High Voltage Multiplier
105,252
149
128
About: I am a distant relative of the Apache Warrior Geronimo. I enjoy working with electronics, wood, metal and gold. I love the flashes of inspiration I get after mulling over a problem. I'm a foodie and creat...
Need more voltage than your supply can deliver? This is the device to build.
Based upon the Villard doubler, cascaded in multiple stages, this circuit will multiply a small AC voltage into a huge potential.
With a 6000 VAC Oil Burner Transformer and just three stages, you can multiply the potential from 6000 to 51,000 VDC!
Also, the higher the voltage ratings on your components, the higher the input voltage can be and therefore, more bang for your buck.
One side benefit of a stack like this is you can tap off various voltages from stage to stage. In this example, three outputs of 17000, 34000, and 51000 volts are available. Nice!
Supplies:
Step 1: The Theory
Each stage of this multiplier is a doubler circuit and is made up of (2) Capacitors and (2) Diodes.
On the positive half-cycle of the input, the capacitors charge in parallel to the peak value of the voltage presented through the forward biased diode. The other diode is reversed biased. Each cap charges to 8484 peak volts.
On the negative half-cycle of the input, the forward biased diode becomes reversed biased while the reversed biased diode becomes forward biased. This effectively connects the capacitors in series allowing them to discharge into the load at the output. The result is a doubled voltage presented to the load or 16968 peak volts.
Each connected stage adds its potential to the total output.
To calculate the expected voltage at the output with a given input and number of stages, plug the numbers into this formula:
Eout = (2 x Ein) x S x 1.414
Eout is the Output Voltage, Ein is the Input Voltage, and S is the number of stages in your design. I used a 6,000 VAC Oil Burner Transformer for my input and built 3 stages.
Eout = (2 x 6000) x 3 x 1.414
Eout = 12000 x 3 x 1.414
Eout = 36000 x 1.414
Eout = 50,904 volts
Step 2: The Parts List
All of the critical parts are available on EBay. Here's what you will need:
(6) 470 picofarad, 20KV Ceramic Doorknob Capacitors.
(6) HV03-12 12KV PIV High Voltage Diodes.
(7) Brass or copper wiring posts (homemade).
(8) 8-32 x 1 in. brass screws.
A length of 50KV High Voltage wire for the output.
A length of 20KV High Voltage wire for the input.
A length of 12ga. Stranded wire for ground.
(3) #8 Wire lugs.
(1) Ziploc Food Storage Container big enough to hold the multiplier(not a bag).
(1) qt. Mineral Oil.
RTV Silicon Rubber Sealant.
NOTE: Only the voltage rating on the components is critical.
The higher the rating, the higher the input voltage can be, resulting in a higher output voltage. The input limit on this design is 10KV (with safety margin built in). Ignition wire or coax cable with the shield removed may be substituted for high voltage wiring if need be.
Step 3: Build It!
This step isn't rocket science, just common sense building techniques. Just copy the design shown with the binding studs added.
Start by cutting (7) pieces of 16 guage brass or copper wire two inches long. Bend each piece around a drill bit and shape with a loop at one end.
Next, cut the heads off of four of the screws to make the studs that join the capacitors together.
Screw a stud into one of the caps. Place a binding post over the stud and screw on another capacitor. Screw in another stud, place a binding post over it and screw on the last capacitor.
Repeat the previous step to create two stacks of three caps each.
Lay the two stacks side by side with the binding posts pointing up.
Cut the four remaining screws to 1/2 inch long.
Attach binding posts to the right side end of each stack using a screw.
Attach a binding post to the left end of the bottom stack using a screw.
Attach the diodes as shown and solder them to the binding posts.
Cut off any excess binding post tops and file them flush to the soldered diodes. No sharp edge here or you will get an unwelcomed breakover which could ruin your project.
Attach the wires with lugs. Tighten the screws and make sure the entire assembly is tight.
Step 4: Bury It!
Now that the multilpier is finished, we need to encase it in oil.
With the lid still on the Ziploc container, punch three holes in the lid at the approximate locations where the leads will exit it. Remove the lid from the container and set it aside.
Slowly fill the empty, clean Ziploc container half way with mineral oil without creating any bubbles in the oil. Oil good! Air bad!
Hold the multiplier by its leads and slowly lower it into the oil bath.
Continue holding the leads with one hand and slowly pour more oil over the multiplier until it has at least a 1/2 inch covering and about 1/2 inch head space between the oil and the lid.
Now pass the leads one at a time through the holes in the lid then work the lid down onto the container while holding the leads. Do Not get oil on the leads at the lid level or the sealant won't stick or seal the wires. Snap the lid onto the container.
Finally, seal the leads and if you like, the lid to the container with the RTV sealant and set the project aside for 24 hours until the RTV is cured.
Your Done!
PLEASE READ THE SAFETY SECTION BEFORE POWERING THIS DEVICE!
THANKS!
Step 5: Notes, Warnings, Safety Procedures and Disclaimer
NOTES
This multiplier is part of a 0 to 50KV adjustable High Voltage Power Supply capable of sourcing 20 milliamps of current.
An instructable on building the supply is my next project, so hold on!
SAFETY WARNINGS and PROCEDURES
  • * * W A R N I N G * * *
This device produces LETHAL CURRENTS at HIGH VOLTAGE. The output of this device WILL KILL YOU if you do not follow standard common sense safety procedures.
Safety Precautions and Procedures
1. Wear safety goggles or glasses, rubber safety gloves, and stand on a rubber safety mat when powering or using this device.
2. GROUND the output of this device after powering it off. It can retain a lethal voltage for several minutes after powering down.
