Helical Vawt (blades and Charge Controller)
62,957
627
18
About: general bloke type of tinkering
A PVC bladed type of helical wind turbine, inspired by the 3 bladed version of TyPower2. In an attempt to emulate the Savonius profile, I used a heat gun to curve the blade tips.
To produce usable power one needs:
  • a turbine, wind or water.
  • a generator, coupled to the turbine.
  • a rectifier to convert the ac output from the generator to dc for battery charging.
  • a storage battery, usually lead acid deep cycle.
  • a charge controller to prevent overcharging which kills battery life.
This instructable deals with the turbine construction, which will be matched to an optimum generator( no idea yet).
The rectifier will be 2 x Full Wave Silicon Bridge Rectifier 35A 400V, more than adequate, but if you have access to a 3 phase rectifier, so much the better.
For the charge controller, I'll be using the Mdavis19 award winning 555 design, the updated 555 design on his website.
I havent had much success with diy pcb's, so I'm going the veroboard route using DIYLC v3 for the component layout software.
Step 1: The PVC Blades
The design began with an idea of 1 metre wide turbine and evolved from there. Using 40mm dia pvc tube, I would need 30 blades to achieve my initial 180 degree twist, which meant the height would be in the 1.4m range.
I sliced the 30 0.5m sections in half and used a pvc joiner for cost reasons, Id only need 15m of tube instead of 30m using other cut methods. First a jig was built to see how feasible it was to cut pvc length wise, it worked well enough and so each 1/2m section was marked prior to the tedious cutting job.
When making 4 marks on the tube the 2nd set of marks always seemed to rotate in relation to the first set, and so I devised an easier method. I made 2 marks on the tube 180 degrees apart and on a table, leaned a ruler against the tube and then drew a line down the tube.
Main tools used here were the jigsaw, a small desktop drill press to make the perpendicular axle blade mount holes, and a lathe to cut out the ridge inside the pvc join fitting which prevented the tube from sliding right through, I wanted a bit of overlap to make a better blade joint.
Step 2: Blade Tip Bending Jig
This was my method of bending the tips into an approximate ideal Savonius shape using a heat gun and plywood jig. Hindsight has shown that it would have been a better idea to have had a full length jig to clamp down the main section while the tip was being bent, but it seemed quicker at the time to have a dowel for length indication in the back.
A dry test fit will highlight if any blades touch each other due to too much tip twist, keep the heat gun handy to rectify twists or warps.
When heat forming keep a cool wet cloth handy to "set" the hot bend with a quick wipe when you have it at the desired shape, it also protects your left hand that holds down the tube while forming it.
Main tool used here was the heatgun on low power which was sufficient to turn the pvc into soggy spaghetti, the forming temp indicator.
Step 3: Holding It Together
The frame has to be resistant to twisting to prevent the binding of the upper and lower bearings due to misalignment, as well as provide a housing for the bearings. The vertical and bottom arm are 25mm x 50mm x 1.6mm rectangle steel, the top was a scrap 25mm x 38mm that was at hand.
For the bearing recesses, I cut a slice out of a steel tube, squeezed it shut around the bearing and slid it into the hole in the ends of the cross member arms.
The bearings are 6000zz type with a 26mm od, the tubing wall thickness was 1.2mm which required a 29mm bi-metal holesaw. A thinner slice of tubing creates a bearing seat stop.
The 6000zz has a static load rating of +/- 198kg and being a deep vee ball bearing, can accomodate an axial load of 99kg, my blade assembly weighing 13.5kg is therefore well within the design limits.
The corner bracing was provided by 200mm sections of 19mmx 3mm thick flat bar.
Main tools used were the welder, small angle grinder and a 29mm bi-metal holesaw in the drill press.
Step 4: The Charge Controller
As I mentioned in the intro, I'll be using the Mdavis19 555 charge controller. In the link to step 8 he is still using his first version with the LM339 chip, but his website has the full 555 version details including fine tuning and test point voltages.
I've made a few substitutes, a 1455 instead of the 555, a 330nF 100v instead of the 0.33uF 35v and a 2N3904 instead of the 2N2222, and the circuit worked first time for me as well. The set points for charge and dump at the test points are on the Mdavis19 website, 1.667v for the lower charge setting and 3.33v for the upper dump setting.
I've included my veroboard version with a DIYLCv3 software screenprint containing the components that I used, mostly because that was what was available, as well as the *.diy project file. In the project file you will be able to see all the cut tracks indicated by a red dot square combo.
Be aware that the software doesnt have a way to view the copper track side in reverse, so I marked all the cut-tracks with a fineliner on the component side and then flipped the actual board to do the cutting.
My scrap veroboard was 14 holes by 32 tracks, hence my particular layout, but its not necessarily the best way to do it.
