Heat Treating Knives
251,619
261
35
The purpose of heat treating is to bring steel to a hardened state. The correct hardness depends on the application of the steel being treated. Knives need to be hard enough to hold an sharp edge through continuous mechanical abrasion, yet be soft (flexible) enough to stand up to forceful use without breaking.
Equipment and tools:
- Visegrip pliers or tongs
- small forge or charcoal fire of sufficient heat (search for forge or smelting instructables)
- fire proof quench container with lid (I used an old cookie tin)
- quenching medium such as used motor oil
- BC fire extinguisher (the kind that puts out grease and oil fires)
- Heat resistant gloves and face shield.
- kitchen oven
- fireproof material for regulator block (I used aluminum tube)
Materials:
- one mild or high carbon steel knife blank (forged or stock removal)
The quenching method I decided to use for this knife was the “edge quench”. I learned this method from $50 Knife Shop by Wayne Goddard. Instead of dropping the heated knife into the quenching medium tip first, submerging the entire knife, the edge quench involves submerging one third to one half of the blade's width (cutting edge first) into the quenching medium. A regulator block is used to hold the blade at the correct depth. The quenching medium I used was old motor oil. After the blade has been quenched, its hardness is still not suitable for usage. In its hard and brittle state, the quenched blade will shatter like glass if dropped, it must be tempered before it is put to use. Tempering involves heating the blade to a non-critical temperature (350 – 450 F) to slightly soften the steel (I used a kitchen oven). A tempered blade will hold a sharp edge and still retain strength and flexibility.
Step 1: Surface and Edge Preparation
The heat treating method is the same for knives made from forging, or stock removal. Whatever method you used,the final bevel should be on the blade and the surface should be brought to the desired finish. This was one of my first forged blades and I found the hammer markings appealing, so I did not polish the blade to a mirror shine, but I used a file to cut the bevel and a rough stone (100 – 200 grit) to get it fairly smooth, and as even as possible. Remember, once it is hardened, it will be much more difficult to remove material via filing and sanding. The edge is the thinnest part of the blade, and therefore more prone to cracking during the quench. Use a strip of 150 grit sand paper to dull the edge and reduce the chance of cracks or warping in the edge.
Step 2: Normalizing
Normalizing involves bringing the unhardened blade to critical temperature a few times to stabilize the structure of the steel. A normalized blade is more resistant to warping during the quench, although some degree of warping is unavoidable.
Heat the blade evenly and touch it to a magnet to test its temperature. Steel becomes non-magnetic at critical temperatures, so torch it, test it against the magnet, and let it cool to room temperature three times to normalize it.
Step 3: Quench Setup
I used this aluminum tube for the regulator block. You won't be able to see past the surface of the oil, so I used nails to indicate the position and direction of the block below the oil.
The quenching container MUST BE FIREPROOF! Do not use plastic Tupperware! It is also a good idea to have an airtight lid for the container to smother flames. I filled the container with water and marked the water level with a red marker (see photo) where the the blade rested one third to one half its depth under the water's surface on the regulator block.
In order for the oil to provide the right qualities for quenching, it needs to be warmed. Wayne Goddard says that cold oil “is not wet enough”. $50 Knife Shop suggests the oil should be 90 – 140F , but I just used my finger to judge when the oil became bath-water warm. I used a hotplate set on LOW HEAT. Heat the quench container filled with water first to get an idea of what heat to use for the oil.
Step 4:
Before you even start up the forge for the quench, prepare your work area by laying out all the tools and equipment you will need for the process. Make sure you have your container lid and a few sets of pliers. Make sure you have a BC fire extinguisher (the kind that puts out grease/oil fires) nearby. Mentally rehearse all of the steps you need to make.
The most important detail is that the knife enters the oil at or above critical temperature. The sequence I use is to heat the blade until it becomes non magnetic, then stick it back into the forge and push/pull the blade's full length through the heat once more, making sure the piece is evenly colored. When the blade comes out of the forge, you should move it into the oil slowly enough not to splash oil, and quickly enough not to lose significant heat. Be prompt about it.
Dunk the hot blade into the oil, onto the regulator block for approximately 15 seconds.
After the 15 seconds, submerge the entire blade into the oil beside the block.
Note: The reason the regulator block is used instead of simply filling the container with enough oil that the blade rests 1/3 to ½ its width against the bottom of the container is so that the blade can be fully submerged after the edge hardening. Laying the blade on its side without a regulator block to fully submerge it risks warping due to one side of the blade being cooled faster than the other.
