Heated Boots
9,018
128
58
About: Hi! I make different things :)
My girlfriend often waits for a bus during 20-30 minutes. There is -5°C...-20°C sometimes. And today I want to show you my solution.
In the video you can see the test of this boots in beautiful New Year Helsinki.
Pleasant viewing :)
Supplies:
Step 1: I Used:
1) Wool Insoles like this:
http://s.click.aliexpress.com/e/ccScfELQ
2) Heating Nichrome Wire. I used 0.4mm:
http://s.click.aliexpress.com/e/jL1nvwo
3) Batteries Li-ion 18650:
http://s.click.aliexpress.com/e/bnXXyPtQ
4) Power Bank Case (5V, 1A):
http://s.click.aliexpress.com/e/zRJrt9q
5) Hand made USB powered cable for 5V, 1A.
6) Sewing Elastic Rubber 40mm:
http://s.click.aliexpress.com/e/bdAQtCMu
Step 2: Nichrome Wire.
I cut 65 cm of nichrome wire. It takes 5V, 0.7A for one foot. Insoles warm up to +49°С.
Step 3: USB-cable
I tested some USB-cables, but they could transfer only 0.5A unfortunately. And I made my own.
Step 4: Soles + Wire + USB-Cable
I sewed the wire and USB-cable to insoles. Nichrome wire couldn't solder, so i used needle with thread.
Step 5: Batteries
I used new li-ion batteries 18650. I tested it's capacity = 3400mAh! It's great :)
Let's calculate battery live time.
Battery has 3.7v and 3400 mAh, but Power Bank voltage transformer gives 5V.
So battery into case should has capacity: 3.7*3400/5 = 2516 mAh.
The nichrome wire "eat" 0.7A, so battery live time: 2516/700 = 3,6 hours. Voltage transformer efficiency, I think, 90%, so we have 3,6*0,9 = 3,24 hours.
It's about 3:15.
Will check it latter.
Step 6: Temperature Test
I got 21°C (without nichrome wire) and 49°C (with). Cool!
Step 7: Put Inside
Step 8: Strap
I sewed straps using 40mm rubber and velcro.
Step 9: Results
Hid under jeans :)
Step 10: Conclusion
We tested heated boots in Helsinki on the New Year holiday. It is a beautiful city! But it was so windy.
We were walking about 8 hours every day. And these boots were saving Masha.
Masha is happy. Me too :)
Live test showed they are great boots, don't causes discomfort. Live time about 2-3 hours. We didn't check the exact time.
But USB contact was bad. I want to change it to other connector type.
PS: Sorry for my bad English, I am still learning. You can correct me (please).
PSS: It's my first instruction, so I will be happy to read your opinions ;)
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    58 Discussions
    GeedieZ
    3 months ago
    What about safety? I keep hearing about exploding li-ion's now and then. Doesn't that worry you?
    KillmyfeelGeedieZ
    Reply 3 months ago
    Yes, I worry about that. But Power Bank has short-circuit protection inside. Besides we all use li-ion in our phones. I don't know what should happen for explode. Maybe I must put my leg into water knee-deep))) Or be crashed by car bumper...
    Lee WilkersonKillmyfeel
    Reply 7 weeks ago
    I don't believe you will have any problem with water shorting because you're only using 5V, however it might just tingle your foot soles if you have standing water in the boot or sock. It would be similar to but less than the effect you get from sticking a 9V battery to your tongue.
    MillerIGeedieZ
    Reply 3 months ago
    When you talk on the phone, the Li-ion battery is millimeters from your face. Now what?
    Lee Wilkerson
    7 weeks ago
    Great! I have been trying to come up with something like this for decades, but I just never got to it until now.
    Thank you very much from me and my cold feet.
    MillerI
    3 months ago
    I really like your 'Ible. It reminds me of times when I lived in a region that required such drastic measures (American Mid West).
    Try using a USB-C cable. They are spec'd and designed to handle the higher loads. Just got a new Chromebook and it wouldn't mobile charge rapidly on regular USB adapters. Got the USB-C adapter and cable and now getting 2.2A charge!
    Cheers!
    KillmyfeelMillerI
    Reply 3 months ago
    Thank you!
    But I don't need more then 0.7...1.0A :)
    MillerIKillmyfeel
    Reply 3 months ago
    Last I checked, 2.0A is a bit more than 0.7 or 1.0. :-)
    jackreno11
    3 months ago
    Very interesting project! Well done!
    It's cool to see some other creators using AliExpress, I feel like it's really overlooked for the kind of deals it has. Especially using the power banks. I've got a few projects in the works using the same parts!
    smokebox
    3 months ago
    Interesting idea to use nichrome wire as a heating element! There was an emphasis on learning a second language in American high school in the 1960's, but it is apparent that
    Americans have become even more insular since then. It is now mostly American women who graduate from American colleges. I am glad that Finns are still interested in other languages!
    Killmyfeelsmokebox
    Reply 3 months ago
    Thanks for comment!
    It's interesting to know somethings about Americans :)
    But I'm not from Finland, I'm from Russian (Saint Petersburg). We celebrated New Year in Helsinki.
    And nichrome wire is standard element in many heating things.
    smokeboxKillmyfeel
    Reply 3 months ago
    I should say that I am glad that Russians (and Finns) are still interested in other languages. This is the first time I have seen fine nichrome wire woven into clothing as a DIY project:) I usually think of nichrome as something difficult to work with, and carbon heating elements seem most popular for this kind of application..
    Killmyfeelsmokebox
    Reply 3 months ago
    Yes, carbon heating elements better for clothes
    wclapieandb41
    Reply 3 months ago
    I wonder if nichrome wire could be soldered with silver solder?
    tem494
    3 months ago on Introduction
    Nice job just wish I had this when I lived in the colder part of the country it would have saved my very cold feet.
    Don’t worry about the English there are people that live in the US that do as well as you do keep up the good work.
