Happy Birthday Tune Using Circuit Playground
1,579
11
About: I make things, sometimes they brake
Here's how to play the Happy Birthday Melody on Adafruit's Arduino Compatible board Circuit Playground.
I needed something small to embed in a box for a birthday box surprise
Step 1: Adding the Code
Copy and Paste this code into the Arduino IDE then name the file cpBirthday
Happy Birthday Song! Modified to work with Adafruit's Circuit Playground
To play the song just press the right button on the Circuit Playground
Thanks to Mike Barela for writing a guide for the Tone library for CP His tutorial can be found here: https://learn.adafruit.com/circuit-playground-music/the-sound-of-music */
#include #include "pitches.h"
// Melody notes: int melody[]= {NOTE_G3, NOTE_G3, NOTE_A3, NOTE_G3, NOTE_C4, NOTE_B3, NOTE_G3,NOTE_G3, NOTE_A3,NOTE_G3, NOTE_D4, NOTE_C4, NOTE_G3, NOTE_G3, NOTE_G4,NOTE_E4,NOTE_C4, NOTE_B3, NOTE_A3, NOTE_F4, NOTE_F4, NOTE_E4, NOTE_C4, NOTE_D4, NOTE_C4 };
// note durations: 4 = quarter note, 8 = eighth note, etc.: int noteDurations[] = { 8,8,4,4,4,2,8,8,4,4,4,2,8,8,4,4,4,4,3,8,8,4,4,4,2 };
void setup() {
CircuitPlayground.begin(); }
void loop() { if(CircuitPlayground.rightButton()) { for (int thisNote = 0; thisNote < 26; thisNote++) { int noteDuration = 1000/noteDurations[thisNote]; // to calculating note duration (1 second divided by the note type) CircuitPlayground.playTone(melody[thisNote],noteDuration); // to distinguish the notes, set a minimum time between them. int pauseBetweenNotes = noteDuration * 1.60; delay(pauseBetweenNotes); noTone(8); } } }
Next add a new tab and name that file pitches.h which is a list notes and their frequencies by Brett Hagman
-copy and paste the following into that file
-save it
* Public Constants *************************************************/
#define NOTE_B0 31 #define NOTE_C1 33 #define NOTE_CS1 35 #define NOTE_D1 37 #define NOTE_DS1 39 #define NOTE_E1 41 #define NOTE_F1 44 #define NOTE_FS1 46 #define NOTE_G1 49 #define NOTE_GS1 52 #define NOTE_A1 55 #define NOTE_AS1 58 #define NOTE_B1 62 #define NOTE_C2 65 #define NOTE_CS2 69 #define NOTE_D2 73 #define NOTE_DS2 78 #define NOTE_E2 82 #define NOTE_F2 87 #define NOTE_FS2 93 #define NOTE_G2 98 #define NOTE_GS2 104 #define NOTE_A2 110 #define NOTE_AS2 117 #define NOTE_B2 123 #define NOTE_C3 131 #define NOTE_CS3 139 #define NOTE_D3 147 #define NOTE_DS3 156 #define NOTE_E3 165 #define NOTE_F3 175 #define NOTE_FS3 185 #define NOTE_G3 196 #define NOTE_GS3 208 #define NOTE_A3 220 #define NOTE_AS3 233 #define NOTE_B3 247 #define NOTE_C4 262 #define NOTE_CS4 277 #define NOTE_D4 294 #define NOTE_DS4 311 #define NOTE_E4 330 #define NOTE_F4 349 #define NOTE_FS4 370 #define NOTE_G4 392 #define NOTE_GS4 415 #define NOTE_A4 440 #define NOTE_AS4 466 #define NOTE_B4 494 #define NOTE_C5 523 #define NOTE_CS5 554 #define NOTE_D5 587 #define NOTE_DS5 622 #define NOTE_E5 659 #define NOTE_F5 698 #define NOTE_FS5 740 #define NOTE_G5 784 #define NOTE_GS5 831 #define NOTE_A5 880 #define NOTE_AS5 932 #define NOTE_B5 988 #define NOTE_C6 1047 #define NOTE_CS6 1109 #define NOTE_D6 1175 #define NOTE_DS6 1245 #define NOTE_E6 1319 #define NOTE_F6 1397 #define NOTE_FS6 1480 #define NOTE_G6 1568 #define NOTE_GS6 1661 #define NOTE_A6 1760 #define NOTE_AS6 1865 #define NOTE_B6 1976 #define NOTE_C7 2093 #define NOTE_CS7 2217 #define NOTE_D7 2349 #define NOTE_DS7 2489 #define NOTE_E7 2637 #define NOTE_F7 2794 #define NOTE_FS7 2960 #define NOTE_G7 3136 #define NOTE_GS7 3322 #define NOTE_A7 3520 #define NOTE_AS7 3729 #define NOTE_B7 3951 #define NOTE_C8 4186 #define NOTE_CS8 4435 #define NOTE_D8 4699 #define NOTE_DS8 4978
Step 2: Upload the Code
Make sure you've added the support for the Circuit Playground as explained on this tutorial from Adafruit.
-Select the Adafruit Circuit PLayground under boards as well as its COM port
-Click upload
Step 3: Make It Portable
- I used a 3 x AAA Battery Holder with On/Off Switch and 2-Pin JST connector to provide power to the board
Feel free to tweak the code as you'd like .
- Questions, Feedback, Compliments and requests all welcomed :) :
@NemesisContrer8
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    2 Discussions
    Isaac JosuéC
    1 year ago
    HOla puedes subir uno en espanol
    blic19933
    2 years ago
    Nice Tutorial. Thanks for putting it up.
