Hardware Store Bracelet
204,196
986
77
About: I fart around being a basic jill-of-all-trades. I like taking apart things to see how they work, and sometimes even get them put back together. I've been accused of having a wickedly dry sense of humor. I...
Make a classy bracelet from hardware store materials! This simple bracelet looks very upscale, but is inexpensive, classic, and easy.
Supplies:
Step 1: Materials Needed
Obtain the following materials from your local hardware store (and/or bead or craft shop):
spool of 20 ga brass wire
spool of 20 ga copper wire
spool of 18 ga copper wire.
Look in the sections where they have doorbells and picture-hanging supplies if you are having trouble.
Step 2: Tools Needed
Get the following tools if you don't already have them. Some of them, like the round nose pliers, are more jewellery specific and may not be available in hardware stores.
an anvil or bench block (solid and smooth chunk of metal)
hammer with a nice smooth face
wire cutters
nylon tip pliers (or regular pliers with their jaws wrapped in layers of tape so that they are smooth)
round nose pliers (needle nose with wrapped jaws will be OK)
2 pin vises
ruler
floral tape
metal file
polishing cloth
and a thingie from the hardware store called a "quick-grip clamp"
Step 3: Cut and Straighten the Wires.
Begin by cutting 24" of the 18 ga copper wire. Clean and straighten it, then cut it into four 5" pieces. One 4" piece will remain.
Smack the 5" pieces flat using the anvil and the hammer. Try to keep them as straight as possible. They will lengthen by about 1/4" and curve somewhat; simply straighten the curve using the nylon pliers. Polish them with the cloth and file one end smooth. Set aside for the moment.
Double over the 4" piece and smack it gently. This piece should not be as flat as the others. Polish and set aside.
Step 4: Make the Twisted Wire for the Outside.
Cut 18" of the 20 ga wires, both copper and brass. Clean and straighten them then, using the pin vises, twist them together. Set aside.
Step 5: Weave the Middle Braid.
This is the most complex part. Read it through a couple of times.
First picture.
Cut 4 10" pieces each of 20 ga brass and copper. Clean and straighten each one. Tape them together, in a straight line, at the bottom with floral tape, alternating the metals. It won't be extremely neat, but don't worry about that; just do your best.
Second picture.
Place into the clamp just above the taped area. Bend alternating pairs of wire (one brass, one copper) in opposing directions. One set forward, one set backward.
Third picture.
Bend the pair on the right all the way across to the left, keeping the wires aligned.
Fourth picture.
Fold the remaining three pairs over the bent wires to the opposite sides.
Fifth picture.
Manipulate the bent pair, formerly the right pair, so that it is now the far left pair. Bend it so that it is parallel with the second pair.
Sixth picture.
Very carefully release the clamp and reset the wires down so that they are just above the edge of the clamp. You will cover the first weave. Tighten the clamp back up.
Continue in this manner until the wires are woven. (Clamp, weave, unclamp, move it down, reclamp, repeat.) Should you need to put down the work, make a note which side is the front so that when you pick it up it will be in front again. (It will create a bend in the work if you weave it backwards.)
Seventh picture.
The wires will stick out the right side of the clamp at an angle as you work on it.
When you cannot weave any more, remove the braid from the clamp and straighten it with the nylon pliers. You may like to hammer it very gently to get any lumps out of it.
Trim the ends to make a 6" piece of woven material. File the ends if necessary to remove any roughness.
I've tried to make the pictures pretty clear. If you are stuck for extremely detailed directions, I am stealing this part pretty much straight from the book "Woven Wire Jewelry" by Linda Chandler and Christine Ritchey. Many libraries have it.
Step 6: Make the Cage.
Fold the twisted wires in half to make a cage for the woven piece.
Use floral tape to assemble temporarily.
Step 7: Bind the Cage to the Braid.
Make a hook in one of the 5 in. flat copper pieces. Neatly wind it around the end of the bracelet, securing the woven part to the twisted part, leaving a small loop for the clasp. Make 3 or 4 twists, cut and flatten the flat bit on the back side.
