HomeMade Modern DIY Box Sofa
57,117
1,182
24
About: HomeMade Modern is an online design source that publishes easy-to-follow, DIY recipes for creating modern home furnishings. We provide creative ideas for making affordable alternatives to pricey designer ho...
Your sofa is probably one of the most expensive pieces of furniture you own. This wood framed sofa is simple and durable with a timeless style. It can be built around almost any sofa cushions you might have or even a single mattress if you want it to double as a daybed. I salvaged some cushions from an IKEA sofa whose frame had broken. Pile pillows along the sturdy, solid-wood sides and back makes this a perfect daybed for a couple to lounge on.
Step 1: Supplies + Tools
Five (5) 8' Long 2×10s of Construction Lumber
Two (2) 8' Long 2×3s of Construction Lumber
Four (4) 8' Long 2×4s of Construction Lumber
3" Screws
2.5" Screws
#10 Biscuits
Ruler
Pencil
120 + 220 Grit Sandpaper
Rag
Clamps
Sofa Cushions
Danish Oil
RYOBI 18 Volt Cordless Drill with Screw Bit
RYOBI Orbital Sander
RYOBI 10" Sliding Compound Miter Saw with Laser
RYOBI Biscuit Joiner
Step 2: Download the Box Sofa Plan
Click here to download the box sofa plan.
Step 3: Cut the 2×10s, 2x4s + 2×3s
Using a ruler and pencil, measure, mark the 2×10s, 2x4s and 2×3s into the lengths shown in the diagram and cut with a compound miter saw.
Step 4: Sand the Pieces
Give the cut pieces a light sanding before assembling them. Using the orbital sander, start with 120-grit sandpaper followed by the 220-grit sandpaper.
Step 5: Assemble the Panels
Lay the 2×10s for 3 panels on the floor. Use the biscuit joiner to cut notches in the 2x10s. Insert glue in the notches and place a glue covered biscuit into the notches. Use the pipe clamps to clamp the boards together while the glue dries.
Step 6: Screw Together the Bottom Frame
Assemble the bottom frame of the sofa using the 3" screws.
Step 7: Attach the Side Panels
The easiest way to attach the panels to the base is to screw them together. For a more finished look, align the screws, spacing them at even increments. If you want to go the extra mile, recess the screws and cover them with wood plugs made from dowels. You can also add metal L-brackets on the inside for additional strength.
Step 8: Screw the Frame to the Panels
Screw the bottom frame to the back panel with the top of the frame aligned with the top of the first 2x10 in the panel.
Step 9: Finish
Paint the wood using the TK or stain it using the TK, if you like. I prefer to leave it raw, letting life add its own patina.
Step 10: Add the Cushions + Pillows
Set the cushions on the frame, add a bunch of pillows, stockpile some snacks and you have the perfect fortress for a weekend-long Netflix binge!
Step 11: Done!
Good luck making your own box sofa and please email or tweet photos to @benuyeda or ben@homemade-modern.com. For more DIY ideas and projects, visit us at HomeMade Modern.
2 People Made This Project!
  • Organization Contest
  • Paper Contest
    Paper Contest
  • Faux-Real Contest
    Faux-Real Contest
24 Discussions
jbell-3
2 years ago
Will have hubs build for my boys' to use as daybeds. GREAT plan!
Edgar Po
2 years ago
I love the elegant design - so simple and graceful. Well done!
Leathaldose
3 years ago
your 2x10's look dry, are you using kiln fried lumber?
Ekoone
3 years ago
thank you so much for this. am gonna try it out.
Ekoone
3 years ago
DarrenG3
3 years ago on Introduction
hello not sure how strong the biscuits joints will be,is this strong enough ? great idea though alooks even better :D
pesoconquesoDarrenG3
Reply 3 years ago on Introduction
The biscuits are mostly to help line it up straight. The real strength of the butt joint comes from the glue all along the mating edges. With that kind of surface to surface contact, I imagine it's a pretty strong joint.
DanC9
you made my day...I have SO many ideas to expand on this...bunk beds? Why not!
kinderdm
This would make some very nice patio seating if sealed and combined with some outdoor cushions. I may have to keep this in mind for once our patio is finished and covered. I love the simplistic look of it.
I love wood-working projects. Great job!
I have been planning to build myself some wood furniture. I once got as far as cutting the wood to make myself a nice comfortable chair for computing. I designed the seat and back to be slightly angled to make it more comfortable. Had to move before I finished it and lost the wood in transit. I've built several work benches, tables, bench seats, and speaker cabinets among other numerous things from wood. Everything except speaker cabinets is always designed to be easily disassembleable.
I would suggest: a daybed should be at least 6' long inside and an even longer one is better (up to 7').
cburnscrx
I really like this idea, especially for apartment living. It breaks down quite easily and makes moving simple. Good work!
bevin.chu
Strictly speaking, it should probably be called a loveseat rather than a sofa, but no matter what, it looks good.
bevin.chu
Love it! Very good looking. Very practical. Very reasonable in cost.
Also, it gave me ideas for an even easier sofa using plywood instead of 2xs.
hi I would just say it looks great I'd love to build myself one too. thanks for sharing your talents with us
cheers
hi I ust say it looks great I'd love to build myself one too. thanks for sharing your talents with us
cheers
