Heat-Powered Stove Top Fan W/ Salvaged Parts
14,664
172
28
About: I love experimenting with science and physics, especially projects that involve electromagnetism, energy conservation and audio.
In this instructable, I will show you how to make a heat-powered fan. Set it on top of a wood stove and it blows warm air around the room. There are no power cords or batteries to fuss with and it doesn’t cost anything to operate. This is especially useful if you want to use it in an off grid cabin or live in the developing world. The fan self regulates its speed, meaning the hotter the fire gets, the faster it spins. It helps distribute heat more evenly throughout a room and allow it to warm up faster than it would without a fan. And it’s whisper quiet.
I have seen this type of fan for sale in the Lehman's catalog for $160, but I was able to make this one for about $5, mostly because I had a lot of stuff laying around. I am not claiming that my fan is as well made or reliable as the $160 version, but it was certainly fun to build and works pretty well. Even if you had to go and buy all the parts, you could probably still build it for under $30. However, many of the parts can be obtained free.
If you are looking for inspiration, you can check out YouTube. One video that inspired me in my design was this one:
https://www.youtube.com/watch?v=1u7POtVxtMI
If you stay within certain guidelines, there is a lot of wiggle room as far as design and materials are concerned. I will try to lay out the guidelines for you.
How it works
The magical part about this fan is that it converts the heat of the stove top into electricity, which it then uses to spin the fan blade. This conversion from heat to electricity is performed by a peltier plate (the white square thing with the wires sticking out of it, see picture above), which can be purchased on eBay for about $2. Sometimes, peltier plates are called thermoelectric coolers, and that is because when peltier plates are connected to a power source, they transfer heat from one side of the plate to the other. When used in this way, a peltier acts as a solid state heat pump. Mostly they are used for cooling things like computer processors.
Simply put, peltiers normally work like this:
power in = heat transfer from one side to the other
For this project, we will use the peltier plate in reverse:
heat transfer from one side to the other = power out
To achieve this, we have to hold one side of the peltier plate at a high temperature, and the other side at a lower temperature. That way, As heat makes its way from the hot side to the cooler side, it passes through the peltier plate, generating a small current. Yup, the peltier will act as a thermoelectric generator!
As we discussed, one side of the peltier plate has to be held at a high temperature. It isn't a good idea to just lay it on the stove however, so for us it means attaching the peltier to a chunk of metal and that sits on top of the stove. As for the cooler side, we will attach a chunk of metal to that as well. This one, however, will be a heat sink or other radiator type design that will shed heat efficiently into the surrounding air. Any common metal could be used for these parts, but aluminum, copper, and brass are much better choices than steel. Steel is comparatively poor at transferring heat and is very hard to machine, so it isn't recommended for this project.
The parts that make up the fan:
  • chunk of aluminum I-beam
  • chainsaw engine block (robbed from dead chainsaw)
  • aluminum heat sinks (robbed from dead computers)
  • peltier plate ($2 eBay)
  • small low-voltage DC motor (the ones from CD players work well)
  • sheet metal
  • small (#4 diameter) bolts
  • assorted brass fittings
Tools and equipment you will want:
  • soldering iron w/ solder
  • hacksaw
  • drill w/ bits
  • flat metal file
  • ruler and pencil
  • tin snips or nibblers
  • assorted flat and Phillips head screwdrivers
  • vise for holding things while you cut them
  • tap sized for tapping #4 NC threads
  • hammer
  • RTV gasket maker or electrical tape
I didn't have this but you might want it:
  • thermal paste
Supplies:
Step 1: Obtain Materials
Aluminum heat sinks like the ones used to cool computer processors work really well for this project, and they are easy to obtain. For one thing, many of us have an antiquated/not-working desktop computer or two lurking in a closet somewhere. Also, try going to computer repair places and asking about any heat sinks they might be willing to part with. Plus, don't forget that recycling collection/drop-off/processing locations are great places to look for dead 'puters. Worst case scenario is, you have to buy a heat sink off of eBay.
The motor for spinning the fan blade has to be a low-voltage DC motor, and CD player motors (the one that actually spins the CD) work very well. All you have to do is get your hands on a CD player, or even a computer CD drive, and tear it apart. As a last resort, you could probably buy a motor off eBay.
The engine blocks of small air-cooled engines, while not as effective (at shedding heat) as heat sinks from computers, make interesting pieces. I chose the engine from a chainsaw, an old Stihl 02 WoodBoss.
