Hex Nut D6
26,040
81
16
This is a new spin on an old classic. I have played table top games for years spending many nights exploring dungeons and fighting dragons, my trusty dice by my side. A slow day at work i was playing around with some nuts and bolts and came up with this fun idea, and thought it make the perfect Christmas gift for my gaming group.
Step 1: What You Will Need
You will need (note: I'm making a 1/4 inch pieces you can do bigger pieces out smaller if you want)
6 1/4 hex nuts
1 1/4 x 2 inch carriage bolt
making tape or painters tape
sharpie
glue
drill or electric screw driver
spray paint
not pictured
tooth picks
Step 2: Setting the Hex Nuts
the first piece you want to get on as tight as possible.
use a tooth pick to apply a decent amount of glue just around the top of the nut make sure to not get to much in the threads
after the first nut it is more important to be straight than tight get it as tight as you can but a uniform straightness is what we are looking for
continue repeating this step till all 6 are on there the 5th but i put a little more glue on to make sure everything stays in place and on the 6th i didn't put any on the top as to give the final product a more clean result
Step 3: Tapping
once you allow the allotted time for the glue to dry
apply tape going around pretty much everything (rule for painting if you don't tape it your going paint it)
i used my finger nail to go around the groves so that i could mark my pips easier (fun fact the dots on a dice are called pips)
Step 4: Mark Your Pips
take your sharpie and mark your pips make sure opposite sides add up to be 7 the order i did was 1-5-3-6-2-4
Step 5: Drill the Pips
if you have a bench clamp id recommend you use that i don't so I just used a wrench
for the drill bit i used a 1/8th bit
just go one side at a time
try to get them straight as you can but i recommend when you start you have to comitt to it if you mess up the tape i will show a fix in the next step
Step 6: Fixing Whoops
if you scratch the tape that means paint can get thru all you need to do is get a small piece of tape and cover the goof up and re drill if needed
Step 7: Spray Paint
remember if you don't tape it your going to paint it so make sure it's all covered don't forget the tips and spray paint and allow it to dry
Step 8: Let's Roll Out
once it's dry take the tape off and we're done you can spin it like a top with a little practice or just roll it on the table
well that's it hope you enjoy the idea if you like it vote for it in the home made gift contest
thank you and may the dice roll in your favor
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    16 Discussions
    Mihsin
    2 years ago
    Nobody rolls metal dice on my tables. I prefer same project out of plastic parts, such as kids toy tools, they're already colored and easy to glue and harmless to pockets. I like this instructable.
    FirstSpear
    2 years ago
    Brilliant idea, and I, like others, am struck by its uniqueness. Concerning weight and visual beauty: thinking... mark nuts unmounted, glue them together, take threadless rod and mark opposite holes to be drilled into rod to create even weight, insert rod and glue it in place. File and trim ends of rod so nothing extends beyond the nuts. Absolutely no idea how one would mark the rod's holes, nor how one would actually drill into the surface of such a thin rod, nor how the glue would factor into the weight issues. Would look lovely in brass, though. Steampunk dice. Surely a first.
    jimofoz
    2 years ago
    Very cool idea. Nicely done. I'd use a Sharpie pen to color in the dots for some contrast. Another idea is that they make a long threaded hex connector that might work, but I think your idea of separate nuts looks better.
    Itsatravjimofoz
    Reply 2 years ago
    Yea the copper on silver doesn't show up well my next one will have red or black for sure
    jomahar12
    2 years ago
    I'm missing something here. I see only "1" pip on one edge of the nut, and "1" pip on other edges of the nut....and on some edges there is no pip. The opposite side of the hex nut has to add up to seven....what gives?
    Itsatravjomahar12
    Reply 2 years ago
    you count the entire face you see shook the opposite of 1 is 6 2 is 5 and 3 is 4
    Drake88
    2 years ago
    Just an idea, but using bronze, brass, or copper nuts might also add to
    the 'effect'. Might also want to use acrylic model paint instead of the
    spray paint to make the pips really stand out.
    Also, if you could use two hex bolts for the 'end' pips. Just measure the length of one bolt so that it will meet the other in the middle of one pip(nut). Applying a little super-glue or locktite to each nuts location on the bolt(and a drop or two for the connector nut) before screwing them down should insure they will not move(or separate in the case of the connector nut) for quite some time.
    Altoidian
    2 years ago
    Now, that's both clever and original. I've certainly never seen it before your Instructable. And I've lived around industry and machine shops all my life. Nice!
    Mags Gilley
    2 years ago
    This is a stupid question, however, what is the name of the game or are you supposed to make more?
    ItsatravMags Gilley
    Reply 2 years ago
    any game that would use a 6 sided dice really
    cbowers18
    2 years ago
    Not only are the spots called pips, "dice" is plural; the singular is "die." You have made one die.
    Since there is slightly more weight on the "one" face than any other, and slightly less weight on the "six" face (one drillout vs. six), this die will tend to roll a six slightly more often than any other number. "Professional" dice, those used in casinos, are machined to exacting tolerances, taking into account even the weight of the paint in the pips, so that each face has an equal chance of turning up.
    A common way of making crooked dice is to drill out the pips on the "six" face, insert small lead pellets in the holes, and then paint over them; hence the term "loaded dice." A die so loaded will tend to land with the loaded face down, and the opposite face (in this example, "one") up. That's why casino dice are transparent, to make loads visible. Don't try this at home; even a Presbyterian minister (me) knows about this and other ways to make crooked dice.
    Itsatravcbowers18
    Reply 2 years ago
    yes i don't think this would pass in Vegas and surprisingly it rolls 4 allot. more fun than functional
    se4587
    2 years ago
    Very interesting idea for dice! Kinda mad that I didn't think of it :)
    genghisbunny
    2 years ago
    Cool idea, you've made me think about other dice shapes that are regular on the rolling sides without being regular polyhedrals.
    Itsatravgenghisbunny
    Reply 2 years ago
    it's funny when you finally see something that will work and you have that ahh ha moment
