Hidden Message Egg (wine Glass Magnifying Lens)
3,220
20
9
About: I enjoy everything
For many years my family makes and displays Easter eggs. I try to do something different every year.
This year I wanted to combine a hidden message inside the egg; readable with an attached homemade glass magnifying lens.
I got the idea from micro-pictures put inside walking canes, rings, lockets which are only visible by either a Stanhope or Dagron lens.
I cut down a wine glass for the lens material and create a modified Plano-convex lens.
Supplies:
Step 1: Items Used
Items used
1. Egg – white chicken egg
2. Glue gun
3. .005 fine black marker
4. Wine glass
5. Bamboo sticks – for grinding the glass to make lens
6. Wet grinders or paper 100,220,400,600,1000,3000
7. Polishing compound – cerium powder mixed with water
8. Diamond cutting wheel
9. Large metal paperclip
10. Household scissors
11. 20 pound white paper
12. Tweezers – I used a plastic jaw for handling the lense and a small jaw for putting the message in the egg
13. Color markers – to decorate outside of egg
14. Egg holder - I used a large spring clamp
15. Safety gear
Always remember shop safety - wear your protective items
Step 2: Make the Magnifying Lens (This Lens Is Called Plano-convex)
I started by cutting a wine glass into little pieces ( I used a wet diamond saw).
I then mounted the broken glass onto pieces of bamboo (to work on the grinders)
Using wet grinders, I worked from 100, 220, 400, 600, 1000 to 3000 grit; to shape and polish the lens.
I used cerium polish to put on the final finish on the lens.
I created a lens with one of the surfaces flat, and the other curved out.
This (wine glass magnifying lens) lens is called plano-convex
Step 3: Prepare the Egg
Poking a big hole and a little hole in an egg.
It was blown in the little hole - blowing out the contents thru the big hole.
I let it dry for a few days.
Step 4: Write Message, Put Message in Egg and Mount Lens to Egg
Write the message
I used my .005 marking pen (the picture shows my writing on rice kit) and wrote my message on 20 pound white paper.
I then cut the message out using household scissors (around the message - about 1/2 inch in diameter).
Put message in egg
Using small tweezers I put the message inside the egg (using a slight roll of the paper and then through the big hole).
I bent out (straighten) a large paperclip to use as a push rod.
With the straight paper clip put through the little hole – I put pressure on the cut out message over the big hole.
Note: the message is to point towards the little hole.
Tricky part: holding the message with paper clip in one hand - I held it upright (with the big hole pointing down)
Using the glue gun, I applied hot glue over the hole - to hold the message in place.
Letting it cool for a minute or two before pulling out the paper clip.
Add lens to egg
Egg holder - I used a large spring clamp to cradle the egg; I position the egg for the little hole to face up.
Using the hot glue gun, I put small dots of glue around the little hole.
Using the plastic jaw tweezers - I then placed the lens (flat side against the egg over the little hole)
I was not quick enough for great adhesion, so I put four small dots of glue – on the edge of the lens to create a better bond of lens to the egg.
Step 5: Decorate the Egg
I used paint markers to put the decoration on.
All done.
I like how it came out.
It is not just a hidden message inside the egg, it is also a secret.
Step 6: Years Past Eggs
I wanted to share some of our decorated eggs from years past.
The first picture shows an easter egg tray painted by my mother.
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    9 Discussions
    cupquake
    5 years ago
    Your mom must have been a painter i love the multicolored egg on the top right corner
    caitlinsdad
    5 years ago on Introduction
    I know it is not precision optics but is there a certain curve you have to put on the round part of the lens? I'm guessing you have to really peer around all sides to view the message or is that all in focus in the field of view?
    Well, there are some size ratios on the internet for simple lenses. Keep in mind that the thickness of the wine glass pieces will be fixed. So when you do your ratios, you will already know the thickness. I decide on my size ratios and started grinding. I first grind towards the outer diameter size I need.
    As far as the curve I make a 45 degree grind from the edge and then a 60 degree grind from the middle of the 45 angle. Do this with your 100 grit then move onto the 220 grit. This creates the curves main shape. Move onto other grits (400 and up) and polish using a spinning and rocking motion. This will knock off the sharp edges. Never stop in one place or you will get a flat spot, keep the lens moving at all times when grinding or polishing. This will give you a nice dome.
    Please note glass cuts fast, so use lots of water.
    Since I am doing this free hand I get mixed results (not precision). I make a few extra and take the best for my project or I need to go back and regrind for better results...
    The style of lens helps out in getting to your magnifying goals - concave vs convex etc...
    I really struggled with the focal length. Viewing through the lens on the egg the message is directly across, not a lot of searching required. You should have seen my back up design for a moveable message to put it in focus. I am glad I did not have to go with the backup design.
    I selected the wine glass because of the clarity. For cheap clear glass it works out well.
    My thought is that I can at least make a lens as well as the early inventors. So, I guess I just try and do my best.
    More questions as you try this, just let me know. I will try to explain it again. Scott
