Hidden Computer Drawer
45,333
641
48
About: My name is Troy. I'm a Mechatronics graduate studying Mechanical Engineering. I like to make things and spend time outdoors (especially SCUBA diving). I am a Community Manager for Instructables.
After I completed my first computer build a few weeks ago, I was at a loss of what to do with my 4 extra 5.25" bays. Searching around the internet as to what to do with all that space, I decided that a simple drawer was the answer.
Not being happy with the look or functionality of any of the drawers found online, I decided that making my own was the only solution.
I wanted the computer tower to look as unmodified as possible. Following these instructions, you can build your own Hidden Computer Drawer.
Step 1: Parts
You won't need many things and most will probably be found around your house if you collect junk like me.
Step 2: Tear Down Drive
Using an old 5.25" bay drive, tear all those old innards out. All you need is the outer case of the drive.
Step 3: Open Bay and Mark Case
Pull off the bay cover. Mine had a tab on each side. Remove any metal pieces that may be blocking the bay if it hasn't been previously used. Twist it back and forth till it breaks off. Align case to where it needs to be and mark where to cut it to make room for the face of the drawer.
Step 4: Set Up Switch
This push-open push-close switch is amazing! Set it up in a corner and draw a line along where the back of the drawer will be. This will help with future measurements.
Step 5: Cut Case and Bay Cover
Draw the line around the whole case and cut. I used a cut off wheel attachment for my Dremel. Sand sharp edges and wipe off all dust before getting this anywhere near your computer.
Step 6: Add Drawer Guides
Measure the inside of where you'd like your drawer to fit. Mine measured 4 13/16" across between the raised bumps for the screws. Cut the length of the bottom of the drawer a little bit long so that it can be trimmed to size in later steps.
Using super glue and scraps of wood (used from my labyrinth project) center the bottom of the drawer and glue in place.
Step 7: Mount Latch
Mount the latch in place by marking the holes of the latch, drilling, and tightening small machine screws. Cut off excess threads.
Step 8: Make Drawer
Measure the height that the drawer should be. Mine turned out to be 1 3/8". Cut and glue the back first. This will be needed for figuring out the depth of the drawer. The size of the front and back of my drawer ended up being 1 3/8" x 4 13/16".
Once the back is glued on, take the drawer and bay cover to your computer. Cut a little bit off at a time until the bay cover is flush with the computer case.
Once you have the correct depth, glue all pieces of polycarbonate together to form the drawer.
Close the latch and glue the catch in place. Make sure that the latch is closed BEFORE you glue in place. Otherwise the latch will not work correctly.
Center and glue the bay cover in place.
My drawer ended up running into the raised round part in the top of the case. I fixed it by cutting that part off and flattening.
Step 9: Glue Drawer Stop
On the top of the case, glue another piece of wood towards the front. This will be used to keep the drawer from falling out when fully extended. If you would like the drawer to be removable, do not perform this step.
Step 10: Test Drawer
Test drawer and make sure that everything works as it should.
Step 11: Install
Time to install into the empty bay. Insert the drawer until flush and lock into place. Mine has a push button latch, but make sure that you use screws to fully secure it in place.
Step 12: Done
This is a great project that can be added to the front of any desktop in just a few hours. If you happen to make a drawer yourself, please share a picture in the comments!
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
48 Discussions
IRSk
2 years ago
Great instructable! Do you have the measurements for everything? I don't have an old disc drive and can't get one, and do you know of any alternatives to polycarbonate?
bscolls
3 years ago
I know this is pretty old, but if you still have that 3d model you made of the polycarbonite drawer, Id love to have it. I have 50g of free filament that I could easily use for this.
tomatoskinsbscolls
Reply 3 years ago
Unfortunately I only drew those up quick and dirty for reference of how to make it. I didn't have the mind set to save and upload the file. You should be able to quickly create the .stl from the measurements shown in those images.
Builders Shed
3 years ago
Awesome! ill make that someday!
Darknessblade.
3 years ago
my current pc case has already a drawer stock, but its still a good mod.
Fredfly
3 years ago
That sad card got a hole two gigs!
joseph07
3 years ago
I put a finger scanner in one bay and I might do this with the other!
joseph07tomatoskins
Reply 3 years ago on Introduction
I used the Eikon To Go but they do not make it anymore. You can still find it on amazon though. I am going to make an instructable on how to do it!
rb765
This is great and would consider buying if someone was to do a kick starter with the empty drive case, so all you would have to do is bolt in and attach the front. (Hint, hint)
Working as a Community Service Officer for 25+ years and investigating thousands of residential burglaries, I can honestly say that criminals are not all that interested in desktop computers. The reason is that they are bulky and you cannot tell if a computer has the latest processor, or is a dual core dog on it's last legs by looking at the case. On the street, they have no resale value, so they leave them alone most times. The only time I have seen them take towers is when they have transport nearby and if they are into identity theft also, but those are a very small percentage of my cases.
acoleman3rb765
thanks for that second bit because you've put my mind at ease. i've been afraid of people twoking my tower, but it's just a quad core from 2009 running win 7. at least i know i won't have to worry about it vanishing.
acoleman3LukasM9
lol i love it. although with what rb has said. i won't have to worry about it anyway.
AndrzejRrb765
interesting insight, i suppose this is not the case (ha) when the computer case is all blinged out with a window and neon watercooling/etc... :)
DavidE14
I need one of these. My wire cutters keep going walkabout.
AT
Sweet project! Nice job. I always thought it would be fun to have a hidden drawer made from a CD or DVD drive. My idea was to keep the powered mechanism in tact to it would open and close on command. Also write a simple drive for it that had a built in password that would have to be entered. The drawer wouldn't be deep like the one you did. I am thinking I like you approach much better.
tomatoskinsAT
Yeah, I thought about the motorized approach but I didn't want to be limited by the space as well with the need for power. I often store small tools in it used when I work on computers myself. Thanks for the nice comment!
Syrinx2112
3 years ago on Step 12
Very cool! Though to hide the contents better I would paint the front panel of the drawer black or put the metal knockout panel that was removed from the bay opening on there
KostaK1
How weird. I bought а PC case for my mobo and it already had a little drawer like that in it by design :-) Your idea surely traveled quick
