance to the each edge of the book and pasted the back of the wraparound cover to the front cover board. Allow glue to run into the spine of the wraparound cover, because you'll want to use that area to cover the point where the cover meets the spine and extend into the front page by about 1/4". This grips the endsheet to the book block to add reinforcement to the spine.
You'll need to cover the back cover board in the same way. Since I'd already stripped the cover from MAKE: Volume 2 (my next bookbinding project), I went ahead and used that for my back cover (guess I'll need to be more creative with picking my endsheets when I bind Volume 2), trimming off the unwanted back cover ad, but leaving enough room to allow the 1/4" spine area to cover the gutter and connect the endsheet to the final page.
Put fresh pieces of wax paper between the covers and the book block, and set under heavy weights to dry overnight. You'll wake up to a copy of MAKE that will last forever, as well as look unique and serve you well.
As you can see, as promised, the finished book lies flat, perfect for following an article's instructions while working on a project like this one.
Now, on to Volume 2 ...
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    39 Discussions
    SparkySolar
    4 years ago
    Thank you, this is very thorough
    saosport
    6 years ago on Introduction
    Thank you I was looking for something like this. My mom's favorite cook book is falling apart and I want to fix it. I just have to get the book away from her:)
    upbags2
    7 years ago on Introduction
    Hello,
    Thank you for sharing this awesome tutorial!
    Can mull be replaced with buckram which is a heavily starched interfacing or other interfacing? I know cheese cloth is probably too loosed weaved.
    BrianSawyerupbags2
    Thanks for the kind words. As for your question, I wish I knew the answer. I don't know much about buckram, but I'd need to look at the weave to determine if it would work. It should be pretty easy to test, though. Just brush it with glue against a sheet of paper and see how well the glue penetrates and whether the fabric feels firm enough to support weight of the pages.
    upbags2BrianSawyer
    You are very welcome and thank you for responding so promptly!:) Yes, I will certainly try the test and if doesn't work, I'll simply purchase the mull.
    Thank you so much!
    Angela
    Owenmon
    8 years ago on Introduction
    ahem.
    could you please remove this instructable from the Oodammo guns group?
    the group is only for k'nex guns that shoot a certian type of k'nex, and this
    has just about nothing to do with k'nex or oodammo. thank you.
    BrianSawyerOwenmon
    I have absolutely no idea how this found its way into your group. I haven't even logged on to Instructables in ages. I'll try to figure out how to remove it, but I still can't see how it was added.
    At any rate, my apologies!
    BrianSawyerOwenmon
    Sorry, but I still don't see its group associations and don't know how to remove it. If you can point me in the right direction, I'd be happy to do so.
    thepelton
    9 years ago on Introduction
    I am thinking of binding a bunch of things I have downloaded off the net, including from Instructables.com. I also was interested in some lists of random things from other sites that would be good made into bound books.
    dadokon6
    10 years ago on Introduction
    Although I haven't yet bound mine, I'm going to use this and another Instructable to archive my Garden Railroad magazines. I found an unusual source for the cover 'board' material, when my workplace threw away a whole bunch of old 3-ring binders from various vendors and such. Cut off the vinyl outside, and Shazam! Cover stock! PS. I'm cheating a bit, this is the second 'ible that I've posted this comment on. These are the two best bookbinding examples I've found. Thanks!
    Dave_in_deal
    10 years ago on Step 9
    Hi Brian im new to the book making scene and have got a 500 page (1000 printed pages) that i am binding. this is the only DIY instruction i have found that shows loose pages. could you post or email me a bit more detail on arranging the loose (500 pages) and how you glue them to make the signatures. it will be most appreceated. Dave
    BrianSawyerDave_in_deal
    Reply 10 years ago on Step 9
    Hi Dave, I think the tutorial is as clear on this point as I could possibly make it. Good luck. Brian
    UltraMagnus
    11 years ago on Introduction
    this is quite a good guide, although, my biggest gripe with it really is how you glue the pages together to make folios. i doubt the glue will hold well in the long term. you would probably be better off just oversewing the binding instead of going to all the faff of making folios and signatures.
    BrianSawyerUltraMagnus
    Reply 11 years ago on Introduction
    Well, since I've sewn through the glued edge anyway, the pages are held in with thread more than glue. Even if the glue fails, they're still stitched securely. Really, the glue is more for support of the stitching process than anything else. I agree that it's a clumsy process and less than ideal, but I'm not sure of a better way. Certainly, if you begin with a saddle-stitched magazine, you're already way ahead of the game and are better off avoiding the whole signature-creation process. If I understand you correctly, you're suggesting it would be better to sew directly through the spine of the original magazine? The point of the exercise is to make the project last longer, and pages fall out of perfect binding easily, so I'm not sure what would be gained by that process. But perhaps I'm misunderstanding you?
    UltraMagnusBrianSawyer
    well, i guess the ideal way would be to just re print the magazines from an ebook version, although if it is a scanned ebook that has a whole bunch of other problems.
    oversewing is basically taking the loose pages, and punching holes near the edge through all of them and sewing them together that way.... wikipedia explains it much better than i can http://en.wikipedia.org/wiki/Oversewn_binding
    Browncoat
    Any chance for someone paying you to do this? I've got a Bible that needs a little TLC with it's binding...
    UltraMagnusBrowncoat
    in all honesty, if the bible has any value other than sentimental, this is the last way you want it rebound. take it to a book restorer, or google around for guides on book restoration
    BrianSawyerBrowncoat
    I suppose anything's possible, given the right price, but my guess is that anything I'd have to charge for a job like this would be way more than anyone would want to spend.