(You will be cutting off about half of your flat wire, but you need the extra so you can grip it firmly.)
Repeat on the other end and in two other places, spacing the pieces about 1.5 inch. from the ends. File any rough edges.
Step 8: Finish It Up!
Lower left and upper right pictures:
Trim the twisted wires to about 1/2". Twist more firmly if needed. Curl into two loops, tucking the ends into the flat wire. You will want to make sure the flat wire can't slip off..
Upper left picture:
Bend the folded end of the 4" wire to make a hook. Measure recipient's wrist at this point and cut the hook to size so that the bracelet will fit when clasped. Work the wire patiently so that the hook end won't get any skin pinched inside it -- it needs to be quite closed at the operating end.
Lower right picture:
Attach the hook to the twisted wires. The two ends go into the two loops created in the first part of this step, and then roll into themselves (think "scroll") with the ends on the inside of the bracelet.
Background picture: Carefully manipulate into a wrist-friendly shape using anything you have handy for a mandrel. I used a piece of pvc to form the tighter curves at the side and my hands to ease the rest into a curve. Round doesn't work, for some reason. After you clasp the hook you can kind of pull on the short sides to get a pretty even shape.
Step 9: Admire Your Beautiful Work.
Since you've now spent two or three hours making this, it's time to sit back and really admire your handiwork. Take some pictures (using river rocks like I did, or roll your own backdrop).
Then make a second one, since you're probably going to end up keeping this one for yourself!
To keep the copper clean you can rub some dry baking soda in and then brush with an old, dry toothbrush then rinse with water and dry well. Brushing with toothpaste, like you brush your teeth, will also make it sparkle.
These instructions were originally composed by me and posted here:
http://wire-sculpture.com/fathersdaycontest06/display24.php
So if you've been looking for me, now you've got another link to who I am. Congratulations. Mike, I expect to be hearing from you about that drink pretty soon.
  • Classroom Science Contest
  • Fandom Contest
    Fandom Contest
77 Discussions
wire qween
3 years ago
The author of this tutorial should be more knowledgeable on the topic of wireworking prior to posting this project. I read through some comments and the common theme seemed to be problems with work hardening of the wire. She should have referenced the many tutorials, books and utubes that address this issue and instruct what to do with work hardened wire prior to completion of the project. It is a heating and qwenching process that she should have researched before addressing the problems that students were experiencing. Just because a person has done a project once does not make them an expert. This seems to be a recurring trend online. My advice is to not just jump into attempting a project from any other source than books written by well experienced authors. I have been a wire artist for more than twenty years, an educator locally and nationally as well as an author. Believe me, if you are serious about wanting to learn the trade of jewelry wireworking. Seek the experts who can guide you in the right direction. Good luck to you and have fun.
angeriverawire qween
Reply 2 years ago
Hmm... That's exactly what my friend would have said. And people have told her that she is abrasive, harsh and totally lacking the ability to be positively constructive. Anyone ever said that to you before? "We have a be nice comment policy. Please be positive and constructive."
ShaynaC1
3 years ago
Thanks so much for your post. I am a newbie to wire wrapping and learning what products I need to get before I actually start. Your instructions are clear and the braclet looks lovely.
dimdiode
4 years ago on Introduction
I really like it, and will have a go at making one myself. Thanks
lovelyloot
5 years ago on Introduction
Hi, I'm Linda Chandler and I love what you've done with the woven bracelet. What a creative idea. I think I'll make one like you yours now. Thanks for mentioning my name.
Linda
hypnoangel
6 years ago
Thanks so much for this tutorial. I am not sure if I have commented yet or not, but want you to know that I have made 3 variations of this so far and I am now making a choker using the same methods. I very much appreciate your time and effort! Food job and very pretty!
SethS
7 years ago on Step 5
Overall this has been a great and informative instructable. The weaving part is a bit confusing though.
