Hanging Cat Bed
13,344
176
10
About: DIY maniac from South-Estonia! I love to inspire and to be inspired.
There is now a second version of the cat bed, which does not require to hang from the ceiling.
The new version is more compact and elegant.
Check it out here:
https://www.instructables.com/id/Purrock-Hammock-for-your-purring-friend/
This is a walkthrough of a simple hanging cat bed that we made.
The project is easy to make, requires simple tools and will leave your little friend purring for ages.
Supplies:
Step 1: Materials and Tools Needed
First gather your materials
This includes:
  • Wood (can also be scraps)
  • Fabric (we used the fluffy kind, because cats like fluffy things! ;)
  • Chain or rope
  • Additionally Beer
Tools needed:
  • Ruler
  • Pliers
  • Carpet knife or scissors
  • Nails
  • Wood glue
  • Some sort of saw
  • Hammer
  • Stapler or glue gun
Step 2: Building the Frame
This process is really simple.
First, if you are using chain, separate it into four equal pieces. We used 3 meters of chain, which turned out to be more than enough.
For wood we used 1,9 cm thick birch. We cut four 2,5 cm wide strips using table saw. If you do not have access to table saw, then you can alternatively use pre-cut wood.
We decided to make our bed a square (40X40cm)
Step 3: Connecting the Frame
To connect the frame we made halving joints and fastened them with nails and woodglue.
You can also use screws to connect the frame but make sure you pre-drill holes to avoid cracking the wood.
If your nails are too long you can snip them to correct lenght using a pair of pliers.
Step 4: Cut and Attach the Fabric
First cut out the rough size of your fabric. Be sure to leave enough for overhang and the curvature in the middle.
Now your cat should be super excited. Keep her away for safety ;)
Figure out how to fold the corners, cut the final size of the fabric and start attaching it.
We used staples but a regular hot glue will also do the job.
Attach the chain to each of the corners using nails bent into U-shape (snip the head of the nail off)
To attach the bed to ceiling you can also use these U-shape nails or you can use screws.
Step 5: Introduce the Bed to Your Cat
At first our cat did not seem to like the swinging motion of the bed but later she got used to it.
Caution : You might get little jealous when you have to wake early in the morning and see that your cat can sleep in that comfy bed till noon.
As you can see the chain structure takes up a fair bit of space.
In the future we might build legs to make it more compact and movable.
If I were to ever make it again, i would consider a circular bed, which would match the cat´s regular sleeping shape (the fluffy circle) better.
Animal Innovations Contest
Runner Up in the
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    10 Discussions
    Waalcko
    3 years ago
    Cats and DIY go purrfectly together. Funny to see your cat "helping" along. Nice project.
    VickyD10
    3 years ago
    Oh love this too! I have five cats so a little variety will be wonderful! Can not wait to do one!
    tomas75a
    3 years ago
    Awesome cat bed! And how cute she looks!!! :D
    jakeers
    3 years ago
    This is pretty sweet. I'd definitely make something like this if I had a cat. Is the bed hanging above like a table or something? So the cat can get to it.
    CraftAndujakeers
    Reply 3 years ago
    Thank you.
    My flat is pretty small, but it has high ceilings. To better use the space I rised the bed up 2 meters. The cat bed is actually next to the the bed and on top of the shower room.
    cadfael2
    3 years ago
    Truly nice, thank you! Shared it on Twitter!
    jessyratfink
    3 years ago
    This is such a great idea! Look at that happy little buddy :D
    CraftAnduseamster
    Reply 3 years ago
    Thank you!
    This project is now part of the competition.
    We are already planning a new version of the cat bed.
