Handmade Flipbook
29,784
70
25
Making your own Flipbook isn't that difficult if you have the right software tools and some patience. I cannot take credit for this design, however - you can find my inspiration over at http://thecurio.us/blog/?p=14 and 3 sample flipbooks by the designer.
View my new flipbooks at https://www.instructables.com/id/Handmade_Flipbook_2/
Supplies:
Step 1: Find 5-6 Sec of Video and Grab Frames
You'll need software that has the ability to grab individual frames and save them to your computer. I used Pinnacle 12 (see figure) and grabbed approximately 101 still frames from approx. 4 seconds of video (at 30fps it should have been 120 individual still frames, but I trimmed the video a little).
This took almost 2 hours - it's time consuming and the software doesn't have any macro ability to automate this procedure. Maybe your software will...
Step 2: Build Up Your Image Collection
You'll end up with a ton of jpeg images. Make sure to number them if your software doesn't do it for you. Pinnacle 12 keeps track of the saved jpgs and appends a number to them which was nice.
Hindsight is 20/20 advice: After finishing my first flipbook, here's a lesson learned: AFTER developing and cutting your images (see later steps) use a Sharpie and label them immediately. I'll show you why in a bit...)
Step 3: Create an Image Template
For this step I used Flash (an OLD version)... I think any graphics software that has the ability to use layers, import jpegs, and export to jpegs will work.
What I did here was create 2 layers: (1) photo and (2) border. The border layer was on top of the photo layer and would create a frame of the picture. I would also use the border to put the frame # as well as cutting guidelines. Why not just use the entire photo (4x6" is the size of the black border in the image here)? You could but the larger stack of photos doesn't flip very well. Using smaller sized images gives a stiffer stack and is easier to flip - just trust me OR try it with a large 4x6 photo stack.
Another reason not to use just plain photo prints is that the developer sometimes doesn't load the photo paper into the hopper properly and you get the occasional image that is slightly askew - a little white on bottom and the image at a very slight angle - ruins the affect.
My work around is seen here - I import the jpeg but it's very large at first. I then resized it (40% of original) and then I cut the image using Ctrl-V. Ctrl-X pastes the resized image directly in the center of the 4x6 work area and the black frame covers part of the photo (see next step).
Step 4: Number the Image and Export
Here you can see that the image has been pasted into the work area - the other image shows the picture with the border hidden. I used the Text tool to give it a number (16) and export it to a jpeg using the screen dimensions. This will create a 4x6 jpeg that I can have developed at the camera store and if I'm careful to use the guidelines to cut, all my images should match up and provide a nice smooth animation.
I could have used a different color for the border but black made the white guidelines easier to see - I changed the guidelines to black when they moved off of the black border - not a big deal if you don't do this, but it helps if the developer doesn't line up the image square on the paper; you'll have at least one end of a guideline that touches the edge of the photo, but hopefully two ends of each guideline.
Also, notice that when I shot this video I kept the subject on the right side of the movie. I knew I would be turning this into a flipbook, so I intentionally kept the subject as far to the right as possible. I also shot it in Widescreen. If you don't have the ability to shoot in Widescreen OR if your subject is centered in your clip, just make your border cover less of the right side of the image and you may even have to build in a left side block to leave in.
Step 5: Cut Out Your Photos
I used a nice cutter to trim each photo to the correct size. Notice here that I left the left black border and number. The number is good in case the photos are printed out of order (they were) or if you drop the stack (I did). The black border will be covered by a leather binding in a later step.
A few thoughts here:
1. I might have been able to fit 2 images to a 4x6" photo - saving money but the images would have been slightly smaller. Also, they would have needed to have been rotated 90 degrees and that wouldn't have left much border which will be needed for drilling later. Keep reading and I think this will begin to make sense...
2. See where I placed the number? Bad idea. Move it down to the middle of the left black border. This way you won't make the mistake I did which is drilling through the numbers. If you wrote the number on the back of each image like I suggested earlier, this will never be a problem.
3. Finally, the more accurate you can be with your trimming - ESPECIALLY on the right edge - the better. You want this stack to not only be as square as possible, but you want that right edge to be cut consistently so the animation is fluid.
Step 6: Gather Your Final Supplies
Besides the photos, you'll also need some leather for the binding and a set of screw posts (also called Chicago screws). I listened to the advice over at the.curio.us website about avoiding Aluminum screw posts because they might strip when tightened - the local hardware store ONLY had these in stock and the clerk told me the same thing, so....
I found a great supplier for these - www.talasonline.com - they charge for the all-brass screws but they sure do look good and have a nice weight to them.
I found a 3" wide and 4" long strip of untreated leather from my local Tandy leather store - they also sell it online. I almost got the 2" wide but my photo stack was just a bit wider than 2" so I trimmed down the 3" using a standard box cutter.
Step 7: Clamp and Drill
Square up your stack and clamp them tight - wrap the photos if you like, but I knew I'd be tossing the first and last one anyway, so I just pushed on.
Now, I don't have a paper drill bit - I wish I did and I'm seriously considering purchasing one. But for this I had to use a standard electric drill and a 1/4" bit. It cut through the paper just fine BUT...
