High Voltage Pulse Generator for $8 (stungun)
7,737
41
14
About: Hello, I'm Bruce. I'm a student in Belgium. I have a wide variety of interests: electronics, computers, technology, ... In my spare time I spend a lot of time on: projects, exploring the internet, cycling. ...
This device is capable of generating high voltage arcs, which can be used as an ignition system for a spud gun.
Or other things where High Voltage pulses are needed for testing purposes.
This device is chargeable with a micro usb cable.
Warning:
This project uses High Voltage and can be dangerous if used wrong. Build and use this on your own responsibility and never use this on living things.
Step 1: Get the Components
NameEbay LinkPrice [$]
HV Modulelink3.51
Battery Holderlink0.72
Push Buttonlink0.72
Enclosurelink0.80
Batterylink2.53
Battery Chargerlink0.72
Total:8.28
You can leave out the charger is if you don't want it.
Step 2: Perpare the Module
The module is a little bit to big to fit inside the enclosure.
First cut the excessive part from the tube off.
Than you can use a piece of sand paper or a milling machine to trim the height of the module to fit inside the casing.
When I was using the milling machine the tube broke and I was able to take the whole tube off, which was also fine.
Step 3: Solder the Circuit
  1. First solder the battery connector to the charge module.
  2. solder the GREEN wire of the high voltage module to the charge module "-" connection
  3. solder the RED wire of the high voltage module to one side of the switch
  4. solder a wire from the "+" connection of the charge module to the other side of the switch
Step 4: Test the Circuit
See how long you can make your arcs. this is important to know when placing the screws.
Step 5: Making the Enclosure
See where everything would fit inside the enclosure and make the holes for the components.
Step 6: Making the Electrodes
  1. Cut the red High Voltage wires to size
  2. Strip the red wires and solder spacers to them
  3. Drill the holes in the enclosure for the bolts to go through
  4. assemble everything as in the picture
Step 7: Final Touch
  1. Test if everything works
  2. Glue everything in place
Update: I added a lot of hot glue at the inside on the electrodes to prevent internal arcing
    • Build a Tool Contest
    • Sweet Treats Challenge
    • Organization Contest
    14 Discussions
    fabianw12
    6 months ago on Step 7
    Great Work!
    How much current it consume de HV module?
    with that battery how much time its on?
    Thanks
    Albertv3
    7 months ago
    Good job Bruce! Made one too. Adding hot glue internally doesn't really help to prevent arcing. Best thing to prevent this is to keep the outside electrodes only about 16-17mm from each other!
    Albertv3Albertv3
    Reply 7 months ago
    By-the-way: did you know that your HV pulse generator pricks tiny holes in a sheet of paper held between both electrodes? NICE invention for a cheap braille writer device.
    FarazA29
    11 months ago
    Really cool! I have a question regarding the used circuit. Which IC are you using and where can I buy it?
    B0nkers
    1 year ago
    Don't get caught with one of these in the UK - the mandatory minimum jail term is five years. http://www.bbc.co.uk/news/uk-scotland-edinburgh-east-fife-40045163
    Man caught with stun gun disguised as torch jailed for five years
    geo brucemach1950
    Reply 1 year ago
    I've never felt a stun gun, but I tested this on my leg a few times and it's not a pleasant feeling.
    PhotoMaster
    1 year ago
    I have seen something very similar (electrically the same) listed for science purposes. I'm thinking of making this for lighting camp fires. Great instructable!
    PhotoMastergeo bruce
    Reply 1 year ago
    I have all sorts of fire starters for camping. I was going to buy and electric lighter but this circuit would serve the same purpose, with additional functionality.
    rafununu
    1 year ago
    Cool. It can't be 1000kV (10^6V), such a voltage generates an arc of 33 cm in normal air !
    geo brucerafununu
    Reply 1 year ago
    Sure it isn't 1000kV, but it's still a lot of bangs for buck!
