Hiding Place in a Log
12,281
202
17
Have you ever lost your keys and been locked out of your house because of it? If so, then this secret hiding place will prevent that from ever happening again.
Step 1: Find a Log and Equipment Needed
*Power Drill
* 3/8" Drill Bit
* 3/8" Dowel
* Hand Saw
* Router
*Safety Glasses
*Rubber Mallet
*Log
Step 2: Drill 2 Holes
Drill two holes deep enough in the log in order for the two dowels to be able to reach about 3/4 through the log.
Step 3: Saw the Log in Half
Use a hand saw to cut your log in half horizontally making sure that the dowel holes remain face up.
Step 4: Insert the Dowels
With the log cut in half insert a 3/8" dowel into the bottom holes of the log. Use a rubber mallet to make sure that they are tight inside of it.
Step 5: Make a Compartment in the Log With a Router
Using a router, route a shallow compartment in the log making sure it is both deep enough and large enough for a key to fit in.
Step 6: Final Touches
Use a drill on the two holes on the opposite half of the log so that they are large enough that the dowels don't get stuck in them, but small enough so it requires some strength to pull them apart. Then put the two pieces together and flip the log so that the holes aren't visible. With that, you now have a convenient hiding place to hide your house key that only you know about.
Hiding Places Contest
Runner Up in the
    • Jewelry Challenge
      Jewelry Challenge
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    17 Discussions
    Raitis
    3 years ago on Introduction
    Splitting the log instead of sawing might be way easier and it fits together better afterwards.
    copenhagen247dipRaitis
    Reply 3 years ago
    How would it fit together better then sawing in? sorry your right about the splitting being easier thou
    P.j.Ncopenhagen247dip
    Reply 1 year ago
    Because sawing it removes material. Splitting it doesn't so it does back together w/o that eigth inch of material that you lost in the cut
    Raitiscopenhagen247dip
    Reply 3 years ago
    When you saw something, you remove material (sawdust), when you split it open, you do not remove material and given a log without branches it splits neatly along the grain and then fits back together. See my instructable here.
    greeneyedlady1961
    2 years ago
    You could always decorate the log with something for all seasons and as a porch item. With just some greenery for the change of seasons. Greenery with flowers for spring and summer and fall leaves and in the winter depending on where you live follow your area for decorations. Add another slab of log to the bottom with flat side down to hold into place. Then just lift the top off. Keeps it out of the bonfire. May not help going thru a window or exposing a key, but locks are for honest people anyway. Put it on the front porch. Just act like your straightening the arrangement. Less likely for someone to break in thru the front of the house. Just a few of my thoughts.
    Schaf77
    Nice job. Just make sure the log does not end up in the campfire lol.
    rmarshall8
    3 years ago
    great idea. first thought...geocache! time to find me a log. tfti
    simasikutokymaru
    Reply 3 years ago
    Lol! But look- it broke open when I picked it up and that's a key in it... Wow! Definitely easier than breaking the window!
    aiferapple
    3 years ago
    You would need to put the log somewhere inconspicuous and possibly fixed down but good idea. Perhaps put a waterproof container inside the compartment
    CLullham
    Nice idea, you should hide the log, though. If it were me, I would definitely pick it up
    GlendonGAryan Gupta
    Reply 3 years ago on Introduction
    Well then allow your keys to cool off before handling them . ;-P
    This isn't a bad idea . Although it is a valid point ; if someone takes the log , you've lost your hiding place (and your stash) . I'd suggest applying this idea to something a little more inconspicuous when left lying around .
    naix90
    3 years ago
    If the log is taken away by someone?