When the bubbling and hissing of the oil subsides (around 45 seconds, time is not critical here) pull the blade out and allow it to cool in open air. Put the lid back on your quenching container to smother any flames.
Step 5: The File Test
Take the quenched blade to your bench when it is cooled. Rest a file on the bevel of the blade and move it back and forth, up and down the length. If all went well, the file should feel glassy as it slides across the bevel. Compare the file's “bite” on the bevel to the unhardened area on the tang. There should be a noticeable difference in the file's exchange with the steel.
Step 6: Tempering
A Note on Tempering: Every article I have read on tempering gives a notice to knife makers who choose to use their kitchen's conventional oven for tempering. Every piece of literature related to backyard knife making I could find gives a foreboding note about angry women coming after you for smoking up their kitchens by leaving motor oil covered steel scraps in the oven.
Some suggest buying a toaster oven for the sole purpose of knife tempering. I just scrub the hardened blade in water with dish soap and then hit it with a wire brush attachment in a power drill and then another soapy water scrub. This seems to get off the majority of the oil, and I have never noticed a smokey smell. Be sure to dry the blade before it goes in the oven. Recommendations for tempering temperatures vary, If you know precisely what type of steel you are using, search online for the correct temperature. The knives I have made are what I assume to be mild steel, coming from sources like hedge clippers and lawnmower blades. With my lack of metallurgy expertise admitted, I temper at 400F.
Cook your blade for one hour, allow it to cool to room temp, and return it to the oven for another hour.
After 3 one hour cycles, the tempering is complete. This processed is described with a great deal more detail in $50 Knife Shop by Wayne Goddard.
Step 7: Finishing the Blade
During the heat treating process, the surface of the steel was likely marred by scale buildup and oil residue, so it will be necessary to re-finish the blade to the desired level of quality. I used the roughest stone I have (100 – 200 grit stone from the hardware store) to put the edge back on the blade. From here, work your way up through your stones to achieve the desired edge.
  • IoT Challenge
    IoT Challenge
  • Gardening Contest
    Gardening Contest
  • Classroom Science Contest
35 Discussions
elikimchi
1 year ago
Mild steel does not harden. You should use steel with at least 0.5% carbon, preferably 0.8% to 0.95%.
taibhsegaeilgeelikimchi
Reply 1 year ago
It can be hardened, but in practical terms only for the first few mms. You will need to employ an old technique called case hardening. It is impractical because it is expensive. The case hardening material is actually very easy to make. You can but it but it stupidly expensive. It gets expensive because you need to weld a case, put the part in it with the hardening powder, then heat it extensively in a kiln which is expensive on the electricity supply. Anyway once you have soaked it in the kiln at temp for many hours, leave it overnight, crack it open and you will have a case hardened Piece of steel.
taibhsegaeilge
1 year ago
okay, after reading this, there are some guides I can add. I am from the UK, so 40°c is the temperature I was taught as a journeyman Smith. For oil quenching steels. When quenching in water cool but never cold was always the rule of thumb. And as for warping of the blades. I know it does happen, it has happened to me on occasion but it is VERY easy to fix, sometimes it is unavoidable. I have found it happens more with laminated steels and the twisted damascus types.
Perhaps this is due to one side always being under more tension than the other due to the twist? Just a theory.
Anyway, I digress....but if there is one piece of advice I can offer, if you want to make lots of blades, make yourself a belt grinder/sander. I did, and it saved me many many hours/days/weeks of endless filing. Just go ahead, make a couple of decent knives, and don't hold back on the finish and you will be begging for a belt sander.....trust me.
kalboon
3 years ago
I hear treated some blades last night and they came out COVERED in all kinds of crud, would you have any useful advice for me? Lol, I'm desperate lol
HamburgerHelperkalboon
Reply 2 years ago
Put wd40 on it and scrub it off with sandpaper ij the direction that you want your grain
samn63kalboon
Reply 2 years ago
This has to do with the metal you are using specifically. At higher temperatures, metal, especially carbon steel, oxidizes at higher rates. With the specific "A" number of your metal, it seems to have few deoxidizers, meaning it will oxidize in the air quicker than if it had increased levels of Silicon, Aluminum, or Manganese. Try a different metal, and spend a little extra to get some good stuff if you want solid results.
finnishknifemaker
2 years ago
I just heat treated and tempered my blade to brown/straw as you showed here, but the edge was still too fragile and the tip broke. So my question is: Is possible to heat it too hot before quenching? Blade was almost bright orange in the daylight when I quenched it. And I´m 100% sure I did tempering correctly. Please help me so I can avoid this in the future.
jcarter35finnishknifemaker
Reply 2 years ago
It's really hard to see the color in daylight - our forge is pretty dim so we can see it pretty well. But even then, I don't usually trust my eyes for the quench. To make sure it's ready, you can get a magnet and hold the blade near it. If it's not attracted to the magnet, you've reached the right temperature. Just be careful - if any part of you gets between the blade and magnet, you can get a red hot knife stuck to your finger!