I got my hands on a chunk of aluminum I-beam somehow, but I am not sure where it came from. It works real well as a base but just about any chunk of metal will work.
One thing we will have to do is sandwich the peltier between the two chunks of metal. For me the easiest way to do it was to bolt the two halves to each other. The drawback is that heat will be conducted through the bolts, and this will hurt efficiency. My compromise was to use small bolts, diameter #4.
I threaded some brass plumbing fittings together to make the part that holds the fan motor. It seems that a ¼ inch NPT (national pipe thread) fitting fits well into the 14mm spark plug hole. For you, a simpler way to make the brass part may be to buy a dishwasher elbow or something like that. Go to the hardware store and start playing around, seeing what you can make. I had some brass pieces laying around, so I used those, though I did have to modify one of them considerably, as I will get into in a minute.
I made my own fan blade by cutting it out of a sheet of aluminum. You could use other metals but they won't be as lightweight. You could also try to buy a fan blade off of eBay, or rob one from an existing fan.
Step 2: Cut a Slice Off Your I-Beam
Okay, so maybe you don't have access to a free piece of an aluminum I-beam, but if you do just put it in the vise between two pieces of two-by-four and saw off a chunk with the hacksaw!
Step 3: Cut Out a Fan Blade
I have included the PDF of my fan blade design if you want to replicate it, and also the image file that you could scale to the size of your liking. Choose one, then simply print it out, cut it out, and lay it on another larger piece of paper (my full size pattern won't fit on an 8.5 by 11 inch sheet) or the sheet metal that your fan blade will be made out of. As the pictures show, trace the blade pattern once, the flip it over and trace it again to make the rest of the blade pattern. Then, simply cut it out with a metal shears, tin snips, or nibblers.
Step 4: Bend Your Fan Blade and Figure Out How to Mount It
Now you have to put a couple of bends in the fan blade. The first pair of bends will be made towards you, the other will be away from you. The pencil lines in the pictures show where the bends have to be made. It is hard to describe in words but the pictures should help you understand. If you are new to instructables, you should know that you can click on pictures to make them larger. Also, some of the pictures have little boxes over them, and placing your cursor over them will display additional details.
I simply held my fan blade down on a board and pushed down on the unsupported part (the part hanging off the edge of the board) to make the desired bend.
To mount the fan blade on the motor, I first tried punching a hole in the middle and forcing it onto the end of the motor shaft. It worked... sort of. The fan blade could still wobble on the shaft. One of the CD player motors I found had a small gear on the end, and I was able to drill a larger hole in the fan blade and force part of the gear into the hole. Now I could just push the gear/fan blade assembly onto the end of the motor shaft. I don't love how this part ended up, as plastic isn't a good choice around so much heat, but it is working for now. I may add some epoxy glue to help it hold up.
Step 5: Brass Parts to Hold the Motor
The pictures above show three of the four brass fittings I used, and how I put them together.
Step 6: Find Something to Thread Into the Spark Plug Hole
The brass parts in the previous step accomplished a lot, namely making a 90 degree turn and adapting up to the size of the motor. However, they don't adapt small enough to thread into the spark plug hole on the engine block. To do that, we have to adapt down to 1/4 inch NPT (national pipe thread). I did have a fitting with the correct size threads, but it was an elbow, so I cut the part off that I didn't want (see the first picture). Then, I had to grind/file the remainder down until I could drive it into the elbow fitting as seen in the second picture. I also had to drill all the way through it, so that the wires to the motor could pass through. I don't have a lathe, so to turn down the part I fed a small headless bolt (I cut the head off with a hacksaw) through the fitting and put a nut on the threaded end. It then chucked the bolt shaft into a drill and as it spun the brass fitting I held a flat metal file against it. Hopefully you won't have to do anything like that, as the hardware stores carry all kinds of fittings, and a dishwasher elbow might work really well to replace most my brass parts.
Step 7: Assemble Your Fan, Part One
Okay, so lets jump to assembly. I will fill you in as we go along. First, we start with the base, which for me is the I-beam. I cleaned up the top part nicely, then set the chainsaw engine block on top of it. I fed a Phillips head screwdriver through the block and down through its mounting holes, then tapped the screwdriver to make a mark. I did this for each of the holes to show me where to drill. Then I drilled the holes in the I-beam.