Main tools were a side cutter and soldering iron.
Step 5: Some Odds and Ends
I used baby bottle teats as weather protection for the top and bottom bearings, packed with grease for added protection.
I used the large flange rivet head but found it undesirable with curved pvc, it tended to distort the blade as it was being riveted, my partial fix was to slice a section off to lessen link strip distortion. I was distracted by finding the optimum position of the rivets to lessen blade distortion and failed to check the blade to blade distance(50mm) and as a result created a 110 degree twist instead of the 180 degrees I initially wanted.
Once the blade halves have been joined they need to be individually balanced before being assembled as a group onto the main axle. A screwdriver in a bench vise will do for the axle. I used a pruning cutter to cut the edges of the heavy side until each blade sat fairly level.
The main axle is 12mm OD with a 10mm ID, the 6000zz bearing also has a 10mm ID, and so I used a polished 10mm OD thick wall ss tube slid through the bearing and into the 12mm main axle as a means of making the bearings accessible for replacement if necessary. Cross drilling and cotter pins mechanically link the bearing shaft and main axle, the blade group assembly is also mechanically coupled with individual pop riveted link strips.
The main tools were the drill press for the cotter pin holes and a plier type pop riveter.
At this stage I have no idea in mind for the generator section, but I have it in mind to take some torque vs rpm measurements once the wind picks up from its current gnat burp and update this 'ible accordingly.
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    18 Discussions
    Steinzel
    1 year ago
    Thanks for this one! Been looking for a good DIY charge controller for a while. Love your blade design! Makes me want to dig deeper into this type of VAWT. You Rock!
    petercdlokesh.vohra92
    Reply 4 years ago on Introduction
    Sure, but it might have to power matched depending of the generator rating. My intention was to couple a stepper motor underneath it but that hasn't transpired yet.
    mperrault1
    5 years ago
    Nice work. Would be a great project to fiberglass etc as the weight of the PVC will limit the efficiency.
    petercdmperrault1
    Reply 5 years ago
    Fiberglassing's not really my thing, somewhat messy and as a result, I dont have a wealth of experience with that media.
    The swept area is 950mm X 1380mm with a combined pvc and axle weight of 5.35kg's, would fiberglass be much lighter?
    ghatchpetercd
    I don't know about your axle weight, but with the swept area you mention a single layer of 6oz carbon fiber sandwiched between 2 layers of 6oz fiberglass and epoxy would weigh between 1.7 - 2.0 kg depending on how well it was glassed. With a simple "male" shaped jig you could build the curves right into the part. The connectors would weigh extra.
    As mentioned above, building it like a sail w/frame and battens might be cheaper, easier and weigh less than fiberglass. .
    SirRahKnight
    The simplest way to cut PVC tubing in the center is to take a finish blade (fine tooth) and reverse mount it on a table saw then set the fence of the saw to center. You can cut the tubes to length and laterally very quickly and easily, without the ingenious jig for the saber saw. I have used this for many PVC projects and it works very well.
    Boobr
    few days ago I was put together outer section of ac motor (two coils with metal core) and some just fitting 6 poles cylindrical ferrite magnet (no idea where it was been used originaly, probably in some dc motor) on shaft with two skateboard bearings, first tests with LED's and low voltage bulbs powered just by hands and piece of string done and in next few days I will try to assembly it with proper casing (some machining needed) and measures will come, I also was planning to turn it by "traditional" propeller type turbine but your article inspired me a little ;) i also think that you may find this: http://www.projectfreepower.com/wind-power/homemade-1000w-wind-turbine.html project interesting
    I appreciate the Artistic elements to the design. When that is coupled with the clean energy production you have a win win scenario. Kudos on the project!
    pulrich1
    Hey couldn't you could take a weather resistant fabric, such as sunbrella type, and make a rectangular frame with a vertical pole in the middle, then mount the fabric to the frame, then rotate the short sides in opposite directions about the vertical pole about 90 degrees and come up with the same shape in a lot less time, cheaper?
    petercdpulrich1
    A plain twist would fail to rotate due to equal exposure to the wind, I also suspect a lot of wind pressure would be lost due to wind spiraling up the twist, so you would need added horizontal fins or disks to reduce wind spill.
    The design problem would be to create less drag on the one vertical half, probably with a vertical curve in the outer edge, tricky to say the least.
    Marucotchan
    What is the generator? because the project is done right, and in an innovative way, but I wonder what is the gardor or shape utilisou to generate energy, it is only shown that the controller used is quite accurate, since the components used are appropriate for the project .
    He has speed limiter?
    Since ja congratulations on project
    petercdMarucotchan
    Still thinking about the generator.
    No speed limiter, maybe not needed with a drag type vawt, but an option is a dump load resistor which could keep the speed down when the device is not charging.
