Hideaway Drafting Table
17,476
469
24
About: Building design/consulting in SE Minnesota. Resource based problem solver... in other words, I always take a minute to peek in construction dumpsters :) ---the way some have to workout everyday... i have to...
Limited space?
Enjoy a stand up desk?
For years I've dreamed of having a drafting table in the apartment but was unwilling to sacrifice living space. This project allows for a drafting table to be installed anywhere - even over an existing desk. The Sketchup rendering is from an old apartment and doesn't match the installation but shows the design intent
Hope this helps get you started! Jeff
Step 1: Tools and Materials
Here are the suggested tools and materials for building a platform desk.
Tools:
Materials
Cost: All materials cost around $60 from HD/Lowes/Habitat. All tools cost under $120 . Fasteners: I recommend using all screws for the project. --- 2x4s were salvaged from a previous couch project at last apartment. Couch frames made the frame for the table. Links provided for where I would buy today on Amazon.
Step 2: Building the Frame
The photos show a frame that is salvaged from the prior couch project. The existing frame was oversized so I cut it down to a 5' width.
To build a frame from scratch.
  • cut the top and bottom piece to length
  • cut the studs to length by subtracting 3" from the desired height (allowing for width of 2x4s) and cutting equal length studs
  • add additional studs as required to provide for shelves inside the hideaway desk
  • secure using 3" screws. two at each connection
  • the last photo shows the back piece of plywood cut to fit the frame and attached with drywall screws 4" from frame connections.
Step 3: Shelves
Shelves -locate/add as needed
  • Solid Shelves: I used scrap wood cut to fit to make the shelves. The brown piece shown in the photos is scrap cut to fit and with holes drilled for power cords. I later decided to put the monitor on the first shelf and drilled a second set of holes through the frame.
  • Adjustable: I drilled holes for 1/4" dowels. The dowels are not show but can be installed running along the narrow section on the right side. Much the same way shelves are installed in standard cabinets.
Step 4: Hinges
There are many options for installing hinges. I used 2" hinges I had leftover from another project. The steps can be applied for any size hinge. Adjustments are required for the depth of recessed hinges.
  1. mark out locations on the base of the frame where the hinges will be installed. I spaced them evenly but slightly adjusted for the location of the supports
  2. set the depth of the circular saw blade to match the closed width of the hinges. use the circular saw to notch out for flush mounted hinges.
  3. set the hinges in place and screw them into the frame
Step 5: Desk Surface
I used a scrap piece of 1/2" plywood. It is recommended to use 5/8" or 3/4" for a more solid surface.
I painted the back of the plywood. If it is a new sheet of 1/2" plywood avoid painting the back because it could warp while drying. With 5/8" or greater it shouldn't be a problem.
  1. cut to match the size of the frame
  2. paint as required
  3. line up board with the hinges and use a 2x4 and scrap plywood as required to allow the board to sit at 90 degrees to the frame
  4. loosely secure one screw at each hinge before installing the second and finally tightening
Step 6: Wall Mount & Hardware
Wall Mount
The full assembly is heavy. I recommend fixing a 2x4 to the wall and using that to rest the weight of the desk while using the drywall screws to screw into studs.
Latches
Most latches should be usable. For this project I used smaller hinges mounted to the frame and catch screws at the side of the table when in the closed position
Rope/Chain Support
Rope is mounted to the inside of the frame and connects to cleats on the table itself. Chain is preferred to avoid any flex but the rope was at hand.
Thanks for reading! Best of luck!
Jeff -- If you like this project check out where the material came from... Platform Beds one and two. Some screws were actually from a backyard chicken coop!
Step 7: Personalize
Installing a monitor. I purchased a monitor from goodwill for $20 in San Francisco a few years ago. The monitors available are in great shape and can be tested in store. To install simply remove all hardware and use screws drilled into the frame to hold the monitor in place. Drill holes as required for power cords.
Installing cork or dry erase board. I used a piece of acrylic from a local frame store cut to length. Acrylic is available in white which makes it easy to work with. Avoid paint on or roll on dry erase surfaces. Roll on cork works fine. Blackboard paint is also an option but make sure the surface is smooth.
Mounting a light/radio/phone charger/fan. Drill for power and mount as required
Mounting an extension cord. I mounted an extension cord outside the frame
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    24 Discussions
    brian.sessums
    11 months ago
    I am here to resurrect your post! I like the idea, I had something similar in mind with my Google Search. I have a "guest bedroom", that I want to add secret "man cave" features, such as... a hidden drafting table! Woot! Let's see some updates to yours if you read this. Are you still using it, 4 years later, if so, has it evolved in appearance/functionality? Thanks!
    jprussackbrian.sessums
    Reply 11 months ago
    Ha! The old desk (made from an old couch) has turned into a chicken coop, mount for a computer monitor and shows up as a leg of a new platform bed! Just used some of those screws to expand a chicken run this week!!
    jprussack
    4 years ago
    Thanks Fadingroar, hadnt thought to do it but that's a great call! I might have to add some Walltalker. And some Mylar to address the finishing issue called out by Mr. Bomlin. Thanks!
    fadingroar
    4 years ago on Introduction
    You could even add some surface to the external part for it to be a white board :) amazing work buddy!
    bomlin
    Great idea. I do have a minor suggestion. If you are going to call this a drafting table, go one more step and add the correct surface to the plywood to make it a real drafting table. Otherwise, great project.
    Cristina26
    4 years ago
    a dream bulid! cool stuff!
    natxc
    4 years ago
    Great idea! Do you have any pics of it closed up on the wall?
    Also, do you think a 2x4 attached to the open end of the desk surface would provide enough stability for drawing on?
    jprussacknatxc
    Reply 4 years ago on Introduction
    Natxc - here's a closed shot at one where you can see the stool providing additional support
    natxcjprussack
    Awesome! Thanks for the added info. I will keep your idea in mind when I have to get rid of my drafting table in a couple months.
    jprussacknatxc
    Thanks Natzc!
    Short answer: Yes
    You'll see in the photo how the cedar spans at the hinges. I would add a board at the open end to help distribute the load (if using 1/2" stock, as I am). Otherwise the 2x4 should be fine. A stool is providing extra support for my desk and is placed mid span near the open end. (photos to follow)
    Mielameri
    4 years ago
    Secret drafting desk! Great idea! I was thinking along the same lines as pucksurfer: when not in use, it could totally be modded to pull double-duty as wall art :)
    Mielameri
    4 years ago
    K.hall86
    4 years ago
    Awesome idea! I know that IKEA makes a cheap table with a variety of different tops. I'm not too sure on their dimensions, bit it looks similar in size and only cost about $10-$20 for the top alone. It is a very smooth and durable table top, perfect for drafting! only a suggestion for a brilliant idea!
    K.hall86K.hall86
    Reply 4 years ago
    http://m.ikea.com/us/en/catalog/products/art/50280098/
    jprussackK.hall86
    Thanks K.hall!
    If anyone is really drafting your best bet is a mylar finish.
    I prefer real wood over particle board. The link provided is for a product that costs $25 and is only 2'-5" x 2'-5". For the same $25 (max $40) you can buy a piece of 5/8" maple from Home Depot / Lowes. They'll even cut it to size!
    pucksurfer
    4 years ago
    This is really cool. Now you just need to paint something on the wood. And make it seem like a wall painting, and it is kind of hidden.
    jprussackpucksurfer
    Reply 4 years ago
    Thanks! The paint I used is Kilz primer. Could totally use a finish coat!