Step 8: Assembly, Part Two
First, feed the wires of the peltier plate through the engine block. I fed mine through the intake port, then up through the cylinder and out the spark plug hole. I had the brass fittings installed up to the elbow, but you will have to determine the best way to feed the wires. Next, lay the peltier on the I-beam, followed by another piece of metal to bridge the hole in the bottom of the engine block (I cut mine from a scrap part of the I-beam I cut off). The peltier supposedly has a "hot side" and a "cool side". The hot side is the one that should go against the I-beam. If the hot side isn't marked, you can touch the two wires of the peltier onto the posts of a car battery very briefly. The side that gets hot is the hot side.
This would be the point where you would want to spread heat conductive paste between the mating surfaces of peltier and the different heat sinks, to help with heat transfer. I don’t have any, but you could either try to scrape some off of old CPUs or you could just buy some off eBay.
Step 9: Assembly, Part 3
Now, feed the little bolts through the holes and tighten them down.
Step 10: Assembly, Part 4
Now, finish assembling the brass parts if you haven't already. I should mention that I drilled three holes through the brass and tapped them with threads so that I could thread little #4 bolts through them to tighten down on the motor. You can see it in the last picture. You don't have to do this, as you could use only one hole w/bolt, or you could use epoxy glue. Or, better you don't use glue, as you might want to take the thing apart. Solder the wires of the motor to the ones of the peltier. Insulate one of the connections with a little RTV gasket maker or electrical tape. Put the motor in its place and tighten it down.
Step 11: Finish!
You can finish by attaching any heat sinks you want to the engine block. I attached one using the existing holes and bolts that held the muffler on. The very last thing to do is attach the fan blade and place the whole thing on a hot stove and see if it spins. If the motor spins the wrong direction, you will have to switch the wires going to it.
To be honest, my fan still needs some work. The heat sinks I used looked good, but don’t shed heat very well. Also, I used plastic to hold the fan blade on, which might not hold up under extreme conditions. The wires of the peltier get hot, and the insulation gets soft. It could probably be better protected. Anyway, some things I need to work on. Thanks for reading, and if you have the time and are so inclined don’t forget to comment or vote on this instructable! It means a lot. Happy making, Hulkbuild out.
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    28 Discussions
    zacker
    1 year ago
    Wow...this was a pretty cool version of these types of fans... i actually made one a couple years ago but my stove gets so hot it melted the plastic parts in the motor... lol but it worked pretty nicely for the ten or 15 minutes that it did work... lol
    SacredDemonzacker
    Reply 1 year ago
    Did you ever find a solution that worked to distribute the heat?
    I bought a $150 ish version of this and broke it the first night because I didn't realize my fireplace was too hot for it... lucky they didn't question the return. However for the couple hours it worked it really helped spread the heat evenly through the house and looked like that might reduce the amount of wood I needed burn.
    zackerSacredDemon
    Reply 1 year ago
    no i just basically gave up and moved on...lol i dont think i could make one that wouldnt melt..unless the motor is all steel with no plastic in or on it at all.
    hulkbuildzacker
    Reply 1 year ago
    Even if there was no plastic in the motor, the magnets inside it would loose their pull at high temperature, so it seems to me that keeping the motor cool is a big priority.
    zackerhulkbuild
    Reply 1 year ago
    yeah I guess maybe i should try it with a taller riser block...
    RobertD235
    1 year ago on Introduction
    Dielectric grease, white type is similar to what auto manufacturers use in ignition distributors and is easier to find than heat type grease and supposedly works near the same available at most auto parts stores or anywhere that sells hardware.
    Vaseline also supposedly works, but might melt out..
    Model airplane propellers an alternative to making one... Or for something that doesn't end up looking like a motor. make the heat power transfer unit to power a computer cooling fan.. many are 5-12v. .(and as long as it mentioned salvaging parts from old computers..but desk top might be useless if have 110-120v ones... .) or even as a battery charger...
    The peltier units also have various voltage and amp output voltages and might need more or less of them for required power for want ever motor fan running..
    Might need to also find a voltage regulator of some sort, or might burn out the motors..
    What ever peltier unit needed They appear Cheap to buy and relative to cost of buying something prebuilt,... and it easy to build one using the same principles described here..
    I'm hoping to eventually build one for my various heaters,, could also build one for taking camping... tent use.. The only place I've ever seen these was in boat parts supply stores and are expensive relative to what look like cost to build..
    An entire unit or all parts could be salvaged from 12v portable coolers. If weren't trashed because something in them stopped working. A lot of them gone to the trash or thrift stores because use too much power to practically be used or were rarely used.
    hulkbuildRobertD235
    Reply 1 year ago
    Thanks dude! I will have to look into that, as any kind of silicone lubricant would probably help with heat transfer. Maybe lithium grease would work!
