How to Make Arduino Based Digital Tachometer Simple DIY Tutorial
41,442
290
43
About: Electrical engineer by profession
Let see how to make Arduino based digital Tachometer.
Working principle :-
IR Sensor get penetrate by motion of motor shaft, signal are transfer from IR Senor module to Arduino.
This signal are processed in Arduino according to code loaded on it.
Then Arduino transfer signals to LCD Screen to display RPM
https://easyeda.com/sharmaz747/Arduino_techometer-...
Step 1: Video
Step 2: Material Reuired
1) IR Sensor module :- http://amzn.to/2mOUVyw
2) LCD Screen :- http://amzn.to/2lxF1bp
3) Arduino Nano :- http://amzn.to/2lxF1bp
4) Zero PCB :- http://amzn.to/2lxF1bp
5) Header pins :- http://amzn.to/2lxF1bp
6) 9V Batter
Step 3: Electrical Circuit
Kindly go through the attached circuit diagram.
IR Sensor Arduino
VCC----------------5V
GND----------------GND
OUT-----------------2(digital pin no. 2)
16X2 LCD Arduino
VSS------------------ GND
VCC----------------- +5V
VEE------------------ POT
RS-------------------- 12
R/W----------------- GND
E--------------------- 11
DB0----------------
DB1----------------
DB2----------------
DB3----------------
DB4------------------ 6
DB5------------------ 5
DB6------------------ 4
DB7---------------- 3
LED+--------------- +5V
LED----------------- GND
Visit https://easyeda.com/
to design & buy your custom make PCB
Step 4: Procedure
Bring a Zero PCB, Mount female header pin on PCB
Place arduino and LCD Screen on PCB
Make solder connection where it is required,
refer electrical drawing for better understanding.
place IR Senor module on PCB in way that its sensor face toward the
wheel of motor to whom RPM have to measure.
Connect the Arduino with PC to upload code.
Then connect the 9V battery to power up arduino & LCD 16 X 2 screen
you can adjust the brightness of screen by rotating that Knob connected at VEE of LCD Screen
Now you are ready to take RPM reading.
Manually rotate the Wheel of motor you can see RPM Reading are appear on screen
feel free to comment below
Thank for your attention hope you like this project
Step 5: Arduino Code
Click here to download Arduino code
upload the code to Arduino
Be sure you have selected right Board & port to successfully upload the code
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    43 Discussions
    fourstar
    2 years ago
    Hello Sir,
    Will this work to measure the RPM for my RC gas engine propeller
    or have you now an other tutorial to measure the rpm of a rc plane
    Thanks
    fourstar
    k1200s
    1 year ago
    In the circuit diagram, the output pin of the IR sensor unit is connected to the Arduino D2 pin. But where on the Arduino code is the input pin declared? Am I the only one that is not being able to make it work?
    stobby256k1200s
    Reply 11 months ago
    Hi!
    See my comments above... It is also common to read around 10 Rpm figures into a moving array and average them so the display is not to glitchy.
    stobby256
    11 months ago
    k1200s
    There are errors throughout; the 68k resistor should not be in there, the D2 input should go to the output pf the op-amp and not the LED, and the pin assignments for the Nano are wrong, I'm working my way through them.
    attachInterrupt(0,isr,RISING);
    the zero in the above refers to pin D2, which actually on a nano is Pin5... so should read...
    attachInterrupt(5,isr,RISING)
    I can see that it will work but it is not written up too well :(
    mb_lenggries
    1 year ago
    it also works nicely with a cheap hall sensor-pcb from eBay! This is my first project with an Arduino (Pro Mini) - and it feels good;-) !!Thank you!!
    next quick Question: Looking at the sketch, I do not see where/how pin D2 is defined as an input (I need to know for further modifications and playing around with a rotary encoder). I would be very nice if you could help with an answer.
    man_thas_cool
    1 year ago
    Quick question: Does the Arduino keep track of the time that it runs? You don't have to start some special 'clock' operation?
    I can't believe how concise this code is compared to other tachometer tutorials I've seen. Nice tutorial!
    ArcAiN6
    1 year ago
    the arduino code download link goes to a Google page that says it violates terms of service for URL shortener..
    Perhaps just past the code in "code" brackets, then no one has to download anything from nefarious places.
    Mr innovativeArcAiN6
    Reply 1 year ago
    it is fix,
    http://www.mediafire.com/file/qb57bnuww0us465/tachometer-using-arduino.ino
    garyparks1949
    2 years ago
    while I have downloaded the project, I haven't had the opportunity to use it as yet. Tried to read through the project and had a difficult time understanding what the person was trying to convey. Not a very explanation of how to build it, however, being a retired engineer being able to build directly from schematics and upload code to the nano makes things quite easy for me, but I think not for a beginner in the business.
    Mr innovativegaryparks1949
    Reply 2 years ago
    I'll try to make my explanation more efficient in upcoming projects thanks for your inputs
    baba1234Mr innovative
    Reply 1 year ago
    hi sir can u plz forwad me the code cause the previous link to the code doesnt work thanks
    garyparks1949Mr innovative
    Reply 2 years ago
    Thank you for your reply. I was not trying to be mean when I commented, But as a retired Electronics Engineer I have had to write Instruction Manuals and Build Manuals. I have found that the "KISS) method is the best way to approach. (KISS Keep It Simple Stupid!). That way even the least trained person with a minimum of experience can usually build from a manual. Again though thank you for the reply. BTW, I'm 68 years young and still myself busy with electronic projects here at home. You don't use it, you lose it!
    Reply 2 years ago
    yes its my honor to have advice from people like you who have a huge experience in your field, this will add more value to my work & KISS is best way to present your ideas, keep motivate us thanks
    baba1234garyparks1949
    Reply 1 year ago
    RomiT1
    1 year ago
    hello sir,
    i want to ask you, how to change rpm output to m/s output?
    could you help me to resolve in arduino sketch?. thank you
