Headband Headphones
8,690
170
These headphones double as a functional, comfortable and stylish winter accessories. To make them I will integrate embroidered fabric speakers with an ear warming headband.
Materials:
- ear warming headband
- wide cloth headband
- thin conductive wire / conductive thread
- 3" embroidery hoop
- old headphones / aux cord
- neodymium magnet
- open weave fabric
- sewing needle & thread
- solder
- soldering iron
Supplies:
Step 1: Set Up
Cut a 3" opening along the interior seam of your cloth headband a little below its horizontal center.
Place the small ring of the embroidery hoop inside the headband and the larger hoop with tightening mechanism on the outside of the headband in the location where you want your speaker. (over your ears)
Step 2: Embroider
Start by threading the conductive wire / tread from one side of the stretched fabric to the other at the center of the embroidery hoop.
From this point create as tight of a coil as possible without letting the conductive material touch at any point.
Secure your coil using an embroidery technique called couching.
Click HERE for a helpful tutorial on couching
Step 3: Solder
When you are finished with your coil, thread the end of your wire / thread to the back where it originated.
Solder one end of your coil to one headphone wire and the other end your coil to the other headphone wire.
Click HERE for a tutorial on the basics of soldering.
Step 4: Magnet
Make a small pouch to hold your neodymium magnet:
To avoid interference with the magnet use an open weave / or very light fabric.
Trace around the magnet onto the fabric.
Fold the fabric so the circle is at the bottom near the crease
Cut a square around the circle so there is about a 1/4" of extra fabric on all sides.
Place the magnet inside and sew up the 3 open edges.
Sew the pouch to the center of the coil from the back on the inside of the headband.
Step 5: Closure
Before sewing the headband closed, be sure to:
Pull the auxiliary through the bottom of the headband.
Sew the magnet pouch in place.
Remove the embroidery hoop.
Step 6: Ear Warmers
For extra warmth place an ear warmer inside of your headband to line it. Then simply stitch the two together.
Step 7: Enjoy
- Plug into any device
- Head out into the cold
- and listen to your favorite winter tunes!
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    2 Discussions
    gravityisweak
    3 years ago
    This is wonderful! The fact that you can make working speakers this way amazes me. I have a few questions. Is the conductive wire coated with anything? You mentioned not to let them touch together so I imagine that its not. If they were enamel coated would this still function as a speaker? I think a flexible material like a headband would make it much more likely that it could get squished or flattened in a way that could cause the coil to touch and short out. Obviously these wouldn't work if you wore this in the rain either. Awesome job though, I can't wait to try this design out!