    RobertD235hulkbuild
    Reply 1 year ago
    I read somewhere online about dielectric grease and it specific for preventing or protecting from heat transfer and or also to protect from corrosion, and not as a grounding assistant,
    I always thought it was for enhancing conductivity but only does by protecting from moisture, corrosion where contacts might not be tight
    The stuff used in automotive distributors is supposed to be different, specific for heat transfer but when replacing similar modules on heat sinks anywhere it usually advised to just use dielectric grease, if can't get the OEM stuff.. As previously noted. I use the white stuff because just looks the same, but use the brown black stuff on extension cord plugs I've had out in the weather for years or other plugs.. .
    It appears it doesn't conduct, otherwise some of my plugs would have shorted out from having too much on them..
    While a petrolium grease might have and it noted vasoline has the same properties and near the same performance . I'd be inclined to stay away from petrolium products in a high heat application and go with the stuff that is...
    I think I saw to use Vasoline on battery terminals also to keep them from corroding, but other greases might work the same
    OttofarAway
    1 year ago
    Great Idea!
    You can salvage high temperature cables from an old Iron and crimp them to the cables close to the Peltier Element - do not solder!
    hulkbuildOttofarAway
    Reply 1 year ago
    Good idea! Now that I think of it, coffee makers have wires inside that are heat protected, I should use those!
    dave.maunder
    1 year ago
    ...built one years ago (rough pic) inspired from another hack-a-day/instructable build project (the good pic). It was candle driven only though.
    Its been sitting in the shed for years; however your build has just made me think about pulling it out, modifying it a little to sit on our wood fire for this winter. Had never thought of doing that until now. Nice build by the way of using the chainsaw block.
    hulkbuildbongodrummer
    Reply 1 year ago
    Absolutely, I will give it a vote as soon as it gets accepted into the contest. It looks like you did a great job, I will have to read it more thoroughly when I get a chance. It may help me improve my design. Also, I got the link to your YouTube video added into my instructable. My vernier calipers is not digital, so it is hard to make precise measurements, but I think the aluminum I made my fan blade from is about .045 inch thick. A little thicker than it needs to be, and my fan blade is a little big, but it works for now. Good luck and let me know how it goes!
    bongodrummer
    1 year ago
    Nice. I am guessing you watched my youtube video https://goo.gl/PwNwhr or read my blog post here http://www.floweringelbow.org/2018/wood-stove/maki... on the subject of making a stove top fan like this from an old chainsaw cylinder using a brass elbow. If so (and I haven't seen the idea anywhere else on the net), how about showing me some love with a link in your 'able? It was a kinda original idea...
    Either way, I like your twist on it and a nice write up. I had to sigh, as I am about half way through writing up an instructable for the trash to treasure contest too... Have some new things up my sleeve though ;)
    Peace, B.
    Reply 1 year ago
    Yes, your video was one of the ones I watched, and I was definitely inspired by the engine block and pipe elbow you went with in your design. It was a great idea, and i don't think I would have went that way if i had not seen your video, so I will gladly add a link to your video as soon as i get the chance. I feel a little bad that it didn't occur to me to do that in the first place, but thanks for being such a good sport about it. Oh, and sorry if I spoiled your trash to treasure plans. I Know how that feels. Good luck in the contest, and if you get something posted let me know and I will give it a vote. Glad to know you are part of the community. Happy making - Hulkbuild
    bongodrummerhulkbuild
    Reply 1 year ago
    Dude, you made my day! The whole point of doing the vid in the first place was to share it, and it's really cool to see how you ran with the idea.
    I really appreciate you adding a link somewhere in there :D
    I'll be sorta competing but good luck in the contest. B.
    PS how thick was the Alu sheet you used for the fan blades?
    cirbuck1
    1 year ago
    Just for academic completeness or those that like to research such things, if you are using a Peltier Junction this way it is called the "Seebeck Effect". It's Peltier if you are creating hot and cold from electrical energy in, and it's Seebeck if you are putting in heat and getting out electricity.
    goldenskyhook
    Question 1 year ago
    What exactly do you mean by a "low voltage motor?" I've got a couple of computer cooling fans around. Would those work? Pretty sure they're 12v. Some specifics would be nice as to how much voltage, current, etc. are generated by the heat exchanger.
