Harbor Freight Grinder Rescue
13,018
11
13
About: I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my first ...
This is a Harbor Freight angle head grinder. It is not their least expensive, nor their most expensive grinder, but a mid-range choice that sells for around $35 US. It works well, but has a weakness. See the second photo. Note the red arrow. It indicates the location of a break in the plastic linkage from the electrical switch to the yellow switch button visible in the first photo. Once the plastic linkage breaks, the grinder is useless. In the second photo you can also see the steel linkage I made to replace the plastic linkage and restore function to my grinder. This Instructable will describe how I made and fitted the steel linkage. It will also provide an option for those who do not have access to a welder.
Materials
  • Steel 1/16" (about 1.6mm) thick
  • Steel 1/8" (about 3mm) thick
Tools
  • Phillips screwdriver
  • Drill
  • Small file
  • Hacksaw
  • Grinder
Step 1: Open the Grinder
Remove the single screw near where the power cord enters the case and slide the half of the case on the power cord end away from the motor. See the second photo. Remove the wheel guard. Then remove the four screws holding the metal head on the grinder. Two are encircled in red. Two are not visible, but their approximate location is indicated by the red arrows.
Step 2: The Switch
Note the text box in the photo. If you do not have access to a welder so you can make a steel linkage to replace the plastic linkage, you can mount a replacement toggle or twist switch on the bottom half of the case where you can find space. Connect to the two wires shown in the photo.
Step 3: Steel Linkage
I tried to replicate the broken plastic linkage as closely as possible with my replacement steel linkage, but there were limitations. The yellow switch button requires a square hole for a fitting. I drilled two holes and used a small file to make it rectangular. See the text boxes. Some improvising was needed. I also left an open door for myself so I could make small adjustment to the length of the linkage. After making and installing the steel linkage, I used some grinding to smooth the linkage so it releases as it should. Still, that is better after some usage. Lubrication with some paraffin rubbed on the steel helps, too.
See the second photo. A plastic linkage does not conduct electricity, so there is no danger it will short leads and terminals. But, a steel linkage is a different situation. I thinned the width of the steel linkage so it would not wear on the insulation for the wires and create an electrical short.
Step 4: Reassembly
When I made and installed my steel linkage, I had to remove the motor's armature. That meant the commutator had to come out of the brush assembly. Getting the commutator back between the two brushes is very difficult. I could hold one brush back out of the way, but finally removed the brush holder screws on the second brush and put the brush holder back in place afterward. See the second photo and the text box.
This angle head grinder need not be considered a cheap throw away item. I use it quite a lot. That would not be possible if I had not replaced the weak plastic linkage with a sturdy steel linkage. I use this grinder with a cut off wheel most of the time. I do not use it continuously for long periods. So, mine has plenty of time to cool. It will continue to serve me well for a long time.
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    13 Discussions
    geefry1
    13 days ago on Step 4
    Very good!
    These kinds of instructions are the very things I sometimes find myself doing and, (since I just happen to own a Harbor Freight angle grinder)... I may need this instruction at some point in the future?! Thanks!
    Phil Bgeefry1
    Reply 12 days ago
    Thank you for looking. I am glad you may be able to use this. I do like the side slide switch, but a faster fix would have been to mount a small twist switch near where the piwer cord comes into the tool.
    geefry1Phil B
    Reply 12 days ago
    Good thought!
    (I see you're a "thinker/analyzer" like me! I'm always realizing I coulda, shoulda woulda done something different at the end of some of my projects or creations but... that's how we learn! It's a gift I cherish!
    wrsexton
    4 months ago
    A bit of heat shrink tubing covering the area between the contacts would add some peace of mind. Great fix!
    Phil Bwrsexton
    Reply 4 months ago
    Thank you. Heat shrink tubing would be worth a try. Whatever makes the linkage wider also makes it thicker, and added thickness in some areas also restricts the ability of the linkage to slide and release. I think the linkage is supposed to release fairly easily so the grinder shuts off if anything jars it, especially anything dangerous to the user.
    Ag800HansPhil B
    Reply 2 months ago
    So would grinding it down a bit more, to then use heat shrink, bringing thickness and width back to current dimensions, adding that shorting-avoidant safety, suffice?
    Phil BAg800Hans
    Reply 2 months ago
    You also want to avoid making the linkage weaker so that it might bend in the stress of use. I have decided no shorting can happen if the linkage is narrow enoigh that it cannot bridge both terminals simulataneously. After several months of use, the linkage has not worn away insulation on either terminal, so narrowing it was effective and still did not weaken the linkage too much. Adding heat shrink material also adds something that causes drag and impedes the free movement of the linkage, even if the linkage was thinned for it.
    iceng
    4 months ago
    Nice one Phil and Merry Xmas with a Great New year :-D
    Phil Biceng
    Reply 4 months ago
    Thank you. A Merry Christmas also to you.
    jprussack
    4 months ago
    Really nice! I have the 9.99 HF angle grinder... it's 5+ years old and I'm always wondering how long it can last. Great to have a look inside and know the linkage issue. Similar to most cell phones where the power button is the cheapest component!! ---they (and some larger brands) probably love it for selling refurbished products
    Phil Bjprussack
    Reply 4 months ago
    Thank you for looking and commenting. Five years of service for ten dollars sounds like you have already gotten your money out of it. Mine was only a few months old when the linkage broke. If you have gotten five years of service your switch arrangement must be more durable. My son-in-law buys very good name brand grinders and runs them continuously. He overheats them and burns them up. When the metal head gets the least bit warm I make certain I give it a rest so it can cool.
    Alex in NZ
    4 months ago
    Nice fix for a broken tool. Always good to make a repair (metal) which is now the strongest part of the item. Thank you for sharing this :-)
    Phil BAlex in NZ
    Reply 4 months ago
    Thank you for looking and for commenting. I expect these Chinese grinders are available in New Zealand, too, although likely with a different brand name. Several of their electric tools use the same motor with a different head. I expect they all have the same failure prone plastic linkage or one very similar to it. I am also very much aware of what it was like before I had a welder and try to provide an option for people in that situation when possible. A Merry Christmas to you.