As the bit goes through each piece of photo paper, it messes up the paper just a bit and causes a slight raise in the paper. A 1" thick stack of photos all of sudden becomes a 1.5" stack on the end that's drilled because all those little holes add up quick.
I ended up just sanding them down with some sand paper - not the greatest solution, but until I get a paper drill bit (not sure they even make them in 1/4" or 3/16") this is all I could do. You can see the scratch marks in one of these images. And notice how the numbers were damaged by the drilling - move the number down to where you won't drill and/or write the number on the back of the photo before they get out of order.
When done, my stack was STILL a little too thick for the 1-1/4" screw posts I purchased to connect through the stack and both sides of the leather binding. So I had to thin out the stack. To keep the animation fluid, I avoided pulling out sequential images; I ended up having to pull out about 15 of 101 images to get the thickness right - I just went through my stack and pulled out those images that were very close to the image before or after it.
Step 8: Closing Comments
Cut the leather binder how you like - I gave it a 1.5" width on top and bottom and used only 2 screw sets... I might try 3 next time for a different look. Try to use a heavy leather, maybe 1/4" or so thickness - thin leather won't provide as rigid a flipbook in my opinion.
The leather will darken into a golden-grown over time and as more hands handle it - it should turn into a nice heirloom.
Overall time estimates (for 101 frames)
Video grab to individual frames: approx 2 hours
Importing frame/resize/border/export to JPEG: approx 2 hours
Cutting 4x6 printed photos: approx 1.5 hours
Drilling/sanding holes/assembly: 1 hour
And once again, I have to point you to http://thecurio.us for giving me the idea as well as for proving that I could do something like this on my own. Check out the originals at :
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    25 Discussions
    Jeesh
    8 years ago on Introduction
    Hey, This was great for my photography project! thanks very much I didnt expect them to be so thick but, hey! hope I get good marks :D thanks again
    rtjacks2
    10 years ago on Introduction
    jktechwrite this is an awesome idea! The wife and I are expecting and this will be the perfect gift to preserve the baby's 1st and surprise presents! How many pictures did you use per book, what type of leather, and where did you get the screw posts? Thanks.
    jktechwriterrtjacks2
    Congrats on the new arrival - my wife loves these 3 flipbooks I made showing our son at different ages. My recommendations, based on making about 8 flipbooks so far: 1. No fewer than 60 frames, no more than 90. The thickness of this stack (if you're having them printed on photo paper) is around 3/4 to 1" thick and is a perfect thickness for flipping - if the book is too thick, there will be frames that don't flip properly. 2. I got a 3" wide by 4' long strip of natural leather from Tandy. The strips are cut perfectly (the long edges are perfectly parallel) and I used the 3/8" thickness which gives the flipbooks a solid feel and doesn't let the stack twist in your hands. Tandy is online so you can order directly from them if you don't have a local Tandy store. 3. The brass Chicago screws come directly from talasonline.com - don't be fooled by the brass screw posts at Ace Hardware - they're not real brass and a screwdriver will strip off the color and you'll see bright aluminum underneath (I was ticked off because the salesperson told me they were real brass but I should have known by their weight - too light). When you order, I recommend getting a pack of 1" (6 pairs for 3 books) and also order a pack of 1/4" extensions (again, 6 of them) just in case your stack plus leather is a little too thick. Jim
    rtjacks2jktechwriter
    Jim thank you for your detailed response. I plan on doing the same and maybe one of the wife were she doesn't realize she is the star! Thanks again, Ron
    Thanks! Glad you like it. I've had dozens of friends and family ask me to make them one - if they only knew how much time went into each one!
    jktechwriterhappylinks
    Thanks - I'll take a look at it. Anything to reduce the time involved in ripping individual images from a video clip to JPEGs would be great. Maybe this will do the trick. (If so, then the next step is to find software to automate the placement of the border around each image - for cutting purposes - and then export to a 4x6 jpeg suitable for printing.
    jeaper99
    Class. Total class. Much better than a simple video, you can leave this on a coffee table where it is interactive, and touchable.
    jktechwriter
    One thing I forgot - use Matte finish on your photos - Glossy has a glare that makes the animation hard to see in some light.
    jktechwriter=SMART=
    I didn't keep track with receipts (next time, sorry). I'd estimate I spent about $15 or so on the developing (going to be cheaper next time when I use Costco), $20 on the leather, and $18 or so on 12 sets of Screw posts (with shipping). The leather will allow me to do another 10+ books (based on about 4" for each binding). Photo printing is the highest cost - I figure each book will cost about $15-20 in materials. A bit high I think, but then again, it's handmade and (IMO) very nice looking.
    finky555
    What a great instructable! Just a thought on drilling paper, if you clamp a piece of wood on each side of the area to drill, (top and bottom of the stack) the bit won't tear the paper at each page as the drill goes through. You could cut and pre-drill the wood to use as a template to line up the pictures and holes for future flip books.
    jktechwriterfinky555
    Yeah, someone else made that comment over at the.curio.us website and I totally missed it. I'm going to use that technique on the next book and hopefully the paper won't be so damaged - I'm guessing the wood on bottom and top keeps the paper from ripping?
    jktechwriter
    Thanks for the comments everyone - I'm glad you like it. I wanted to give my wife a gift that would be a nice heirloom. The leather is already starting to brown from the handful of people I've shown.