RaNDoMLeiGHSethS
Reply 7 years ago on Step 5
I'm not sure if the source (with wayyyy more photos) shows up for you, but just in case:
"I've tried to make the pictures pretty clear. If you are stuck for extremely detailed directions, I am stealing this part pretty much straight from the book "Woven Wire Jewelry" by Linda Chandler and Christine Ritchey. Many libraries have it."
The photos in this instructable are my own, though. Sorry if I was unclear - this instructable was actually more or less a repost from a jewellery makers website where I had entered the exact same instructions as part of a father's day jewellery contest. Most of the readers of that site (which is not up anymore) are familiar with wire weaving techniques. As is often the case, when one is too used to the technique, sometimes you accidentally leave out basic instructions.
Thanks for looking at it, and if you have any specific questions, I'll be happy to try to answer them for you. :)
buttersnake
11 years ago on Introduction
Looks really nice, especially for the little money its costs to make. Just be careful wearing it, with all the meth addicts stealing copper these days you might get jumped! LOL
SeaPoppy
9 years ago on Introduction
Pretty bracelet, but it'll leave yr arm green, right? Is there some (maybe hardware too?) coating that'll actually work (aka not nail polish, already tried and failed) to make things like this usable? : ) TY!
jseveranceSeaPoppy
Renaissance wax! Amazing stuff! I purchased thru Amazon- google it for other sources. It's not cheap ($20ish for a 2oz tin) but a little goes a looooong way. Polish the bracelet (or other jewelry/household item) to desired shine/patina. Use a soft cloth to apply a thin layer of RW to item, buff for shine. RW hardens & seals immediately. (This sounds scary, like it will solidify as soon as you open the jar, but it won't. Your thin layer will "dry" immediately, but not in a bad way!) Use multiple layers for extra durability, deeper shine, or to "fill" surface imperfections. (It's not a putty, tho, don't have crazy expectations here...)
I'm in love with this stuff. It can be used on any metal, or wood, ceramic, papier mache- I can't find anything you CAN'T use it on. The supplied pamphlet says it was developed by the British Museum to restore/protect antiquities in the '50's, I think. It's supposed to not degrade the way other crystalline waxes do, it doesn't have the yellowing issues of beeswax... It's great stuff! There's an alcohol-based solvent that removes it. I assume it wears off as I wear my jewelry and reapply occasionally, but I haven't had any issues. And it cures the green from raw copper!
General note: Don't be silly- this IS a petroleum product, and NOT intended for human consumption. Please don't use this on anything you plan to eat/drink from, please don't lick your fingers when applying it, please don't leave it where your toddler might use it for lotion- you are responsible for your proper use of this product. :)
bluemoon6
Yup work hardened it got!!! but it really hold its shape when I wear it--and it does tarnish easy---but.......a q-tip dipped in tarnex and dabbed on the wire and bingo --back to its old shinny self!!!! Just love the bracelet--thanks for sharing it with us!!! --in a pinch pickle juice takes away the tarnich too!! not as good as tzrnex though!! LOL!!!
bluemoon6
with my old arthritic hands this one was a little hard for me--but the end result was very nice--not as perfect as the photo --a little rustic--but everyone who sees it love it--thanks for sharing-----and I braded the side pieces also --cause I dint have a drill to make the sirals perfect or anywhere near it---LOL!!
RaNDoMLeiGHbluemoon6
That could look really nice, with the braided edges.
Yah the wire gets a little work-hardened, doesn't it? I was surprised about it. Congrats on the good work!
brainiac27
8 years ago on Introduction
Thanks for the guide. I have made countless bracelets like this as gifts and everyone of them still wears it. I added enameled wire to mix it up, a pink bracelet came out well enough.
Never made anything like this...but it looks so cool. And my boyfriend might possibly like it. If I make it and it's crap then I'll keep it. :)
Anionis
12 years ago on Introduction
Very good instructable! Just one thing, would there be a way to invorporate the side holders into the bind (very careful threading through?), just to hold them on stronger. They could, over time, bend outwards, and splay, making it harder to put on the bracelet, and ruining the look somewhat. Otherwise, I love it!
