Home Made Vertical Hydroponic System
92,649
209
20
About: I love to build grow lights and grow with hydroponics.
I saw a vertical hydroponic system that I really liked but what I didn't like was the $500 price tag.  I thought about it for a while and decided I could design my own system that is similar for much less money.  After about a month of spending weekends running back and forth to the hardware store I came up with this system shown in the videos below.  I call it The Rain Tower because there is a pump in the resivour that pumps the nutrients to the top of the tower and they rain down on the roots of the plants on the inside of the tower.
In this first video above is the test run I did growing 12 lettuce plants.  The results were amazing as you will see.
In this second video I take you step by step showing you all the parts you need and how to put it all together.  Links will pop up during the video but if for some reason you don't see them you can visit the web page here: The Rain Tower Home Page
If you have questions you can email me or visit my site at www.tomorrowsgarden.net
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    20 Discussions
    michaelb2
    2 years ago
    What is the current best pump? I have burn through three sunsun jp055 pumps in less than a year
    JacksonM35michaelb2
    Reply 2 years ago
    I'm not at all knowledgeable about hydroponics, but I know a bit about aquariums. Your best bet is to go to a pet store that only deals in fish and ask them about it. Chances are that the owners and employees will own fish, and they'll have used pumps in the past. They're likely to know which would be best for moving the amount of water you want to move, how far you need to move it, and how many gallons per hour you need it to move.
    gabigirlhs
    2 years ago
    Hi there.....I also posted this question elsewhere but the article was quite old-....
    I also saw the same tower for 500$. It looks great but is pricey and doesn't get delivered to Europe... BUT, I really would like to make one myself and am at the beginning of looking into it. I just have one question. Why are stainless steel (or even glass) containers never used? I understand that they are far from cost-efficient and may be more difficult to build but it spares the risk of weird chemicals from plastics or PVC. Or is there something else that goes on that I don't know about yet so that stainless steel shouldn't be used??
    IrvinH2
    3 years ago
    I watched your video and it you say to use epoxy its food safe that is not at all true its dangerous filled with chemicals you need to stop giving people false information your going to get someone sick or worse
    k2reme
    3 years ago
    like the design i have little different version that uses mist emitters and a single res for all the towers. not in production yet but it works well with one tower
    tomithy1235
    5 years ago on Introduction
    I sent you an email but never got a response.
    I was asking about better materials to use than epoxy (which is pretty toxic), and now I am planning on just using normal schedule 40 PVC cement, as that's already intended for safe use with water lines.
    Why did you use the epoxy? It seems like a bad choice to be around plants and water for plants, just for safety concerns.
    Is there any reason not to use PVC cement?
    I would have used something else like other people have been. That epoxy is expensive too but it held up. Mike Walker was using a PVC cement that he said he found near where you buy the fence posts. I haven't looked into it. There are some food safe PVC cement products on Amazon. The actual fence post and 3" PVC pipe are safe. I just checked into that recently and called the manufacture.
    Yeah, I wasn't concerned about the post or pipe, both seem to be the same material, and I know PVC is safe. I had to order the fence post online, unfortunately, and I just looked and it looks like he uses PVC fence post cement, which does in fact appear to work well.
    I guess my concern just comes in with the (minute, I know) amount of potentially malicious chemicals that could come with that. I know Schedule 40 PVC cement is supposed to be non-toxic (as it commonly holds water line connections together), but I'm also worried that it won't be strong enough to hold more of a joint connection like this, instead of just holding together two pipes that are stuck together with friction. I plan on trying it to see how it works, but maybe I'll research the PVC fence post cement more too, but not being made specifically to be drinking water safe scares me, but perhaps unnecessarily.
    Thank you for your diligent information though, it's inspired me to build one, I just need the time to start the construction, now that all the supplies finally came!
    myoungelegtomithy1235
    Reply 3 years ago on Introduction
    I know this was posted over a year ago, however, I just began constructing one of these hydroponic rain towers. I noticed that you seemed worried about PVC cement in your above post, and also noted that you mentioned that the strength might not be enough "..instead of just holding together two pipes that are stuck together with friction...
    I believe the PVC cement involves a chemical reaction whereby the PVC is dissolved to an extent and when two pieces are put together (at a joint with the cement), the magic of bonding the 2 pieces begins to occur. I think the hardest part about using PVC cement here is that we are having to bond a piece to the side of the post.
    I am planning on finishing up mine today and will likely use some sort of silicone adhesive. Also, in regards to toxins for the plants. I took advice from a soil scientists. If plants can't grow, then the solid has toxins. If plants do grow, its probably safe and healthy.
    Cheers!
    CarlaB1SleestaksRule
    Reply 4 years ago on Introduction
    oooh... that's good news! I didn't think that vinyl fence posts would be food safe. Is it just their product that's safe, or are they saying that all vinyl fence posts are safe? Did they give you any details about why it's safe? Thank you for your help!
    SleestaksRuleCarlaB1
    Call the manufacture. 1-800-336-2383
    They make it for Lowes and Home Depot.
    Press 3 for the tech dept. Ask if it's safe for growing plants. Really nice guy there.
    This is PVC 4 LDPA - Low
    -density polythylene �" not known to leach toxic
    chemicals
    Milk jugs are made with polyethylene. Water bottles leach toxins into the water, but milk is held to a higher standard.
    slo5ohtomithy1235
    A lot of things like epoxy, PVC cement, concrete are toxic during their chemical reaction stage but are inert after that. Epoxy and PVC cement are used in home aquariums, but only AFTER they are solid. Even concrete can be used, but it can take several months before the concrete is done curing enough that it will no longer spike the water.
    It's the chemical reaction that happens during the hardening process that releases toxins, once the reaction is complete, they become safe.
    Thanks for the tip!
    Just ordered some, I'll have to try it out. Looks like it'll be handy around the house a lot too!
    ktshoema
    I want to know why the 15 min on/of cycle? I am 99% sure that it would be better for the plants if the pump was on the entire time.
    Check out my system @ https://sites.google.com/site/classroomhydroponics/
    Hello
    Thanks for this tutorial. Very useful to make Vertical Hydroponic System. Its good to be going green and it becomes interesting when we can make greenery around us, Even in our home too. This kind of article are very helpful to make our world more beautiful and green. Add a vertical hydroponic garden to style your home environment http://www.designcot.com/2014/08/add-a-vertical-h...
    Keep Sharing.
    GeoF1
    Hi, I wanted to know if anyone had any issues with humidity and mold growth on the inside of the tower. I was trying to do it in my house and a 15 min on/off cycle was causing some weird mold growth in the tower. Also, what about preventing mosquitoes?