RobertV86finnishknifemaker
Reply 2 years ago
Quenching should be done when the steel reaches a bright red colour, 800-900 fahrenheit. Forging and shaping the steal is done at a bright yellow/orange colour, 1700-2100 fahrenheit. quenching at temperatures over 800-900 degrees can result in a brittle blade and/or your blade could warp or crack.
samn63finnishknifemaker
Reply 2 years ago
Quenching and Tempering refer to two specific heat treating processes. It seems like you may not have tempered 100% correctly. Quenching is much easier, and only requires that the metal reach Austenizing temperatures and then is rapidly cooled. Tempering on the other hand, is much more specific. It requires a quenched material, quenching being as described above, be taken to temperatures below the first transformation temperature of that specific alloy (normally 1100-1300) and held for 1 hour per inch of material. It is then cooled in the furnace, dropping temperatures roughly 400 degrees per hour (again, depending on the alloy) down to 700 or 800 degrees (again, depending on the alloy) and then air cooled. Higher alloys require controlled cooling to much cooler temperatures, as they commonly are more suseptible to diffusion (oxidation basically) at lower temperatures. Hope this helped. I fear they use their heat treating process labels loosely around here.
jcarter35
2 years ago
Just so you know, quenching and tempering have little to no effect on mild steel. You will still see the color appear from the tempering process, but there isn't enough carbon present for the metal to harden properly. As for the material you've been using, in my experience, anything that cuts is usually at least medium steel - so you're good there. Lawn mower blades are highly prized junk steel! If you want to go all out (affordably) get some leaf spring from a junkyard. Most of the swords I've made started as leaf or coil spring. It's good stuff. Thanks for the instructable!
JacieT
2 years ago
I have quite a few knives I would like to have tempered so that they cut better. You mentioned that when tempering a metal blade, it should be between 350-450 degrees Fahrenheit. At what point does the metal start to melt? http://www.pacmet.com/index.php?h=capabilitiesandservices
samn63JacieT
Reply 2 years ago
This is actually misleading and has to do with their use of "Tempering". Tempering is a specific heat treating process that takes quenched steel, with "quenched" steel being metal that has been taken to Austenizing temperatures, roughly 1650 degrees Fahrenheit, and then rapidly cooled. Once that has been accomplished, the metal is then taken to temperatures below the first transformation temperature, roughly 1100-1300 for 1 hour per inch of material. IE 1" material would be kept at that temperature for 1 hour. It is then furnace cooled, dropping roughly 400 degrees per hour to 700 or 800 degrees and then air cooled. Varying the temperatures, while obeying the two critical temperatures and time constraints, should give you an ideal "temper".
Hal0427
3 years ago
These instructions are great! Now if only I follow them.
McGuyver_09
3 years ago
I have never heard about having to heat the oil before quenching the work piece, but it does make sense I suppose. I found in all my years of metallurgy experience used diesel oil works the best and doesn't have to be warmed prior to using due to multitude of additives and relatively thin viscosity once used. Basically the purpose of this is merely to cool the metal at a slower rate to prevent stressing the metal to the point of fracture, and it also replenishes the carbon content in the steel allowing it to hold a sharp edge. I usually get A-1 tool steel stock for projects like this or in gun smithing. There is also a cool little color chart BTW a great source for high carbon steel suitable for knife making is at saw shops, or any place that deals with replacing the blades of wood chippers, industrial sheet metal shears, old school paper cutting boards. etc.
kalboon
3 years ago
*heat treated lol
kalboon
3 years ago
*heat treated lol
cmcustomes1991
3 years ago
ok i have been doing about 1 1/2 on google and youtube and made my first 2 knifes out of a lawnmower blade no tampering no hardening and holds an edge pretty desent but my main question is is there differnt temps for different types of carbon steels
Steel TitanFcmcustomes1991
Reply 3 years ago
Absolutely! A lot of it is trial and error, but I suggest looking up a steel heat-treating chart.
curvy77
7 years ago on Introduction
you say that in its quenched state it is still brittle. but with the blades i have made after i quenched them they were still very strong.