3. DO NOT TOUCH the device AT ANY TIME during operation.
4. Do not allow others who are not familiar with high voltage devices to touch or use this device without proper supervision.
5. Do Not operate this device alone! Have an emergency person available when performing your experiments who is familiar with proper rescue procedures.
DISCLAIMER
By building and operating this device, you acknowledge that you understand the dangers improper operation can pose and you accept all risks associated with the operation of this device.
You also acknowledge that I am not nor will be responsible for any death or dismemberment by this device whatsoever and that you assume all risk by the use of this device.
2 People Made This Project!
  • Party Challenge
    Party Challenge
  • IoT Challenge
    IoT Challenge
  • Arduino Contest 2019
128 Discussions
MDA37
1 year ago
Hello sir,
Can I use "rectified" flyback transformer (new type), instead of AC flyback transformers (old type), for input power of this "capacitor and diode" combination circuit. Would this circuit work by input of "rectified flyback transformer".
TimothyE26MDA37
Reply 5 months ago
Hello MDA37, the short answer to your question is NO.
The voltage must be alternating (the faster the more efficient for this application),
so a dc voltage source will not charge all of the capacitors it may only charge the first capacitor but the voltage will be terminated beyond that point.
A crt tv flyback transformer is always the best and cheapest for this project.
MDA37
1 year ago
Hello sir,
Can we use DST flyback Transformer without capacitor which gives half cycle pulsating DC I think.
Would this circuit work?
MDA37MDA37
Reply 1 year ago
Please answer me sir.
Anyone?
MDA37
1 year ago
Hello sir,
MDA37
1 year ago
Hello sir,
MDA37
1 year ago
hello sir,
Can I use "rectified" flyback Transformer instead of "AC" flyback transformer, to power up this "capacitor and diode" combination circuit. would this circuit work of input of rectified flyback transformer
HikmatB
3 years ago
if i want to make voltage multiplier 20kv with input 220V 50hz, what the best components to mak it?
hydranixHikmatB
Reply 3 years ago
You won't be able to make a 100x voltage multiplier like this. The high voltage diodes consume a considerable amount of the voltage. Further the cost of just the diodes would be more than $/€ 2000.
If you want 20kV from 220V mains, just use a transformer. Its FAR cheaper, and many times more efficient. Plus playing with 20kV, you need some serious insulation layers between the capacitors and diodes to prevent unwanted arcing.
2 12kV neon sign transformers would run you around $/€ 100-150.
Then rectifying that would be about another $/€ 100-150.
So using a multiplier would be more failure prone, much more dangerous, and cost easily 20 times a dual transformer setup.
If you want to really don't want to go the transformer route, don't use this circuit. Use a Marx generator. It doesn't suffer from the same diminishing returns as a multiplier. Though it has other drawbacks as well.
Be careful though. 20mA at 20kV will likely instantly kill you, and a Marx generator can easily exceed 100 to 200 times that current. One touch, anywhere on your body, and you're very dead.
HikmatBhydranix
Reply 3 years ago
do you ever made voltage multiplier, do you have id line? my id : hikmatsb
or my email hikmatsaefulbahri@gmail.com please answer
HikmatBhydranix
Reply 3 years ago
HikmatBhydranix
Reply 3 years ago
thanks a lot for your information
hydranix
3 years ago
...and you don't experience any arcs between those unprotected solder joints?
razara71
3 years ago
Very nice article.
ToshikazuK
3 years ago
Will the multiplier work if I directly connect it the AC mains power supply?
AabcC
3 years ago on Step 5
hi, can I use different output capacitors in same multiplier? how to built a multiplier with different output capacitors?
crashstudio
4 years ago on Introduction
I just finished building one to your spec and was wondering how to connect my 10kv OBT to it. There are 2 secondary terminals.
aclark17
6 years ago on Introduction
Alright Ive thought on this for some time and I absolutely HAVE to ask... partly because some Im confused about and partly because no one else has.
First, my OBT is similar to the one used in this instructable, RMS 6kV. Peak to peak its 20kV, half wave obviously 10kV. Now burningsuntech, you said the RMS value is .707 of the peak value, and/or the peak value is 30% higher than the RMS, but my numbers dont equate, according to what the label on the OBT says my RMS should be 7070v, and yet it says its RMS is 6kV. So whats up with that?
The other part of my question is in the formula you give, Output voltage, Input voltage, and the number of stages are all represented as well as the action of each stage (that being Ein x 2), i.e. Eout = (2 x Ein) x (# of stages), but where are you getting the extra 41.4% output at the end there, represented by x 1.414? Its not mentioned, its just there?
I also wanted to say that even though Im confused on those minor details (not minor to me cause I wanna know :P) I have constructed the multiplier, connected the variac, which is an external one that I can keep outside the case and plug the supply into or use for other things as well, and connected the OBT to the multiplier using 20kV If its labelled TV-20/40/50 thats the kV rating) HV wire I got from flybacks, as well as a short length of 50kV (TV-50) for the output, and while I still have to fill the project box for the multiplier with wax (it DOES arc!!!! Blew a diode that way... just one though!) it works PERFECTLY! Its a very elegant project, and I am very proud of it. Thank you for your instructable and lessons on the theory of operation, its great!!!
aclark17aclark17
Reply 6 years ago on Introduction
Oh I forgot, I meant to ask if the x 1.414 was because of ripple or is it something else entirely?
aclark17aclark17
Reply 5 years ago on Introduction
Nevermind, I got it, the caps charging to the peak forward 8484v, which is 1.414 times the input of 6000v
